Racer needs quicker boost response
Old Sep 17, 2003 | 07:18 PM
Spank's Avatar
mythical Unicorn
Guys I need your help. I have a 93 with sequential and PFC tuned to 364 at the wheel. I also have 4.88 gears in the rear, however I need quicker boost respons.
Any suggestions what we can do to help get quicker response. Scotty White has 400 lbs of torque at 1800 RPM's in his ZO6 so I need any help I can get.
Thanks for your help.
P.S. Let me know if you did any of the improvements what change you noticed.
My car is no slug but I want to do better and I need better response.
Thanks
Old Sep 17, 2003 | 07:42 PM
rynberg's Avatar
The stock turbos spool instantly from 2800 rpm up, the 99-specs from about 2500-2600 rpm from what I've seen other people post. I don't know why you would need "quicker" boost response, if you are racing, you should never be in that rpm range anyway.
Are you using an aftermarket boost controller or the PFC to control your boost? Perhaps you have the wastegate set to open at too "mild" of a response, therefore slowing your spooling.
Old Sep 17, 2003 | 07:45 PM
LetsGO7's Avatar
i don't know if this is true....but here i go...
I never drove my FD with stock flywheel, i drove the car with lighten flywheel....if you want fast turbo response lighten flywheel maybe build up the boost quicker by very LITTLE. heavy flywheel (stock) will produce slow to more of a kick while boosting to boosted.
There are other things you can do, with your PFC playing around with your timing and fuel (low to mid area). Rally cars have KILLER low-mid tuning and high ends isn't really there compare to low-mid (rally cars have good HP figures and KILLER torq. figures). Also anti-lag on the turbos setting through PFC will QUICKen up your turbos but you better have money to buy another set if you run it for awhile, if you turbos are like 10,000miles or over, don't do it. Fresh turbos should be practiced with anti-lag. image....racing team changes there turbo like every round or every other....which means it get pretty crazy.
-joe
Old Sep 17, 2003 | 08:01 PM
CCarlisi's Avatar
Rebreaking things
The pfc will stick lock the turbo system in secondary mode once you switch over until the rpms fall to 3000, even though the foward switchover point is 4080rpms. Therefore if you punch it, let off and fall below 4080 but above 3k you're going to have a lot of lag. Apparently, you can adjust this with the datalogit. I'm going to play around with mine this weekend.
If you have an aftermarket IC you might consider removing the airbox and putting K&N filters on the turbo inlets. I did this out of necessity because my greddy FMIC was taking up the space that the airbox used to occupy. After replacing the box and upgrading the IC boost response increased significantly. The greddy FMIC is supposed to have more pressure drop than the stock IC so I attribute the increase in response to the removal of the airbox rather than the IC.
Old Sep 17, 2003 | 08:08 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Damn... 364 @ the wheels?? Nice. What are the rest of your mods?
Old Sep 17, 2003 | 08:21 PM
turbogarrett's Avatar
0 lbs of boost
if you're using a manual boost controller, only use a ball and spring type instead of the home depot bleeder valve. other than that the only other way i can think of for better response would be to drop a ls1 in it
Old Sep 18, 2003 | 12:25 AM
turbojeff's Avatar
Do it right, do it once
Hey Spank, it's Jeff H.
Your not ever going to get the low end torque Scotty has, ever... 99 twins will give you a little better response but not Z06 response.
Rynberg, never have autocrossed I'm guessing? See sometimes on a 45 sec run it isn't really worth upsetting the car shifting from 1st to 2nd and back to first again in tight corners, you end up just making due and pulling out of a corner at low rpms. This is really where Z06 kicks the FDs ***. It isn't just the HP, it is the powerband, that motor pulls nicely from the bottom end.
To everyone else, he's got about all the mods you can have and stay in SM2, FMIC, light flywheel, etc, etc, etc...
Old Sep 18, 2003 | 08:36 PM
Spank's Avatar
mythical Unicorn
Jeff
Hi Jeff, I have heard about the 99 turbos. Eric will sell me his 2000 since he is going to a 3 rotor next year. I have also heard things like a boost controller will help spool up due to ours being open early. I have also heard something about doing some porting in our turbo manifold.
You know my car and yes I have everything you can have and still be in SM2. However I have heard that we can get boost even faster with some modifications. Also as stated above I have heard about boost with no lag.
You know autocrossing I do not put many miles on the car. If I could have no lag and had to replace the turbos every few thousand miles or so that may be worth it.
What have you heard about the above?
Thanks everybody for your help. As jeff said I have lots of mods. What I am looking for is how to make the response happen faster and harder.
Allan
Old Sep 18, 2003 | 08:59 PM
Icemastr's Avatar
All Motor
Get a 6 speed transmission. Want me to come over to Boise Idaho and beat this Scotty fellow with my Miata?
Old Sep 18, 2003 | 09:49 PM
BoostedRex's Avatar
NorCal 7's Co-founder
Did you ever think about upgrading to the BNR Stage 3 turbos and having them left as a sequential setup instead of going parallel? You should be getting boost faster with those and just up your boost to 14-16PSI. That would be a huge power difference and the turbos are still the stock part number so it wouldn't eliminate you from the class if changing to an aftermarket turbo did that. I know it sounds kinda shady, but still an idea and one that would work from what I have seen. Best of luck to you and I hope that helped. Laterz.
