Power FC Is it ok to use 02 feedback control without an airpump
Old Aug 27, 2003 | 12:41 PM
weaklink's Avatar
Resident Retard
Question Is it ok to use 02 feedback control without an airpump
I have heard that you should not use 02 feedback control without an airpump. Why not? It seems to me that the 02 sensor is way upstream of the cat which is where the airpump injected air for emissions, right? I want to run 02 feedback not only for the mileage, but also to cut down on the choking exhaust fumes at light cruise and idle. My WB02 only functions at >13 volts, not always an option with my underdrive pulleys, especially at idle.
Old Aug 27, 2003 | 02:30 PM
REAL papaSMURF's Avatar
works fine with me, but then again i have a cutout. with it closed, it still works allright.
Old Aug 27, 2003 | 05:46 PM
twokrx7's Avatar
Need more sleep
if it works then use it
my car will try to go into cosed loop at idle and light throttle conditions ... pain in the ***, ymmv
Bauer778
Nov 4, 2015 04:42 PM
alexdimen
20
Oct 23, 2015 01:50 PM
Clacor
Sep 11, 2015 08:36 PM
