Dual Stock Fuel Pumps on tii?
Old Dec 1, 2002 | 11:44 PM
RexRyder's Avatar
Anyone ever done this before? Just 30 bucks more (for another fuel pump) and I can have more fuel output than a 255lph Walbro!!
Pics here: http://www.nopistons.com/forums/inde...=ST&f=9&t=9210
Old Dec 2, 2002 | 12:53 AM
jmseven's Avatar
Asset is Wealth
You can run them parallel, regulated by an FPR.
Old Dec 2, 2002 | 02:39 AM
jspecracer7's Avatar
1JZ powered
Just like the site say!...
Use a stock pump with the stock out fuel line in place. Attach a second pump next to where the stock return fuel line is and use that as the 2nd pump OUT fuel line. Put a 3/8 bulk head fitting on to the fuel pump assembly as the return.
Now use BOTH stock out and return fuel lines as OUT lines. Run one line to the primary rail. Run the other line to the secondary rail. Aeroquip Fuel pressure regulator allows for 2 IN's, so that will be your "Y". The Out goes to the 3/8 bulk head fitting you put on the fuel pump assembly for your return.
Get it!
Old Dec 2, 2002 | 04:30 AM
Bridgeported's Avatar
Do it up! I'm a fan of this modification because it gets the job you want done, and gets it done for a fraction of the price... it's what I'm all about (being i'm a broke *** student still)
Old Dec 2, 2002 | 06:35 AM
dvls-7's Avatar
Sick & Twisted
I have a 3rd gen pump in the car now but i still have the T2 pump i took out would i be able to use them both together? Also is there a complete write up or pics of this and what should be done about getting juice to the pumps?
Old Dec 2, 2002 | 11:08 AM
Jimmy325i's Avatar
No longer cares
Is the hole in the top of the tank big enough to drop two pumps through?
One drawback other than the increased current needed to run these things would also be the heat generated from two pumps going into the gas. Cold gas makes more power.
Old Dec 3, 2002 | 07:12 AM
dvls-7's Avatar
Sick & Twisted
immanuel__7
89
Sep 5, 2015 10:23 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
