need badly help please:(
Old Jan 31, 2003 | 04:33 PM
eddierotary's Avatar
back with rotaries
i finish my car today and i started it and the car start for 10 to 30 sec and die but doesnt unless you keep hitting the gas and start missfiring and now it have a loud noise that i dont know where it come but i dont think is the turbo. the turbo is getting oil. my A/F gauge reads betwen rich and stoich but when it dies goes too lean and sometime when i tap the gas it goes to lean. i havent drove it and i dont think im going too im worry about and i hope is theres a fix to it. any sugestion or gess of what could be? my setup is in my signature. thanks
Old Jan 31, 2003 | 06:36 PM
13bpower's Avatar
s4 for life
1. the A/F gauge won't give an acurate reading until the o2 sensor is warmed up to at least 600 F.
2. How does it run for the first 10-30 seconds that is runs by itself.
Vaccum leak, AFM, Compression???, Running really rich...
More info?
Old Jan 31, 2003 | 06:40 PM
Judge Ito's Avatar
Check your timing. Your crank angle sensor might be installed incorrect.
Old Jan 31, 2003 | 08:11 PM
back with rotaries
the first 10-30 sec runs by it self and idle about 1200rpm
but after that i have to give gas or dies. and i start giving gas and it start missfiring alot. and my A/F gauge said stoich- rich and i look back to the muffler menwhile i rev it and is like rich. only come like black smoke. i dont see any white or blue smoke. but like i said sometime my meter sometime read lean and when first i started it it foul my spark plug about 5 times and the it started to run the 10-30 sec running fine and die. by the way too, i have four gslse injectors but only two are working with the gslse computer, and distributor with 0 degree leading and i think 10 degree trailing and is not advancing. and i have the intercooler in the car but i didnt have enought pipe to finish so i too some PVC pipe and i skip the intercooler and send it strait to the manifold. does that will cause problem too? another thing the last time i try to keep it running, it make a loud noise, like it was locking or something and i check the turbo and it was ok. and i dont know. i hope is not a apex seal or something in the engine. and another thing how you can check if the BOV works? i think mine dont work but anyway it wasnt making boost. i hope theres a fix to it. i dont want to buy an engine now. thanks
Old Jan 31, 2003 | 09:14 PM
back with rotaries
well it doesnt sound like is locking but it make a loud skwel and i shut it of and didnt started after that.
Old Feb 1, 2003 | 01:02 AM
dcee's Avatar
what year AFM are you using? Also, what TPS?
Old Feb 1, 2003 | 09:40 AM
back with rotaries
most of the sensor is stock gslse sensor and the AFM, O2 sensor too, the only 2 sensor that i change was the air temp sensor that the original one broke and im using a 88 turbo II one and the TPS that is from a 88 turbo II.
Old Feb 1, 2003 | 09:47 AM
WTF
im pretty sure its a vaccum leak...mine did the same thing when i cracked my lower intake manifold. you should check every vaccum hose 3 times to to be sure
Old Feb 1, 2003 | 10:51 AM
back with rotaries
im going to check that today and do some other things too .
Old Feb 1, 2003 | 01:17 PM
back with rotaries
well i think i found the problem. the the gasket of the lower manifold to the engine didnt seal at all by the middle plate. why because there a mark of the exhaust port there, im still searching it looked like every thing else is ok. i hope is only that.
squirrels
Sep 1, 2024 09:52 AM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Jmpabon93
Sep 30, 2015 04:57 PM
