ECU codes on an S5
Old Apr 14, 2003 | 10:19 PM
Fingers's Avatar
ECU codes on an S5
K.. found tons of info for s4's... but how do you read codes for an s5?
Thanks
-Ross
Old Apr 14, 2003 | 10:31 PM
Scott 89t2's Avatar
SOLD THE RX-7!
http://www.1300cc.com/howto/how2/codes.html
Old Apr 14, 2003 | 10:53 PM
Fingers's Avatar
Am I like the only person in the world who can't see that site? it says page cannot be displayed
If someone could save the page and email it to me, that would be GREATLY appreciated.
rosrock@hotmail.com
Thanks guys!
-Ross
Old Apr 14, 2003 | 10:59 PM
Scott 89t2's Avatar
SOLD THE RX-7!
works fine...
All you need is a piece of wire, your car key, and the list of codes below.
Right beside the battery and the coil there should be a single green plug. Stick one end of the wire in there. Now ground the other end to the battery "-" or the frame. now stick the key in the ign. and turn it to "on" (not start!!). if you have codes stored, the check engine light should turn off for a few secs. then will come on and start flashing. if it's on for more then a sec. then that is a count of 10. If it is flashing fast that is a one. for examble the code #31 would be "---- ---- ---- -" then it will stop for a few secs, and repeat it (asuming only one code is stored) If more then one code is pressent, it will show the lowest # first. and display the rest in order.
Code# Input Device malfunction Fail-safe function
01 trailing ignition coil malfunction of spark plug, broken wire, short circuit Trailing side ignitions pulse cut
02 crank angle sensor (ne sensor) broken wire, short circuit fuel injection and ignition cut
03 crank angle sensor (g sensor) broken wire, short circuit fuel injection and ignition cut
05* knock sensor Broken wire, short circuit Ignition timming retarded
08 airflow meter (AFM) broken wire, short circuit basic fuel injection amount and fixed timing
09 water thermosensor broken wire, short circuit coolant temp fixed at 80 degrees C (176F)
10 intake air thermosensor (AFM) broken wire, short circuit intake air temp fixed at 20C (68F)
11 intake air thermosensor (engine) broken wire, short circuit intake air temp fixed at 20C (68F)
12 Throttle sensor (full range) broken wire, short circuit throttle valve opening angle signal fixed at 20%
13 pressure sensor (intake manifold) broken wire, short circuit intake pressure fixed at 760 mmHg (29.9 inhg)
14 atmospheric pressure sensor malfunctioning ECU at. Pressure fixed at 760 mmHg
15 oxygen sensor oxygen sensor output remains below 0.55v 80 sec. after F/B system operation beginning feedback system canceled(for EGI)
17 feedback system oxygen sensor output remains 0.55v 10 sec. after F/B system operation beginning feedback system canceled(for EGI)
18 throttle sensor (narrow range) broken wire, short circuit signal fixed at full open
20 metering oil pump position sensor broken wire, short circuit Mop fixed smallest open. basic fuel amount and timing fixed
27 metering oil pump (MOP) malfunctioning MOP, step motors, broken wire, short circuit, or malfunctioning ECU Mop fixed smallest open,basic fuel amount and timing fixed
37 metering oil pump (MOP) malfunctioning MOP, step motors, broken wire, short circuit, or malfunctioning ECU basic fuel amount and timing fixed
Code # Output device
25 solenoid valve (pressure regulator control (PRC))
26 step motor (MOP)
30 split air solenoid valve
31 solenoid valve (relief)
32 solenoid valve (switch)
33 port air solenoid valve
34 solenoid valve (bypass air control (bac))
38 solenoid valve (accelerated warm-up system)
40~ auxiliary port valve
41~ solenoid valve (variable dynamic effect intake control (vdi))
42* Duty solenoid (turbo boost pressure control)
51 fuel pump resistor relay
71 injector (front secondary)
73 injector (rear secondary)
after you get the codes out and fix the problem (or even before) you have to reset the ECU to get rid of them.
Just disconnect the Neg battery terminal for more then 5 secs. If the codes come back then you didn't fix the problem.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
ZacMan
Sep 19, 2015 09:20 PM
