Update! Front Brakes finished (less bleeding) 56k noway!
Old 02-25-04, 09:18 PM
Like Ghandi with a gun
Kenteth's Avatar
Hey all, had a nce day today. So ed, coming over this weekend to help me bleed brakes and install the tranny? The flywheel should be here friday...
Total cost:
2 front rebuilt calipers: $120
2 rear rebuilt calipers: $140
2 front rotors, new: $56
2 rear rotors, new: $54
Stainless Steal lines: $85
Brake fluid: $5
Total: $460
anyone have an idea what this would have costed if a shop did it? 4 corner, new/rebuilt everything brakes?
Full picture gallery of today's update: http://sheepdog.ar2engineering.net/p...-25-04--brakes!/index.htm
Kenteth's Avatar
Total cost:
Brake fluid: $5
Total: $460
Old 02-25-04, 09:20 PM
Y00s a h000
Ocelot's Avatar
Thats a lotta posts.
Old 02-25-04, 09:22 PM
Kenteth's Avatar
aughhhhh... every time lately, it like posts my thread x10 and takes ten minutes to post.
Old 02-25-04, 09:26 PM
brohr01's Avatar
wow, i have those exact jackstands. you get them at walmart?
Old 02-25-04, 09:27 PM
casio isn't here.
casio's Avatar
where'd you get the rotors? are those single piston front calipers?
btw -- link didnt work.
Old 02-25-04, 09:29 PM
Kenteth's Avatar
yeah... add on "!/index.html" to the link, the forum isn't allowing the ! in the url... the fronts were from napa, the rears were from an ebay auction. single pistons
Old 02-25-04, 09:30 PM
Kenteth's Avatar
http://sheepdog.ar2engineering.net/pictureserver/
goto the last link in the left column
Old 02-25-04, 09:31 PM
Kenteth's Avatar
LOL yeah, actually i did... $7.50 a piece if I remember right...
EDIT: for got about the spleed bleeders...
In all i suppose its costing me around $500 for the four corners...
Old 02-25-04, 10:11 PM
seven-less
Sir Rupert Hobo's Avatar
Kenteth, the speed bleeders: what, where, and for how much?
or anyone else know some good ones?
and where did you get the rebuilt calipers?
Old 02-25-04, 10:22 PM
Kenteth's Avatar
I got the front calipers off the forum, and the rears off ebay ( i think, maybe they were both off the forum, i forget now). The speed bleeders came from speedbleeder.com i think. I've seen them at nopistons for slighly cheaper (couple dollars to the set)...
Old 02-25-04, 10:29 PM
Kenteth's Avatar
I just checked my old PM's, it seems those rear calipers only costed my $120
Old 02-25-04, 10:35 PM
seven-less
thanks dude
Old 02-25-04, 10:41 PM
Russ's Avatar
where did you get the ss brake lines?
Old 02-25-04, 10:52 PM
Icemark's Avatar
Please only post a thread once!
Old 02-25-04, 11:55 PM
Open up! Search Warrant!
Project84's Avatar
Location: Kicking down doors in a neighborhood near you
Hey man looks nice. I have standby duty this weekend so I don't know if I'll get called or not but I'll try to come out and help you do as much as I can. The brakes shouldn't take too long to bleed, and the clutch is cake. Did you get the counterweight from the auto drive plate off the crank shaft yet?
Old 02-26-04, 12:00 AM
Haven't we ALL heard this
Wankel7's Avatar
Could have rebuilt the brakes your self and saved even more money.
Looks good though.
James
Old 02-26-04, 12:44 AM
Couldn't stay away
F1blueRx7's Avatar
Yeah I was gonna say, who rebuilt your calipers?
Old 02-26-04, 01:33 AM
Kenteth's Avatar
I bought them from mazdatrix.
Yeah... I know
Nope, the plan for tomorrow is after work, swing up to sears and buy a puller ($29). Go home, finish the rear brakes (mazdatrix never replied back to confirm the rear-steer bushings... so i dunno whats up with that...) I'm going to try to see what happens to put it together w/o the bushing. It will probably suck... but I don't know what mazdatrix did with my order... Then I'll remove that couter weight. The flywheel should be here friday.
Yeah... I did that wit the rear caliper's last summer. So.. technicaly I do have two rebuilt rear rotors that are now for sale. Heh... yeah, i wasted a little cash i guess...
I rebuilt a set last summer... It didn't solve many problems though (lack of skill/tools). Anyhow, the repacement is going much better (less the desinigrated rear-steer and few rounded bolts).
Old 02-26-04, 06:32 AM
hIGGI's Avatar
werd front calipers u have....
Old 02-26-04, 07:39 AM
Kenteth's Avatar
just single piston is all...?
Old 02-26-04, 07:42 AM
hIGGI's Avatar
yeah, just wondering anyone would spend money on single piston when 4 piston is available
Old 02-26-04, 07:48 AM
Yup, still here
Nick86's Avatar
I was thinking the same thing - You have the 5 lug, why go with single piston calipers? Weird.
Old 02-26-04, 08:03 AM
didi u have problems taking the rotors off the hub?
on my 88 vert, I am doing the same minus the hoses, and I got the 2 screws off but the rotors will NOT come off the hub, any ideas?
my car has been on jack stand for a month :-(
I tried lightly hitting with a 3 lb hammer, no luck.
help!
Old 02-26-04, 08:29 AM
Yup, still here
Nick86's Avatar
help!
Use a 10 lb hammer.
Seriously - soak it in releasing fluid and start hitting the disk (at the hub). Keep turning the disk so that you don't keep hitting the same place. Hit it hard - and if all else fails use heat.
Quick Reply: Update! Front Brakes finished (less bleeding) 56k noway!
