I want 400hp on my RX
Old Oct 27, 2001 | 10:14 PM
asiandru's Avatar
Question I want 400hp on my RX
Help me squeeze any horses i can out of a stock twinturbo 3rd gen rx7 without modifying the enigne
Old Oct 27, 2001 | 10:46 PM
mazdaspeed00's Avatar
For Sale
this is what u need for a 400 hp FD without modding the engine or twins.
-Downpipe
-Midpipe
-Catback
-Air Intake
-Pulleys
-9.5lb Flywheel
-Front Mount IC
-Upgraded ECU
-Boost Controler
-As well as other relilibility mods
-radiatior
-another oil cooler (if you have a touring)
and finally
-a well tuned car.
with all these mods your should be putting out around 350-400
Old Oct 27, 2001 | 10:58 PM
Bacon's Avatar
IRS 4 Life
and i want a toilet made out of solid gold, but it just isnt in the cards now is it?
above is right, but i dont think id stress the stock turbos to produce that hp, add single turbo to list, i think 374 is abt the highest ive seen on stock twins RWHP
im sootin for 500+with my new setup, but ill have a fuly built motor , well if vosko's car ever leaves the shop
Old Oct 27, 2001 | 11:03 PM
vosko's Avatar
Just Call Me Terminator!
Old Oct 27, 2001 | 11:24 PM
asiandru's Avatar
Thanks for the info, but can u be more specific as in what name brand u would recommend and what steps/order you would do it in.
I'm a bodyman =) completely incompetent when it comes to the engine....
http://www.autolinecollision.ca/cars/RX71.jpg
My rx7 if anyone is wondering....it's basically a rice rocket for now
that's why i definately need the power to back up the looks
Thanks for all replys.
Old Oct 27, 2001 | 11:36 PM
Johnny's Avatar
OG
You really need to get some new wheels seriously...they hurt me..otherwise your car is allright... 400 hp is alot to ask from stock motor/turbo...rear wheel horsepower speaking..its "almost" impossible..highest dyno I've seen is in the 380rwhp range.
more realistic would be a 340-350rwhp numbers with the mods someone listed in a earlier post... as for the order...sounds like you have made up your mind..so why not doing it all at once...once you start getting to your third "power"mod anyways..you get to the point where you need to do all of them anyways..for engine safety.
A big thing the person did leave out is the fuel requirement...with all that garbage and running high boost (anything over 12) you will be pushing the stock fuel system... you need to add
fuel pump (bosch,nippondenso,cosmo) to name a few
RRFPR (rising rate fuel pressure regulator) (SR,M2 to name a few)
maybe even think about larger injectors..1200 secondaries..
There are too many choices to be had out there..but if you want to PM me...I will recommend my personal fav...
Old Oct 27, 2001 | 11:57 PM
asiandru's Avatar
ALOT OF HELP
thanks alot! the more specific you guys are, the easier my job will be. And hahahah yes, i did change the wheels, lol
http://www.autolinecollision.ca/cars/image10.jpg
Old Oct 27, 2001 | 11:59 PM
Johnny's Avatar
OG
Re: ALOT OF HELP
O thank god..you gave them to the 300Z
Old Oct 28, 2001 | 12:07 AM
asiandru's Avatar
so how much am I looking at in terms of cost and time with this list of mods
-Downpipe
-Midpipe
-Catback
-Air Intake
-Pulleys
-9.5lb Flywheel
-Front Mount IC
-Upgraded ECU
-Boost Controler
-radiatior
Old Oct 28, 2001 | 12:18 AM
vosko's Avatar
roughly $8000 installed
Old Oct 28, 2001 | 12:24 AM
JoeD's Avatar
i think 400 RWHP is impossible on a completely stock turbo and engine setup. the higest ive seen on stock turbos was 374, as someone mentioned above. that was on a ported motor, almost maxxing out the turbos, and i think race gas.
porting adds about 30 RWHP....so on a stock engine with a similar setup, expect to see around 350-360 max. to get any higher, you need to steet port the enigne.
BTW, why do you wanna be maxxing out everything on the car?? port the engine, and add upgraded twins. 400 should come up pretty easily with that setup.
my .02.
Old Oct 28, 2001 | 12:26 AM
asiandru's Avatar
SHIET...
i'm guessing that's 8000 US....hmmm that's actually not that bad.
can anyone help me get "Exhaust Leak" off my list under my name?
Old Oct 28, 2001 | 12:45 AM
JoeD's Avatar
Re: SHIET...
dude, quit dreaming.....it's not possible with only bolt ons. if it was, you would see more 400 hp FD's running around. spend 10G's if you want, bolt ons will not get close to 400 RWHP.
sorry to burst your bubble.
