where are the fuses for a 1988 s4???
Old 04-09-03, 05:03 AM
Newbie
rx7s41988's Avatar
hi does anyone out there knw where the in car fuses are for stuff like radio clock and stuff for a 1988 s4??
Old 04-09-03, 05:44 AM
Zoom Zoom Boom!
Dan H's Avatar
Not sure if the radio clock is one of the fuses but check for the small black fuse box along the right side when you pop open the hood. Just open up the little latch and voila!
Old 04-09-03, 05:52 AM
Zoom Zoom Boom!
Dan H's Avatar
Oh, I forgot to mention theres another fuse block around the dummy foot pedal. I'm not exactly sure about that one so hopefully somene else will reply...
Old 04-09-03, 08:18 AM
I'm a boost creep...
NZConvertible's Avatar
The fuse box you're looking for is in behind the plastic panel next to your right foot. Since yours will probably have Japanese text on the cover, you'll need this:
Good to see another Kiwi here.
Old 04-17-03, 09:30 AM
Resident Moonwalker
ViperKillerWannabe's Avatar
Would it be in the same place as a '90? And also, which one is for the power seatbelts?
Old 04-18-03, 06:24 AM
The S5 fuse box is in the same place. The two empty slots at the bottom of the fuse box in the diagram above are used for the fog lights and seatbelts on S5's.
Coochas
44
11-05-19 11:08 PM
yr6
10-04-15 12:23 PM
FC3S Timmy
16
10-03-15 01:08 AM
Quick Reply: where are the fuses for a 1988 s4???
