Electrics Gurus!
Old Jul 20, 2003 | 02:12 AM
MAX-IMAL's Avatar
Respect Brotha!
Question Electrics Gurus!
Ok, I don't know if this is stupid or not but anyway what could cause a voltage regulator go bad ??? cuz i just bought an fd alternator and screwed up my voltage regulator, same what happen to my fc alterantor.
Thx
MAx.
Old Jul 20, 2003 | 09:03 AM
Fingers's Avatar
Wrong pulley would cause the alternator to overspin, and the regulator to be operating way too much. Could be excess water entering the electronics... could be even your belt slipping and you're just misdiagnosing... dunno... what makes you think the voltage regulator has gone south?
Old Jul 20, 2003 | 10:05 AM
Cwaters's Avatar
Just Messing About
Heat. It's an electronic gizmo and heat is the enemy. Buy a "lifetime" warrenty part and just resign yourself to chainging them out every so often.
Old Jul 20, 2003 | 10:55 AM
HAILERS's Avatar
HAILERS
Maybe if you've jumpered the car off, a diode in the alt has gone.
Or how about this. See what the alternator is really putting out. Put your meters pos lead on the alternators out put. Right on the nut that holds the wire down. Right there on the alternator itself. Neg on the battery neg post. Is there a signifficant difference b/t that voltage from putting the meter on the batterys positive post and meters neg on the battery neg????? If so, I'd suspect a bad connection at the battery cables.
Old Jul 20, 2003 | 10:58 AM
HAILERS's Avatar
HAILERS
Oh yes. When you put the key to ON, do the idiot lights all light up as they are supposed to???
Do you have the two small wires connected to the alternator?? Original plug?
Old Jul 20, 2003 | 03:02 PM
MAX-IMAL's Avatar
Respect Brotha!
Well about the pulley I put the one that i bought at Rx7.com same diameter size only but dual.
Old Jul 20, 2003 | 03:05 PM
MAX-IMAL's Avatar
Respect Brotha!
Yeah in the Fd one but not in the Fc alternator.
WANKfactor
Sep 29, 2015 01:14 PM
