More turbo questions.
Putting together my turbo 12a setup and the 2.5 inch DP for the second gen turbo I picked up is 50 bucks cheaper than the 3. Question is am I going to be happy with that? How much of a power difference would there be from a 2.5 to a 3 inch exhaust.
Also, found cheap Holley Blue 14psi pumps. I assume that should be plenty for my turbo applications, especially since I only run at 3psi pressure right now.
Thanks for listening to my rambling and helping me out.
Ben
Ben
Yeah, a 14 PSI pump should be fine man. That leaves you plenty of room for when you hit boost and the RRFPR kicks in. Theres an 11 PSI difference, but just to be safe, I would go now more than 10. No need to max out the pump, you never know how inaccurate it can get up there at maximum flow
~T.J.
.~T.J.
Trending Topics
how much boost do you plan on this thing to run when it's tuned? you may need the 3" DP IMO for better boost. i dunno, when i do mine i'm using the 3". but i don't see it making allll that much difference. ok now i'm rambling
I have a 2.5 inch exhaust on my 13BT and it quite happily runs 12psi and sounds good too. I do plan to go to a 3 inch exhaust when funds allow, but it's fine as it is. I guess it depends on how much boost you wanna run and what kinda power levels you're aiming for.
Also, be aware that a S4 (and possibly S5) turbo may have boost creep issues with a 3 inch exhaust due to lower back pressure. Which do you have? And are you using the stock internal wastegate or external?
Hey pillage6, what makes you think your FPR is f--ked?. Im having the same problems with running out of petro at the end of second gear also. The funny thing is this Holley POS Blue pump and FPR is almost brand new!. Any ideas anyone?
Are you guys really sure a Holley blue is good enough for turbo?
When I was looking into turbo plans I was gonna run a Aeromotive high pressure pump.
I reall dont think its good for turbo,I might be wrong but recheck with someone who has a Turbo set up.
BTW I have a Holley blue and regulator on the car,I never had a problem.
Originally posted by TheTwinTurboRX-7
stock internal wastegate, low boost
5psi
5psi
Is the turbo S4 or S5? you can tell because the S4 has a single wastegate door and the S5 has dual doors. The S5 can therefore control boost better.
Am I missing something here?
I talked to a few people and they said when a fuel pump goes bad, it just quits, so I figured my regulator was bad.
I just replaced the filter not long ago, so I know that isn't clogged. I checked the vacuum line from the plenum to the regualtor, that isn't clogged.
Last night I bought a new gauge, sometimes it reads 4-5 lbs. and sometimes 1 lb.. My fuel trouble is getting worse, now I am running out of gas during regular driving sometimes.
it is a series four
already know that
spent more time on the second gen than the first, but thanks for the tip
port the wastegate, run a maunal boost controller
already know that
You won't need a boost controller at all to run 5 psi. A boost controller isn't going to turn the boost down any lower than what the wastegate actuator is set for. I think its like 5.5-6 psi on a S4, so good luck.
I think both the S4 and S5 wastegate actuators are both set to 5.5 psi, so you won't beable to go lower than this unless you get a different actuator. IIRC the S5 runs higher boost with help from a built in EBC that is suppose to keep the boost to 8psi.
Both S4 and S5 have creep problems with an open exhaust. For instance RB's full exhaust (3" until the y-pipe) on the TII claims to raise the boost to about 10-12 psi. This is due to boost creep, which is not good.
Simply put, boost creep means that your turbo system is out of control, which is dangerous and not optimal in any way.
Port those baby wastegates, then you can use the manual boost controller to turn up the boost when you feel like you are ready for it.
PLEASE LISTEN TO ME!!!!! the holley blue will not work for turbo!!!!! stop blaming the FMU!! the only way for a FMU to fail is for the diaphram to crack, or rupture, not raising the fuel pressure, a simple way to test your fmu is remove the boost sensing line, and turn on the fuel pump,if the FMU is bad it will leak gas!
you need a high pressure EFI style pump in order to have a blowthrough system that works properly, THATS THE BOTTOM LINE!!!!
You know, I didnt think the blue would work, I mean its like 110 GPH which is a lot of gas, but no pressure. Its a high volume pump, not high pressure. Youre gonna need high pressure and a decently high volume as well. I was going to use a stock GSL-SE fuel pump for my setup.
~T.J.
~T.J.
I just bought the GSL-SE pump for my blow through, I took Robert's advice.
After this weekend, I will let you know what happens. Right now I am running out of fuel at the end of second gear WOT.
Good choice! i know you'll be happy with it. hahahaha WOOOOOOOOOOO!!!!!!!!!!
