Exhaust system ground wire, WTF?
Old Mar 11, 2003 | 06:03 PM
BlackSport0187's Avatar
Stay Tuned
Question Exhaust system ground wire, WTF?
There is a ground wire that goes from the body of the car (one of the exhaust hanger spots) to the muffler on the driver's side. What is it for?
I recently installed an Apexi GT-Spec cat-back exhaust system, and there is a bolt and hole in it that is designated for the ground wire. I assume this means that the ground is important.
Any ideas guys?
Isaac
Old Mar 11, 2003 | 06:13 PM
ORX705's Avatar
Cheese
i know my oxy sensor doesn't work if a ground isn't hooked up to the exh.
Old Mar 11, 2003 | 06:23 PM
gsracer's Avatar
EIT
I took off the grounding strap and made my own ground on the passenger side when I took off my stock catback and replaced it with the n1 single.
Old Mar 11, 2003 | 06:48 PM
GlenL's Avatar
WTF... when I replaced stock with RB complete, I didn't see any ground wires. I looked too, because the instructions said it would be there, but couldn't find it.
Old Mar 11, 2003 | 06:54 PM
RETed's Avatar
It's to minimize rusting to the exhaust system.
If your O2 sensor quits working after removing this wire, you're got bigger problems.
-Ted
Old Mar 11, 2003 | 07:15 PM
rotary>piston's Avatar
i just took that thing off. I didn't know it was important. Should I put a new one on? Or is it that important?
Old Mar 11, 2003 | 07:25 PM
seventhgear's Avatar
boost on the way(GTU II)
MINE HAS NEVER BEEN ON.... since i bought it
Old Mar 11, 2003 | 07:27 PM
Icemark's Avatar
ted is right, as well as it also helps avoid engine noise on the stereo from the static electric charge that can be created at the gaskets.
Old Mar 12, 2003 | 11:17 AM
Rpeck's Avatar
What R U thinking self?
Just put it on, it will make you sleep better at nite.
at least it did for me
I just tapped a couple of welds on my wire, but a large hose clamp out of site should be easy to do also.
Old Mar 12, 2003 | 01:02 PM
DAN CARWIN's Avatar
I thought that it had something to do with the exaust over heat on the idiot lights?
Old Mar 12, 2003 | 03:31 PM
rx_7_driver's Avatar
cut mine off last year hadn't had a problem since, exhaust was already rusty when i took it off
DAN CARWIN, i belive that sensor is under the passenger side seat
-Shawn
Old Mar 13, 2003 | 02:00 AM
Stay Tuned
Smile
Thanks guys! I feel enlightened.
Isaac
Old Mar 13, 2003 | 08:57 AM
LoSRx7's Avatar
Anyone have a picture of the 2 points of connection of that ground wire. Like where it attachs.
Thx.
LoS
Old Mar 28, 2003 | 09:13 PM
LoSRx7's Avatar
^bump
Old Mar 28, 2003 | 10:13 PM
Rx-7Blazin's Avatar
is this the wire behind the drivers side muffler?? if so i just thought it was a wire to prevent you exhaust from hitting the ground if it came loose
streetlegal?
Mar 17, 2022 02:46 PM
GrossPolluter
Aug 22, 2015 11:23 PM
PhillyFC
Aug 21, 2015 06:36 PM
