6-speed in an FC..
Old Jun 4, 2003 | 10:10 PM
Rxmfn7's Avatar
Do a barrel roll!
6-speed in an FC..
I've been contemplating having my tranny rebuilt, and toying with the idea of having some different gears swapped in. I know it it possible to swap FB gears and miata gears into a N/A FC tranny. This got me thinking,.. the newer Miatas can come with an optional 6-speed. Would it be possible to swap these gears in, instead of the regular 5-speed gears? I was going to contact Rob at Pineapple, but thought Id ask first to see if anyone had any input. Thanks..
Old Jun 4, 2003 | 10:14 PM
Psychoblue23's Avatar
When you find out let me know. I am going to be in the process of gettin a new trany myself. This sounds lie a neat idea. Although wiht the lil power my car as 6th speed is overkill.
- James
Old Jun 4, 2003 | 10:16 PM
theonlygreat's Avatar
i couldn't really imagine having another gear to wrap to redline in my FC. lol. you can barely get all the way through second without exceeding the speed limit. but if it's geared closer than the stock 5 speed that would be awesome.
Old Jun 4, 2003 | 10:19 PM
Rxmfn7's Avatar
Do a barrel roll!
Im sure it is. I personally think the gearing is a tad high ,( well at least 4th and 5th) in a stock FC. It may be fine for turbos . but with less powerful N/As, it seems to stop pulling *good* after 100mph, about the top of 3rd. The regular 5-speed miata gears are closer ratios that the FC, so Id assume the 6-speed would be even better.
Old Jun 4, 2003 | 10:25 PM
Well depending on price, looks like you have might have found a nice lil project.
- James
Old Jun 4, 2003 | 10:28 PM
TonyTurboII's Avatar
Glock Lover
Ive heard the the miata 6 speeds are weak. I mean, they may be fine for a n/a, but I know id like 6 gears.
Old Jun 4, 2003 | 11:06 PM
T2felix's Avatar
no ****... i think i would like six gears as well.... let me know how it turns out.......
Old Jun 4, 2003 | 11:22 PM
Black13B's Avatar
In Full Autist Cosplay
i agree with tonyturboii..
anyone considered a mazda b-series pickup transmission? i started a thread about that a long time ago.. dont remember much of it though..
(i know its not a 6 speed) but the b-series pickup tranny would be excellent for accelleration right? and possibly a tad more durable than a stock FC tranny? comments anyone?
Old Jun 4, 2003 | 11:37 PM
Wormiez's Avatar
I remember Soul Assasin had a 6-Speed HKS tranny.
Check them out but I'm sure it won't be cheap.
Old Jun 4, 2003 | 11:40 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
HKS Manual Transmission
Gear Ratios: 1st 2.773; 2nd 1.984; 3rd 1.548; 4th 1.246; 5th 1.000
Price: $6357.00
I found the HKS five speed at CS not 6 but it looks to be better than stock ratios.
Santiago
Old Jun 5, 2003 | 12:05 AM
OC_'s Avatar
OC_
I'm bastardizing my car!
i wouldnt get the HKS anyway, i wold probably go with a Jerico and have 100000000 gears to chose from. They dont make a 6 speed that i know of, but who needs overdirve?
Old Jun 5, 2003 | 12:19 AM
Mayhaps it be possible to swap in the RX-8 6-speed into an FC? Who knows...? We might find out in a few months.
Old Jun 5, 2003 | 12:21 AM
andrewb70's Avatar
I am putting a 6 speed in my 1987 FC.
Andrew
Old Jun 5, 2003 | 02:43 AM
Fatty_FC3S's Avatar
The 6 speed miata trannies are plenty strong enough for and NA rotary. A local rotor truck runs the miata tranny with his 175hp NA motor and its so much fun with those close gear ratios. Only problem is that the miata tranny is a different length, so the shifter comes through at a different spot. Otherwise it bolts right up. Granted this was on a rotortruck, so making it fit is simply as cutting a new hole in the floor for the shifter to go through, then cover the old one. Hope that helps some!
Graham
Old Jun 5, 2003 | 02:45 AM
and to think some people say Miata's aren't good for anything, lol
Old Jun 5, 2003 | 03:44 AM
jacobcartmill's Avatar
just dont care.
a good friend of mine has a 91 miata and his gears are wayyy shorter than my series5 NA gears. he has that greddy 15g turbo kit and his gears may even be a little *too* short for that much power. his 1st gear is pretty much useless, but its geared just right for highway pulls and such.
i think the gears would be perfect for an FC.
Old Jun 5, 2003 | 03:59 AM
J-Rat's Avatar
Alcohol Fueled!
Yeah, 6-speed dogmission, sold it though.
Old Jun 5, 2003 | 04:45 AM
bingoboy's Avatar
Lava Surfer
didn't sean (scathcart) have a 6speed in his FC before he got rid of it? can't remember...
Old Jun 5, 2003 | 07:10 AM
Rxmfn7's Avatar
Do a barrel roll!
I emailed Pineapple, Ill let you guys know what he says.
Old Jun 5, 2003 | 07:18 AM
leatherseatcovers's Avatar
http://www.gurumotorsports.com/
These guys will build a dog engaged transmission using a TII case. Close ratio with 5th gear 1:1.
Old Jun 5, 2003 | 07:23 AM
Rxmfn7's Avatar
Do a barrel roll!
Well, my car is still street driven and on long trips sometimes, so I would still like an overdrive.
Old Jun 5, 2003 | 09:36 AM
projekt's Avatar
i'm pretty sure the 6 speed isn't an in house tranny. it's not made by mazda iirc. if it is, i'm wrong
Old Jun 5, 2003 | 12:27 PM
what is a dog engaged transmission?
damn, I should know these things.......I mean I work at a transmission shop
Old Jun 5, 2003 | 12:29 PM
projekt's Avatar
a straight cut gear box
Old Jun 5, 2003 | 12:43 PM
i dont think there is a point in spending that extra money!! wouldnt really ever use 6 gear
