Reliability Mods - Opinions?
Old May 5, 2003 | 09:54 PM
Louis M's Avatar
Just wondering, I was looking over the reliability mods at Rob's site, and was curious if any of the products listed are either inadequate or there is a better product. Also, if I am missing anything, could you please correct me!
Product: Manufacturer
Catback Exhaust: HKS Hiper @ $340
Downpipe: HKS Downpipe @ $200
Boost Gauge: Autometer @ $58
Air Seperation Tank: RX7Trix @ $150
Vacuum Hoses: Hose Techniques @ $220
Front Anti-Roll Bar Mount: ??
Rubber Intake Hose Couplers: Is it included in Vacuum Hoses?
Air/Fuel Gauge: Autometer @ $65
Water Temperature Gauge: Autometer @ $65
Knock Sensor: J&S
Radiator: Fluidyne @ $470
Intercooler: HKS @ $1290
What are your opinions of these products? Thanks
Old May 5, 2003 | 10:05 PM
93BlackFD's Avatar
built my own engine
screw the knock sensor, get a Apex'i PFC
it includes knock sensor and retard unit, and will give you full diagnostics of your car
get off the friggin stock ECU as quick as possible
Old May 5, 2003 | 10:06 PM
Mahjik's Avatar
Mr. Links
Well, IMO, the A/F gauge is going to be pretty much useless you are also going to use a wideband O2 sensor.
Skip the FMIC unless you plan on upgrading your ECU at the same time.
Also skip the J&S Knock sensor for now.
The vacuum lines, don't worry about them unless you already have a boost problem. If you have a problem, then replace them otherwise, if it ain't broke, don't break it.
Good luck.
Old May 5, 2003 | 10:11 PM
keynote22's Avatar
for cat back it's personal pref on sound and size.
Down pipe best bets are m2 or petitt
boost gauge you can do better but it will cost a lot more. defi is a favorite
vacuum hose....support the forum vendors and buy the kit from them.
Antiroll bar mounts....racing beat sends new mounts with thier bar. you only need the brace for heavy racing/autocross
rubber intake hose...this is not a vacuum hose. These are intecooler interconnnects.
pass on the air/fuel and get a pfc and commander. you will need it if you plan to do all these mods
water temp is good one to have. defi makes a cool kit for all gauges
knock sensor...not sure on that one
radiator..koyo is also good
intercooler...depends on what kind you want. front mount, stock mount etc...
you can search each item on its own and find piles of info and opinions.
Old May 5, 2003 | 11:44 PM
DavidDeco's Avatar
I have more fun than you.
Good luck.
I agree here. I've had the 4 wire Greddy sensor which is as good a non-WB as you can get and quickly went to the FJO 5wire WB unit. You should skip the A/F meter at your level.
The J&S I haven't used but I would skip it as well. There are also issues with tuning with it because if you go to zero or sub-10 split with your timing as many do, this could cause some issues I've *heard* with the J&S since it will retard your timing on the leading only in the case of a "knock sense" and you may wind up with your trailing firing before. Do a Search for more info on this.
David
msilvia
164
Mar 8, 2020 08:00 PM
localized
Sep 15, 2015 08:23 PM
mulcryant
Sep 9, 2015 05:24 PM
