How to change WHEEL STUDS?
Old Aug 24, 2001 | 01:28 PM
ROSHX7's Avatar
Exclamation How to change WHEEL STUDS?
I need to replace some wheel studs (the screw that you bolt your wheels onto) on the back of my 87 TII, since a few have stripped threads. I got some new ones from Mazda, just want to know how the heck to put them in?
Old Aug 24, 2001 | 10:36 PM
FEDREX's Avatar
"Just Looking".......
Put 2 nuts on the stud. To unscrew, use wrench on inboard nut. The outer nut will act as a stop.
To install, tighten the outer most nut - the inboard nut will then act as a stop.
Old Aug 24, 2001 | 10:51 PM
Six Rotors's Avatar
Wow dangerous advice!The wheel studs are a press fit on FC hubs.You have to take the hub off and press them out and the new ones in,note the splines near the head of the stud.
Old Aug 25, 2001 | 08:56 AM
FEDREX's Avatar
6rotor thanks for the correction. I had heard somewhere that is a method used to remove studs; apparently not in this case.
PhillyFC
Aug 21, 2015 06:36 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
