Power FC no reading from boost sensor
Old May 14, 2003 | 09:33 PM
Rayman93RX7's Avatar
R.B. technologies
Unhappy no reading from boost sensor
Here is what happens
I plug in the boost sensor and the PFC just shows 4 black lines ( ---- ) for the boost reading, and the sensor shows 0.03 volts. If I unplug it I get a +1. somthing bar, and like 4.81 volts.
Did all the obious checks, looked at the wires, tested them, checked the hose going into the sensor, and I also tried another sensor with the same result.
I am guessing that maybe the PFC was setup for a GM 3bar sensor by the last owner since I bought it used. I don't have a datalogit yet, is there anyway to know if the car was set for a 3 bar with only the commander?
Anyone have any ideas at all?
thanks
Ray
PM me or
AIM -- RaymanGT500
e-mail -- RaymanGTO@comcast.net
Old May 14, 2003 | 09:37 PM
R.B. technologies
Old May 14, 2003 | 09:47 PM
Badog's Avatar
Yes, from the commander you can check it from the PIMS screen. Scale should be 35086 and 3947 for option 1.
Old May 15, 2003 | 02:39 PM
R.B. technologies
in the commander there is no PIMS screen, there is a PIM screen but all you can do is basic fuel correction for RMP and PIM volt. There is just a list of RPM / volts and then a 100% next to them. You must have to get the Datalogit to change the settings back to 35086, 3947. What do these # represent and do you know where they are entered in ?
Old May 16, 2003 | 07:00 PM
R.B. technologies
Skeese
65
Mar 28, 2017 03:30 PM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
