Wich will make more hp xs t04s or apex Rx-6
like the title says
it will be on a fully pored motor and all the acomping goodies...
im lookin for 20-22 psi boost...wich will give me the most top end
The T04S will make more HP. I think it is difficult to make the rx-6 get over 425HP but the T04S will take you close to 475-500 with a ported motor and 20-22 psi. If you want to make really high HP you should consider the T-78, T-88 or the XS T04X possibly even a T-70 but it doesn't come in a kit.
The T04S will probably make more but I still wouldn't sell the RX6 short. I made 417 RWHP corrected (443 uncorrected) on a fully built engine at 15 psi on 89 octane fuel with the RX6. I haven't had time to further tune my car but with some better octane fuel and more boost and time more time on the dyno, I think that 450-500 RWHP is easily doable.... its just that my 1200 cc secondaries are just about maxed out.
well the only reason im not goin sommething bigger is b/c im tryin to keep a glimer of streetablity..im use to non-seq with full boost in the 3800-4k range...wich dosent bother me...im just wonderin wich can make the hp...it seems they are similary sized, im just wonderin how much the rx-6 can flow compared to to4s....
There are dyno curves of the XS-Engineering T04e/s kits on their web site. I don't know the dyno curve of the other one you are considering. I'd want to see that.
Peak power for 1-2k rpms are not the end-all-be-all. I choose the T04e kit because it kicks the T04s kit's *** till about 6k rpms. With my confiuration I'm supposed to get 400+rwhp peak. That's good enough for me.
Ken
Ken
Trending Topics
Originally posted by wankawankel Go with the T88 like me. Don't you wanna do wheelie's past your ompetition? (fast & the furious scene)
28lbs w/100hp wet shot will do the trick.
Ken
well i ned some power below 5k...i men i do like to street race...but i wana be makin 450+@ the wheels... to4s iveseen the harts for 47x.xx but the rx-6 is rated @ 400 @ 15psi..im gonna be runnin 20..so theroiticly it should be in the same ball park...i cant let vosko with his to4s be faster..hehe
+ a 20lb nos refil is like 40 bux....i cant afford that..
Re: Wich will make more hp xs t04s or apex Rx-6
