Got Cold Air? - I do! (Pics)
Old Apr 30, 2003 | 09:40 AM
Nick86's Avatar
Yup, still here
Thumbs up Got Cold Air? - I do! (Pics)
Well, this was a project that I've been half-heartedly working on while my car was in storage. Once it came out - I got to work. I wanted to have a true cold air system, so I came up with a way to draw cold air in from in front of the wheel - while still retaining my winshield washer system (more on that in a bit).
First thing was to remove the washer bottle, and cut a 3.5" hole in the metal under the stock air box. In that hole I put a 3" - 4" ID PVC reducer, and siliconed it in place:
1)
I then put a 45 degree bend on the other side, and extended the tube down beside the brake ducting. Here's a shot from the wheel well. You can see where the washer used to be (I'll explain in a bit).
2)
Now, to the enine bay. Using cardboard as a template, I contructed a box out of aluminum, and welded it all up. Once it was secured to the car I was able to properly cut out the AFM hole, as well as the inlet for the new cold air ducting. Once the AFM adapter was fitted with the K&N, it all lined up very nicely. Take a look:
3)
4)
5)
Here you can see down the tubing and actually see daylight at the end!
6)
In this pic the filter isn't actually where it is supposed to be - it's sticking up a bit more than it should. I will be putting some foam rubber on the hood to completely seal the box.
7)
Now, for the washer situation. I didn't want a ghetto install of the washer bottle, so I did some creative wiring. Because the car is a GXL, it came with headlight washers - and the resevoir was on the drivers side. Now, since I've used them a grand total of 3 times in 5 years, I decided that I could do without them. I rewired the pump (you can see the old connector in the second pic - the green wires are the new ones) so that the resevoir that used to be for the headlight washers now does the windshield. The only visual difference is that the washer tubes now go up the drivers side of the car instead of the passenger's side.
So in all, I have a new cold air intake, and all I had to give up was my seldom used headlight washers - I think I made the right choice. I hope you guys like it!
Old Apr 30, 2003 | 09:42 AM
Nick86's Avatar
Yup, still here
Dammit! why won't the pics work! I can email them to someone if they have a better host that I do!
Old Apr 30, 2003 | 10:16 AM
SureShot's Avatar
Seduced by the DARK SIDE
I can host them.
Mail to Bill.Branning@co.clay.fl.us
I am considering that same setup.
Old Apr 30, 2003 | 10:18 AM
damn!!! iw anted to see those pics
can you PM me wioth em or come up with a way for all of us to see em???
damn!!! i wanted to see those pics
try to get those up
im considering somethin similar
Old Apr 30, 2003 | 10:23 AM
projekt's Avatar
the fc has headlight washers?
Old Apr 30, 2003 | 10:27 AM
SureShot's Avatar
Here is the modified fog light & duct setup to supply ram air.
top
left
front
right
back
Old Apr 30, 2003 | 10:51 AM
Nick86's Avatar
Yup, still here
SureShot, I sent you the pics - Thanks!
The setup that you have there is for an S5 - right? The S4 brake ducts are quite different.
Old Apr 30, 2003 | 11:10 AM
SureShot's Avatar
Yes S5 -
I'm working on formatting your post.
Old Apr 30, 2003 | 11:20 AM
SureShot's Avatar
A repost of Nick's write up ---
1)
2))
3))
4))
5))
6))
7))
Old Apr 30, 2003 | 11:21 AM
SureShot's Avatar
Very nice workmanship...
Yea - I know - not everyone has a 21" monitor.
I'll reduce them later.
Old Apr 30, 2003 | 11:23 AM
Nick86's Avatar
Yup, still here
Thanks a lot SureShot!
Old Apr 30, 2003 | 11:30 AM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
That looks great. I can't wait till I get my AFM adapter.
BTW Nick86 what brand are those rotors? how much? how well do they work over stock?
Old Apr 30, 2003 | 11:34 AM
Rotary-Revolution's Avatar
Looks good
Old Apr 30, 2003 | 11:35 AM
KiyoKix's Avatar
13B N/A POWA!
So nick...what did you use to cut the hole in the car? VERY VERY VERY nice setup you have going on there btw.
Old Apr 30, 2003 | 11:37 AM
Nick86's Avatar
Yup, still here
The rotors are KVR. Because I picked them up from their manufacturig site, they were $91 CAD ($63.44 USD - they sell them for $106 USD on their site) each.
www.kvrperformance.com
To be honest I haven't even tried them yet. My Master cylinder finally gave out as I was bleeding the brakes, so the car is still stationary unti I properly bleed the MC and the rest of the system!
Old Apr 30, 2003 | 11:40 AM
Nick86's Avatar
Yup, still here
I borrowed a 3.5" OD metal hole saw (Looks like the ones for cutting holes for door *****) and just went at it. The metal there is actually really thin, so it took no time at all. I then put anti-corrosion coating on it, and sealed the whole thing with RTV silicone. (that's what all that orange crap is on the tube underneith!)
Thanks for the compliments!
Old Apr 30, 2003 | 11:42 AM
1987RX7guy's Avatar
What is the URL for the site? I am thinking about what brand to get for when I start the non "go-fast" mods. I like the brembos offered by the store but they are 120 each so I am not sure what the better deal would be.
What did you use to make the hole for the air duct?
Old Apr 30, 2003 | 11:51 AM
eViLRotor's Avatar
Brother of the Rotary
Nice Box!
Dude, I would never give up my headlight washers...
Old Apr 30, 2003 | 11:59 AM
KiyoKix's Avatar
13B N/A POWA!
Oh yea...I screw the headlight washers . And that's one pretty *** rotor!
Old Apr 30, 2003 | 12:32 PM
hey man--what are these headlight washers you speak of?? I have an S4 GXL as well, but I don't see anything like that on mine.
Old Apr 30, 2003 | 12:39 PM
Nick86's Avatar
Yup, still here
Go out to your car, and flip the lights up. Right in front of the lights there is a little spray nozzle (one on each light). These are controlled by a button on your headlight switch. Press it, and you get spray!
What usually happens is the switch blows, and is replaced with one out of a scrapped base model, so you don't get the switch at all.
The resevoir is on the drivers side under where the battery goes - it is much bigger than the window one (go figure), and the filler neck extends up by the battery.
Look at pic #7, you can see the filler by the battery.
Old Apr 30, 2003 | 12:48 PM
DC350's Avatar
Rotor Head
Damn thats a job well done!
Old Apr 30, 2003 | 02:09 PM
Barwick's Avatar
SCCA Rookie
Anyone else notice that the hole on the drivers side is MUCH bigger than the hole on the passenger side? That'd be a perfect place to put a cold air intake, except it's on the wrong side of the engine bay.
Old Apr 30, 2003 | 02:50 PM
Rxmfn7's Avatar
Do a barrel roll!
Looks very nice, Im thinking of a setup very similar to that, only I dont really want to use the brake ducting. Also, that headlight washer thing must have been an option, because my car doesnt have one, nor did any other FC ive ever seen in person, and more than a few have been GXLs.. Also, It appears that your AFM is upside down...I hear thats a no-no, might want to turn it back over. I have the same strut bar as you, only I painted mine balck..