Old Oct 28, 2001 | 02:06 AM
rxrx7's Avatar
Austin Powers 2 is the funniest movie made and I agree, for $8G, going single with a FMIC should give you 400hp easy.
Old Oct 28, 2001 | 02:23 AM
FD Racer's Avatar
sold the FD...kept the FB
asiandru,
Are you talking flywheel or rear-wheel horsepower?
Old Oct 28, 2001 | 04:03 AM
HADNSE's Avatar
he's heading for a new motor anyways so let's just add some nitrous on top of the mix now with big *** fuel injector :P
Old Oct 28, 2001 | 08:55 AM
Mr. Belvi's Avatar
It's not exactly a good idea to run turbos at 100% their ability. You will end up overworking them and have to replace them eventually anyway. It would be a lot safer and easier if you went with a turbo like the A'pex-i one if you just want 400hp.
Old Oct 28, 2001 | 10:44 AM
Arrow Re: I want 400hp on my RX
Well, if you're talking about *motor* hp, check out my sig
I'm making in the neighborhood of 400...
Old Oct 28, 2001 | 11:04 AM
Red-Rx7's Avatar
Administrative Me
-Downpipe
-Midpipe
-Catback
-Air Intake
-Pulleys
-9.5lb Flywheel
-Front Mount IC
-Upgraded ECU
-Boost Controler
-radiatior
With what you have listed:
1) Boost gauge. You would be surprised how much diagnostic information can be attained from an accurate unit as this. This will give you an idea of your engine health, performance, and your 'looks cool' factor. There are many different boost gauges, and I recomend going to a digital unit. Stay away from Autometer if possible. Those tend to be off +-1.5psi. I recomend Greddy/Defi/Hks/Apexi etc. Go with a name brand. You can choose the face color, position, etc. This is a reliability and in your case, a looks modification.
2) Water/Coolant Tempature. I would put this in the same time as the boost gauge. Again, this gives you all the benifits as above. The stock gauge only has three settings: A) COLD B) OK C)SCREWED. Your car wont run correctly in two of those settings. Its nice to have some sort of information, unless you have a money tree in the backyard and don't care.
3) Vacuum Hose. This is a frustrating task, but one well worth it. Those damn black snakes that cover your car can cause some leathal bites if one decideds to be mean. Since you noted you are a 'body/looks' guy, this is a great chance to pick up some color silicone tubing to customize your engine bay. Use zip ties! Also buys some worm clamps, and dump the stock ones. Use zip ties to hold the silicone on the nipples. Doing this mod will provide reliabilty.
4) Air Intake. I recomend a custom one. You can fabricate two pipes leading off your inlets with a K&N Filter on it. This is the cheapest way to go, and provides flexability. If you want to be more elaborite, you can fabricate some cold-air induction unit where the oil-cooler would normally reside on the 'R' models. This will open up your breathing for your engine. This would also be a good time to remove your airpump. Doing this will add power.
5) Downpipe. I recomend this as your second, if not first step. This is considered a 'safty' mod, but does add power. Depending on how many miles your car has, these precats tend to clog up, causing all sorts of problems; primairliy heat exchange. Dump the stock downpipe, and pick up a downpipe from either HKS (199), Pettit, or someone. They all usually run in the same category. This will add power and reliability.
6) Catback. Removing stock exhaust is always a good thing when considering power additions. There are many routes to go on this one, but it all depends on what you are looking for. You noted you were a 'looks/body' guy. Are you a 'sound guy' too? One of the best flowing HP exhausts would be the Apexi GT. Your decision here. At most, you are looking at a minimal rwhp between the different setups. This will add power.
7) ECU. Some people may note that I am throwing this into the equation too soon, but I would do this early in the game. You have MANY options here. Since you commented that you are a 'body/looks' guy, rather than 'tuner/mechanic'; I would recomend you stay away from these: Haltech, Wolf, PowerFC, TecXX, Motec or anything that is somewhat of a stand alone system. With that out in the air, I recomend you do not get a Peter Ferrel PMS unit either. What I would recomend, is Pettit's unlimited ECU. Simple plug and play, and allows you to run boost up to your map sensors capability (17.5 psi). Doing this modification will provide reliability and power.
8) AST Modification. Now would be a good time to remove the stock (plastic) Air Seperator Tank. These things are prone to becoming brittle due to the heat & pressure. Last thing you want is to be racing and having this thing bust on you. Go with Pettit's AST. Great choice. Doing this mod will provide reliabilty.
