Thinking N/A SP 4-port...
Old Oct 14, 2003 | 03:43 PM
Liquid Anarchy's Avatar
We come with the Hardcore
Well... with the new information presented to me about the Aux-Bridge; I'm contimplating an N/A 4-port. S5 rotating assembly, MegaSquirt for fuel, 12A Dizzy for spark, full header-back exhaust. I want to keep it very streetable (this will be my daily driver) but also, I want 200+ HP.
The question at this point is... what intake manifold should I use?? I've seen modded 6-port manifolds... but that's kindof... eh'. But the 4-port manifolds are pointing the wrong direction.
Also; what kind of porting to do? I'll at least put a large streetport on it... but, what about a half-bridge?
Let me know what you guys think.
Old Oct 14, 2003 | 06:36 PM
bump
Old Oct 14, 2003 | 06:40 PM
j200pruf's Avatar
RIP Icemark
Hey Liquid, I know this sounds like a broken record, but you should try and IDA manifold with 50mm throttle bodies. IDA's are probably the shortest manifolds that you would want to run on the street. And for TB's, there are quite a few different manufactures out there today.
Old Oct 14, 2003 | 08:10 PM
Yeah, I know that, I just can't afford one right away. I plan on using a stock TII, or a Modded N/A manifold... I just don't know which one yet.
Old Oct 14, 2003 | 08:49 PM
88IntegraLS's Avatar
Displacement > Boost
Are you trying for 200 BHP or RWHP?
Old Oct 14, 2003 | 10:24 PM
RWHP... I've got a lot more done than listed.
Old Oct 15, 2003 | 02:40 AM
^TTT^
Old Oct 15, 2003 | 03:06 AM
I wish I was driving!
Re: Thinking N/A SP 4-port...
Why does it matter which way the UIM points? You could route on of the upcoming RETed elbows to run into a CAI following the same route as the Greddy Intercooler kit, with the piping running along the left side of the car and the filter being located in the drivers side of the front bumper. Afterall, you have no AFM.
Works for me.
I'd try a small half-bridge, and make the bridge fairly wide. That should meet your goals.
Old Oct 15, 2003 | 03:10 AM
Hmm... Or use an S5 TII LIM connected to an FD UIM with a FD Greddy elbow, CAI as described above, half bridge. I haven't yet experimented with the renesis rotors, but they seem affordable at $700 for a pair, brand new, if they work.
Old Oct 15, 2003 | 05:56 AM
KNONFS's Avatar
B O R I C U A
Re: Re: Thinking N/A SP 4-port...
Works for me.
And as a "extra" benefit the air filter will be located on a MUCH cooler area than the one on the 6 port manifold
Old Oct 15, 2003 | 07:45 AM
faster7's Avatar
Remember Liquid you'll get to a point where 200whp isn't enough and you'll wish you'd started out turbo.
At least with a 4 port bridge of some sort and a standalone, put just a bit of boost to it and that extra power won't be hard to come by.
Is it known whether the renesis rotors have the same balance as S5/S6/S7? Or would you have to pop $700+something else for balance?
R
Old Oct 15, 2003 | 07:50 AM
faster7's Avatar
Double post.
Old Oct 15, 2003 | 09:43 AM
mazdaspeed7's Avatar
mad scientist
Why do people here seem to think the 4 port motors are the only ones that can make decent power? A 6 port motor has more port timing and area than any 4 port could hope for without the port beign backfilled with epoxy.
Old Oct 15, 2003 | 11:22 AM
KNONFS's Avatar
B O R I C U A
Sometimes things look good on paper but doesn't on real life. Know what I mean?
Old Oct 15, 2003 | 12:05 PM
mad scientist
But thats assuming that the ports themselves are the problem. That is also assuming that everything else being equal. I totally disagree, and I expect to change the way people see 6 ports. I see a long list of problems with the vast majority of n/a's running around. There are a few people aside from myself that are building n/a's that bypass the problems I see. But right now, myself, and the 2 people im specifically referring to are breaking in our motors. I could argue on for hours with theories backing my point of view, but I see no point. Proof is what matters here, instead of physics and conjecture.
