BAD probs with new motor
Old Mar 12, 2003 | 07:11 PM
spoolin93r1's Avatar
Okay, just got new motor installed and started earlier. After fixing a minor fuel leak, it got it started and had some really bad issues with it. First off, my oil cooler line popped off, giving no oil to the motor at all. It made a really high pitched sound both times i started it. I started it twice because i thought i fixed the cooler line. The problem I'm most worried about is the fact that it jumped straight to 4k rpms and stayed there. I have a PFC and all block off plates installed, so no more double throttle or AWS. I need help asap, I wanna drive my car! If anyone has any ideas, please post asap or call me on my cell 812-528-3894, name's eric, thanks guys
Old Mar 12, 2003 | 07:16 PM
R Xplicit's Avatar
did you do the install in the reman/new engine?
Old Mar 12, 2003 | 07:18 PM
yes indeedy, i looked over everything multiple times and used the manual, just can't figure out the 4k idle and the loud screeching noise
Old Mar 12, 2003 | 07:24 PM
Trexthe3rd's Avatar
Check all the sensor input signal to the PFC, there may be a bad input signal used for idle adjust.
or
your air bleed screw could be way off.
Snook's Avatar
Tony Stewart Killer.
ttt
someone help out
Old Mar 12, 2003 | 07:25 PM
Trexthe3rd's Avatar
Where is the screeching noise comming from
Old Mar 12, 2003 | 07:34 PM
R Xplicit's Avatar
the idle can be worked out....well, that is, if it is acting like the aws system......does it come down after a quick click of the key or blip of the throttle?
Old Mar 12, 2003 | 07:47 PM
mjw's Avatar
mjw
Are you sure the high pitched squeal isn't coming from one of the belts or pulleys?
Old Mar 12, 2003 | 07:56 PM
well i checked the sensor voltages on the PFC while it was shut off, and the only one i was worried about was the Fuel one, it was stuck at 4.98 volts. but it wouldn't have nuthin to do with it, that's just the fuel temp sensor and i don't have one anymore, i have the rx7store fuel rail. i'm pretty sure the loud sound wasn't a belt, my friend said the sound was comin from the side by the turbos, but i dunno. i'm just sooo worried about the 4k idle, i can't figure it out
Old Mar 12, 2003 | 09:15 PM
okay, got an update. i got the oil cooler line to stay on, started it again, the rpm's stayed at a good level and the whine went away. the other oil cooler line popped off and then the rpm's shot up and the whine came back. i immediately shut it off as soon as i found out the oil was shootin out. would a lack of oil or oil pressure be causing the idle problems??
Old Mar 12, 2003 | 09:18 PM
Marshall's Avatar
No offense but why are oil lines popping off!?
Old Mar 12, 2003 | 09:31 PM
tk5dan's Avatar
lol serious, fasten them down or something. THey shouldn't be popping off like that....
Old Mar 12, 2003 | 09:34 PM
sacabon's Avatar
just curious where did you buy the engine?
Old Mar 12, 2003 | 10:17 PM
i finally got both the oil lines tight, to where they wouldn't pop off, they're a bitch. so basically, now everytime i start it, the rpm's automatically jump up, it makes a really loud screeching/whirring noise, and white smoke comes out of the engine bay.
the engine is from atkins (spare the flames). a guy at a local shop had it for his 7, but sold it to me cheap because his project was taking too long. i'm holding off on startin it any longer and callin all the shops in the morning
Old Mar 12, 2003 | 11:00 PM
turbojeff's Avatar
Do it right, do it once
Smoke from the engine bay...
Well it could be stuff burning off the turbos. It could be the belts like others have said (fits with the screeching).
For the idle, the AWS will give a 3K idle, 4K rpms would indicate that you might have a vacuum leak.
Since you put the motor in you should really look around at everything carefully before you start it again. Is the screeching noise a high pitched squeal or grinding scraping noise?
Jeff
Old Mar 13, 2003 | 01:56 AM
i tightened the belts and filled the power steering fluid and it still makes noise, i just can't figure it out. i have no more AWS or double throttle, i have all block off plates installed, no more solenoids, the rats nest is gone completely. my friend was watchin my fuel pressure gauge when it was runnin and said the gauge didn't move. the idle screws are fine, the butterflies are where they should be. i cranked the motor with the the fuses yanked so it wouldn't inject fuel or spark and the motor cranks over and sounds just fine, so i don't think anything internal is hurt. i'm at a total loss here
Old Mar 13, 2003 | 08:15 AM
Tim McCreary's Avatar
Did you replace the clips for the oil cooler lines? Did you damage them upon removal?
Make sure that the oil connections are corrected before attempting anything else.
Tim
Old Mar 13, 2003 | 09:18 AM
Trexthe3rd's Avatar
From your previous posts:
1. I'm not sure how the PFC controls the idle, but the stock ECU does in fact use the fuel temperature as part of the idle adjustment. (Trust me, I learned the hard way)
2. You mentioned that the idle was ok and the noise was gone after the oil line was re-attached, so are you or are you not still getting the same symptoms after the oil lines are properly installed.
Old Mar 13, 2003 | 02:47 PM
well i'm kinda screwed on the fuel temp sensor cuz the fuel rail has no place to put it. do u think that's what's doin it? i finally got the lines attached good, but it's still doin the same stuff. i seriously doubt it's anything internal making the noise, but can't figure out where it's coming from
Old Mar 13, 2003 | 09:44 PM
twokrx7's Avatar
Need more sleep
I posted before to someone else that had an upgraded fuel rail with no fuel temp sensor ... gotta do your research folks.
Change all your fuel temp corrections to be constant and install a resistor on the connector, or, change your temp corrections and install the original fuel temp sensor and leave it laying somewhere.
Old Mar 13, 2003 | 10:56 PM
You're the man, Kyle
Glad to see some new knowledgeable people on the forum.....
Old Mar 14, 2003 | 07:03 PM
not to sound like a total retard, but which temp corrections are you talking about? the only thing i can think of is the one that gives it a little extra fuel upon warmup, but that uses the water temp sensor, not the fuel, right? i only have the commander, not the datalogit. and also, would the fuel temp sensor cause the crappy idle prob?
cristoDathird
28
May 30, 2019 08:47 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
sYnth.
Aug 19, 2015 06:27 PM
JZW
20B Forum
Aug 18, 2015 08:56 PM
