low booost
Old 04-19-03, 10:37 PM
Dalen's Avatar
low booost
hey.. my secondary boost is not running full.. its running very flat.. now i haven't got my DP on it.. but i was wondering if a clogged pre cat would cause this problem? or do you think its a vacuum hose.. because most of the time when i accelerate.. i get this high pitched whisling sound.. could taht be the heat shield? or is there a vacuum hose thats leaking which is causing both problems..? please help
Dalen
Old 04-20-03, 02:03 PM
Dalen's Avatar
no ones had this problem?
Old 04-20-03, 02:29 PM
Mr. Links
Mahjik's Avatar
Yes a clogged cat can cause boost problems. Simply searching for "clogged cat" would have brought you up many threads like the following:
https://www.rx7club.com/forum/showth...hreadid=117918
Without a reporting your boost pattern, it will be hard to diagnose.
As far as a whistling sound, it's extremely doubtful it's coming from a lose heat shield. A lose heat shield will be more a rattling sound, not a whistle.
Turblown
Vendor Classifieds
10-17-20 03:25 PM
Logan Reinisch
44
09-17-18 12:20 PM
Jmpabon93
09-30-15 04:57 PM
Quick Reply: low booost