Zach
Old Sep 18, 2003 | 10:00 PM
rynberg's Avatar
Well, last Sunday was my 4th time... It was also the first time I had to deal with curves slow enough (and a slippery surface) that a shift down to 1st was pretty much mandatory. My first three auto-x were not tight enough (with a grippier surface too) to REQUIRE a shift to 1st.
I completely understand the low-end torque advantage that the V8s have in that circumstance. I'd imagine it's one of the reasons the Z06 is now dominating over the FD in SCCA.
Old Sep 19, 2003 | 12:32 AM
turbojeff's Avatar
LOL. Yeah, you try it. Oh it might help to mention Scotty doesn't just trailer his Z06, he brings it in a nice black SEMI truck with race trailer. He doesn't just autocross either, hes a road racer too.
I'd actually be surprised if you didn't end up dead last.
Old Sep 19, 2003 | 12:47 AM
Snook's Avatar
Tony Stewart Killer.
IMO autocrosses are stupid
roadracing is the only way to go
Old Sep 19, 2003 | 09:53 AM
NorthwindHost's Avatar
Hmm... About the flywheel.
All the lightened flywheel does is let you accelerate faster. It actually has nothing to do with the turbo system. The downside of the lighten flywheel is that once you let off the gas, it also decelerates quickly too due to the fact that momentum is less on the lightened flywheel then the stock.
I would just get the BNR Stage 3 to do the work.
450+ isn't bad to the wheel.
Old Sep 19, 2003 | 01:02 PM
Snook's Avatar
another IMO
the bnr turbos are stupid
If you want 450+ to the wheel get a small single turbo that spools fast (I don't think they can do 450rwhp anyway when pushing them to the max 19psi.)
some are leaking oil, they still retaint the stock manifold and position close to the engine where they provide unnecessary heating, and aren't proven to last yet.
However if you need to pass a certain inspection for track use it's probably the best choice unless the newer style turbos with more hp are reliable at high psi.
Old Sep 19, 2003 | 01:15 PM
dubulup's Avatar
development
another IMO
Snook, he wants to stay SM2, don't think he can go single???
Maybe try a combo of things, port match exhaust manifold, ball and spring boost controller, , and the BNR's. But like stated before I don't think any rotary will have 400ft-lbs at 1800rpms.
Old Sep 19, 2003 | 02:25 PM
moehler's Avatar
I don't think this would help too much, but if you don't have one, what about an Efini Y-pipe?
Old Sep 20, 2003 | 09:12 PM
Spank's Avatar
mythical Unicorn
BNR Turbos
Zach
Zach in SM2 I can do whatever I want to the turbos. Currently I am running 17lbs of boost. I have heard about the BNR however I have no data or have yet to actually speak to someone who has them in the sequential mode and can compare. Also I have heard how the Garett will spool quickly due to the bearings. Currently I am looking at upgrading the turbo and doing a Blitz boost controller. Any upgrades will be done over the winter so I will be ready for the first national race next year.
Do you know anyone with first hand experience with the BNR or Garett?
Allan
Old Sep 20, 2003 | 09:24 PM
Spank's Avatar
mythical Unicorn
Secondary Mode
Would you please let me know if you are able to overcome the problem. I have never heard of the situation you are talking about. So please let me know what you find.
Thanks
Allan
Old Sep 20, 2003 | 09:30 PM
Spank's Avatar
mythical Unicorn
Secondary Mode
Thanks
Allan
Old Sep 20, 2003 | 09:56 PM
Icemastr's Avatar
All Motor
You havent seen my Miata, it doesn't need to be trailered in, but I run 93 and 15psi for small local events/practice and 116 and 20psi for major race events, using a HKS GT 28/35 with a Tec III ecu, bored to 2.0L and ported cylinder heads with an 3rd gen transmission and rear end. Adjustable coil overs with 750 front and 350 rear spring rate. It has a trailer hitch so I can bring my set of racing slicks too. I think I might do a bit better than last place, but this Scotty guy sounds pretty serious and it sounds doubtful my little Miata would beat him, how much does his car weigh? Mine is 2090 /w driver. It makes great torque on the low end, and about 400HP is the max I can push on race gas.
Old Sep 20, 2003 | 10:26 PM
bureau_c's Avatar
Damn, that sounds like a serious frickin' Miata. Yikes...how can you have any traction at all w/ that much power??
jds
Old Sep 22, 2003 | 12:51 PM
turbojeff's Avatar
Sounds like a badass Miata. 4 time novice class champ? How do you do when your running with the big boys? Do you beat everyone?
Old Sep 22, 2003 | 01:03 PM
have you looked into the m2 ball bearing turbos??? should spool faster!
Old Sep 22, 2003 | 02:57 PM
Mahjik's Avatar
Mr. Links
That's not a bad idea. Artguy is running those and he probably has the best lowend power of any FD on the forum.
