White Goop In Oil Filler Neck *pics*
Old Feb 18, 2003 | 06:27 PM
CowsniperRX7's Avatar
Rear Admiral
This has happened before. There is a slimy white goop in the oil filler neck. What is this? What causes this? Should I be worried about a blown engine?
Old Feb 18, 2003 | 06:57 PM
Marshall's Avatar
I think the white goo is an unknown entity but was decided to be normal.
Old Feb 18, 2003 | 06:58 PM
eric e's Avatar
just new to this forum and the rx7
but anything that looks like mayonaise in the oil is usually a mix of oil and water
the question is where is the water coming from?
if you are only driving short distances during winter then the moisture in the air drawn into the engine can be enough to cause minor amounts of white goo
and is why when for a few minutes after a car is started it will be blowing white steam and drops of water out the exhaust
however once the engine is up to temperatures above boiling point the moisture in the air will be boiled out and the oil should look clean, exhaust will also stop blowing steam as super heated water vapour can't be seen
SO, if you have a little mayo after a few weeks of short runs near freezing don't be worried
BUT, if you have lots of mayo there all the time, even after several drives of over half an hour, then you may have blown an O-ring
eric e
keep an eye on your coolant levels and the see if there is an oily film in your radiator water
Old Feb 18, 2003 | 09:51 PM
Mr rx-7 tt's Avatar
rotary sensei
It's condensation, it's normal don't worry about it..
Old Feb 18, 2003 | 10:05 PM
maxcooper's Avatar
WWFSMD
I used to get that stuff, and it does seem to be somewhat "normal". But I think it stopped when I switched to synthetic oil.
-Max
Old Feb 18, 2003 | 10:49 PM
yes it's a mix of something! don't worry it's not as bad as mine! mine's like a light light brown w/ this clumps mine's a really bad coolant mix =/
Old Feb 19, 2003 | 02:57 AM
reza's Avatar
take 1 part of oil and 1 part of water.
mix them with a mixer, then you will get butter.
reza
Old Feb 19, 2003 | 04:16 AM
BoostedRex's Avatar
NorCal 7's Co-founder
I agree, I had the same issues with my '93 Touring. Doesn't seem to be any problem at all and certainly no cause for worry. Laterz.
Zach
Old Feb 19, 2003 | 06:54 AM
xstacy7's Avatar
I love when things work
Never seen bright green vacuum hoses before...
Old Feb 19, 2003 | 02:48 PM
CrispyRX7's Avatar
Polishing Fiend
Emulsified oil. Condensation mixed with oil.
Crispy
-repeating what everyone else has just said ;-)
Old Feb 19, 2003 | 04:58 PM
Rear Admiral
They are yellow, the camera was messed up because it was so close.
Thanks for the help everyone!
NCross
Sep 3, 2015 03:42 PM