9) Grounding Straps/Battery Relocation. You should do this now, since the next two steps will be most difficult if you don't.
10) Radiator. Some may say "go with the midpipe!!", while others may have said "You should have gone with a radiator 1st!", I believe responcibility is the key. By this point, you will have the technical information infront of you to be a safe (for the car) driver. Before jumping into the next few steps, it is a good point to continue with the reliabiltiy. Most everything else from these next few points will start adding horsepower, while knicking your reliabiltiy. Grab a good radiator, don't be cheasy. I would recomend Fluidyne. The mounting location depends on what decide to do on number 8. Use watter wetter with your coolant as well. Doing this modification will provide reliability.
11) Intercooler. Well, here is a chance to define how you want your car to be. What do you do primarily with this car? Is it a weekend warrior/drag racing killer? Or is it an AutoX or RoadRace car? The difference is which intercooler you go with. An upgraded Stock-mount or CWS intercooler is best used with a RoadRacing/AutoX scenario. In these types of usage, you want the radiator to be up front collecting that cool air first. For street warrior/drag racing, grab a front mount intercooler. Which brand depends on what you are doing. If going with a stock-mount intercooler, I would recomend Peter Ferrels unit. It works well. As for a FMIC, in your case, I would go with an Apexi unit. Don't be confused in buying the 'biggest of the biggest'; meaning, don't buy a Greddy 3 row, since your boost will be 16 and below. These intercoolers are for high-boost scenarios.
12) Piping Because your redoing your intercooler configuration, now is the chance to clean up some of those bottlenecks/weird bends. I would recomend going with a greddy elbow (even one with a BOV flange), and an Efini Y-Pipe. Then, get some nice 3" or 2 - 2/3 piping fabricated to the sections. Buy some matching/contrasting silicone piping connectors.
13) BOV Since you have the flange for it now, it would be a good turbo saver on unwanted backlash pressure.
14) Turbo timer Ok... here is the deal on this one. Get one, but don't use it for a turbo safty application, rather an engine application. In all reality, if you drive your car hard you should drive some cool off laps. But, in the cases you cant, use the timer. Take notice: The stock turbos are oil cooled, and water cooled; therefore the turbo timer really doesn't help as many people think they do.
15) SparkPlugs. Again, I would recomend changing your plugs to some 'racing' plugs by this point. It never hurts (except maybe mpg economy.. But thats not what we are here for is it?) and offers safty. I would also recomend you go with some thicker plug wires while your at it. Stay with NGK plugs. Doing this would be a reliability and power gain (not much power, but it helps!).
16) Fuel! As you start to reach into the heavy power delivery, fuel upgrades are recomended. At the mininum, I would at least get a new fuel pump. Upgraded injectors/rails depends on you. If you do go with upgraded injectors/rails you will have to decide how you want to control them, in which this relates back to the ECU you choose. Remember, you can always buy a fuel controller seperatly, but I recomend against it. This will enable you to run more power reliable.
17) Fan Mod. I would do the FAN mod at this point to provide you with that extra tad bit of cooling. Basically, this modification forces your fans to run in high-speed mode all the time, vs the other speeds. Doing this mod will provide reliabilty.
18) Thermostat Change This depends on your car. You may not need it in the region you are in. But, if you drive the car hard, its recomended. Go with a colder thermostat, or drill yours out. This will push the coolant through earlier in the game. Doing this mod will provide reliabilty.
19) Mid-Pipe Hang-on baybee! Thats what you will be thinking when you take your cat out of the car and put a straight through pipe on the car. If you do each piece individually, this will be the component that you will recognize the most power gains. Watch the boost creep! Doing this modification is a power gain, and -1 off on reliability.
20) Boost controller. With open exhaust and intake, your boost is going to start to creep and spike upwards. There is a lot of controller units out there on the market. Depending on what your goal is, decide on the product. I will let you do the research here. Basically, if you are looking for something to completly tune every 500 rpm increments of boost, delays, etc go with the Apexi AVC-R. If your looking for a good twist and turn go type, grab a Greddy ProfecB.
21) Pully kit. Well, we are getting down to the little things that are needed. A Pully kit will give you a little hp. But anything works. Do some research on this, and choose the appropriate kit.
22) Ignition Amp. I recomend you go with a unit that DOES NOT REQUIRE splicing into the coil harness. Some units do, and this is a nono in my book. It seems that once you start cutting into the resistance of the wire, bad things COULD happen. Either way, my recomendation is the HKS Twin Power. Easy bolt on. This will give you more power.