But like I said, there are just too many variables to say 6 ports are inferior to 4 ports, based on the hp people have gotten out of them in the past.
Old Oct 15, 2003 | 12:18 PM
Black13B's Avatar
In Full Autist Cosplay
Anarchy - Why the 12A dizzy for spark?
renns has developed a way to mainain the stock ECU only for spark use, and the MS unit takes over everything else functioning essentially as the main ECU.
This is how I will be setting up my GXL over the winter.. MS unit, but no dizzy, just retaining stock ECU for spark.
If you already know about that, then I am curious as to why you chose the dizzy over this method. Pro's? Con's?
Old Oct 15, 2003 | 02:17 PM
j200pruf's Avatar
RIP Icemark
Black, did he make a set-up for a S5 or S4, cuz I think it would be a little bit harder to do that type of a set-up with a S5 ECU, since liquid will probably be removing a lot of the ECU controlled stuff.
And going with what MS7 said, I had been talking with Dana (Rotary Racer, I think) about doing a 4 port N/A. After talking about this for a week or so, I talked to Rob Golden. He said that would be a bad idea, since the 6 port can flow MORE air for a N/A.
Just something to think about.
Old Oct 15, 2003 | 03:35 PM
One of the major problems with the 6 port block is the intake manifold (espicially the LIM with their auxilary port actuators). Sure, you could spend hundreds of hours fabbing your own intake manifold, but why bother when the 4 port already had a good manifold, and will make just as much power as the 6 port when configured with equal compression rotors, if not more.
Really, if you want to prove your point, you need to do so first before making claims. Your credibility on this forum has been questioned before when you made claims that your car was "in the 13's", and that you were "going to the dyno next week" (seemingly every week), but never produced a dyno graph or a timeslip. You can't claim numbers, especially in cases of such huge controversy, without having any proof to back it up, just as the situation is here.
Old Oct 15, 2003 | 03:40 PM
J200; right on the money. To piggyback the S5, you'd need to keep a lot of sensors, or the car will go into limp-mode.
MS7; You have made the connection... maybe there's more to HP than timing... flow probably plays into it quite a bit (see the SP vs. Aux-Bridge thread)
Russell; Don't call me Liquid.
Anyone; Know someone w/ a Half-Bridged 4-Port N/A??
Old Oct 15, 2003 | 03:47 PM
mad scientist
I only stated that I have a point to prove. Im not making any claims now. But Im not so sure im even going to visit this forum anymore. I get into argument after argument, and no matter how much it adds up on paper, I cant seem to win for losing. In the past I havent had the funds to prove anything, but things have changed. But now I dont see the point. No matter what, people are going to doubt my results. Just because its been done that way before, and continues to be done that way doesnt mean its the right, or especially the best. Im sick of wasting my time here, all for nothing.
Old Oct 15, 2003 | 03:52 PM
KNONFS's Avatar
B O R I C U A
I like your point of view, and will wait for the numbers. I really hope you prove us wrong, but till then I will stick with what I've seen
Old Oct 15, 2003 | 04:11 PM
mad scientist
At least someone appreciates trying somethign new. ESPECIALLY when they have been proven time and time again on other continents...
Old Oct 15, 2003 | 07:40 PM
Black13B's Avatar
J200, renns has done it with an S4 ECU.
Considering the MS unit is running the engine anyways, is there no possible way to swap out an S5 ECU setup with the MS/S4 combination? What would it really take, considering the MS unit is pretty much tying up all the loose ends? (Or perhaps am I not looking at it from the right point of view)?
Old Oct 15, 2003 | 09:55 PM
. . . meaning the split in the secondary runner for the aux'es? Or just the general suckiness of the stock NA manifolds?
Old Oct 15, 2003 | 11:08 PM
mad scientist
Standalone ems and a non stock intake manifold and TB, primarily. Aside from peoples mindset holding them back, i see the major problems as the stock intake manifold and EMS. They dont work very well in stock form(especially the EMS), and modding the car only makes it worse.
btw, when are you going to get AIM?
