Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
High-end ECU selection (yes, again...)
Old Feb 7, 2003 | 05:21 PM
hyperion's Avatar
Re-engineering everything
Hi all,
I've been looking over some of the ECU threads in the digest and I'd just like to get a read based on the most current information available. If you find a thread that I have missed that addresses my specific concerns, I would be grateful for a pointer.
I am considering an aftermarket EMS for my 94 FD. I have researched many of the players, but I lack some real-world knowledge with rotary applications. Here are the control units I have checked out:
Tier 1:
1) Pectel T6/T10
2) MoTeC M48/M800
3) EFI 1.9/2.1
4) Haltech E11
Tier 2:
1) DTA P8Pro
2) Apex'i Power FC
3) AEM EMS
4) Electromotive TEC3
Here are my requirements, roughly in order of importance:
1) can use factory harness for almost all input/output (I am willing to build my own harness adapter and add auxilary sensors)
2) can provide a 3D boost-corrected map (so that an EBC can be used safely and effectively)
3) it well-suited to rotor control (with variable timing split)
4) does not disable any of the factory functions that rely on the CPU (or as few as possible--I realize this is a bit unrealistic)
5) is altitude-correcting
6) can store multiple maps, preferably selectable from the cockpit
7) has usable datalogging
8) can be run in closed loop O2 on a per-rotor basis (multiple wideband Lambda)
9) has the potential for more closed-loop functions (trac ctrl, launch ctrl, anti-lag)
10) has output in "real" units (not voltages or some other value that must be translated on the fly)
I realize this is quite a load of information, and that any of the tier 1 controllers is probably capable of meeting my needs. I am more or less looking to hear your gut reaction as to which direction will be the path of least resistance for me. I have access to tuners for many of these systems, although the UK high-end stuff will be a bit problematic in that regard.
I am particularly interested in anyone who has had firsthand experience with the tier 1 stuff, especially Pectel, EFI, and MoTeC.
Thanks in advance for any help you can offer me,
-ch
Old Feb 7, 2003 | 05:31 PM
hyperion's Avatar
And I should have mentioned:
My usage for the car will be a mixture of track days and autocross, but it must also be able to run reliably on the street as well. You track-only nuts may now look down on me.
Thus, the system should perform well idling under high temps and with various accessories on/off.
Thanks again,
-ch
Old Feb 20, 2003 | 12:49 AM
T88NosRx7's Avatar
Halteck
Old Feb 20, 2003 | 02:35 AM
AnthonyNYC's Avatar
Stay tuned...
Choices
I think by just the closed loop option eliminates most of them. I assume you meant sort of a self tuning feature since you mentioned wide band.
For what you are asking, it sounds like the Power FC meets most of what you require...
Anthony
Old Feb 20, 2003 | 06:45 PM
kabooski's Avatar
Laying Down Rotary Law
AEM
remove your stock computer
Plug in the AEM Brain
set auto tune
and go.....................................