23) Removing the AWS. Removing the Accelerated Warmup system should be done next. I recomend you should cut the butterflies in the manifold out as well. Since you are disabling this, the butterflies sit in there in an 'open' state. Removing these, and capping the holes has actually shown RWHP gains. Coincident? Maybe. But, anything to remove turbulance going into the engine must help. Doing this mod may provide more power.
24) Short Shifter kit This would be a good time to start doing the driveline/other sections of the car. Go ahead and get a short shifter. Everyone needs one! heh
25) Clutch. Your going to need a clutch real soon with all these modifications. Remember though, we are only running at 12 psi max right now. Why? So your damn car doesn't fall apart. Grab a good clutch. ACT/BONEZ is an excellent clutch that will last you a good period of time. I would recomend staying away from centerforce. Some people have had good things to say, but most I talk to don't. I didn't. Also, you don't need a clutch that is 'on/off' either, unless you want to look like a fool driving around town lurching everywhere.
26) Lower weight flywheel. Any recipicating mass that you remove helps. This happens to bring your RPMS up a little quicker too. As you will start to notice, we are just about done with performance. Now we are getting into the little things that do make a difference.
27) Suspension kit. If you are making 397 rwhp with the stock suspension, throw a suspension kit on there. You will then make 397 afterwords, yet your car can be faster. Suspension tuning can counter the horsepower blues. Have fun playing!
28) Beefy rear end!. Throw a KAAZ 1.5 LSD in there. This will help on those 7k launches. Trust me, it is no fun braking the pumkin in two. Its very costly I might add.
29) 4.33 gears Well, changing the gearing always improves some sort of time. Generally, people that have changed to these gears don't notice a 'speed' increasement, but rather the 'correct' rpm in racing. Depends on your application.
30) Upgraded power plant frame. Mazdaspeed sells a nice one. Its red too.
31) Upgraded axles. No one likes a week link in the equation, and your axles will be it. Grab some nice chromoly ones. Hope you have some money left over.
32) Weight Reduction. Again, if you are at 397 rwhp, take some weight off and stop eating the McDonalds breakfast. This will make the car seem as though it has 410 rwhp. But in your case, it will just bring the car down to the weight before you added all the body kits.
33) Pay mike for typing. I am tired of typing now. good day.
34) oh yeah.. turn up the boost to 17 psi add some gas, make a few 400 rwhp passes.
35) replace engine .....
mike
Old Oct 28, 2001 | 12:54 PM
JoeD's Avatar
nice piece of writing there Mike! can someone archive that for all the newbies??
Old Oct 28, 2001 | 05:22 PM
asiandru's Avatar
DoPE
**** you guys are awesome! with all this information i'll be sure to reach 400hp, even 600hp with the right parts.
Now....just to find a mechanic who knows what he's doing? anybody know any recommendations around the vancouver BC?
more questions...
everybodys been telling me to change out my twin turbos and get one BIG turbo? good idea?
what about Nos? they claim RX7's don't work well with Nos? true? why?
THANKS!!!
Old Oct 28, 2001 | 05:51 PM
Nathan Kwok's Avatar
I think it is best not to just go all out all at once. If you've been happy with 255hp up until now, which is ~220rwhp, then nearly doubling that is quite a big first step. It will be A LOT less work to simply go with something like an M2 stage 3 kit, which doesn't require dyno tuning, custom parts, fabrication, etc etc, and you'll still get 320rwhp at least and still be (mostly) emissions legal. Most of the huge HP freaks started with stuff like that and then realize they need more, but if you don't need more, it won't even be close to worth it. And you definitely don't need 600hp if you won't be racing.
Old Oct 28, 2001 | 06:46 PM
neo_omega's Avatar
***Moderator***
:o seems like we will see this guy's engine blow up soon. There goes another engine.
Old Oct 28, 2001 | 07:01 PM
Wow a good post!
Nice post Mike! you a patient.
Brakes - I'd add some Brembo rotors for the front with Potterfield pads.
Fuel system - You will need some ND 1200 or 1300 secondaries. I've hit 89% on 13 psi and I still have a MP. Either Bosch or Walbro fuel pump. I think Bosch is better and costs more.
I think the M2 stock IC is a good choice.
I'd go with the comment about too big of a jump. Your suspension and brakes will not keep up with a 400rwhp rig. I'm at about 300 with modest brake tire and suspension upgrades and the power is not the issue.
Oh yeah and I totally agree with Mike's #35. Once you pop it you can get a ported motor.
Old Oct 28, 2001 | 07:41 PM
martini's Avatar
I think you should street port it too.
