Engine Building Tip
Old Dec 1, 2002 | 09:34 AM
rgordon1979's Avatar
LS what?
Engine Building Tip
I am in the process of rebuilding a '88 TII engine. In the process of finding a new rear rotor and housing I came across something I have never seen on here before.
As you know, Mazda balanced each rotor at the factory. Due to slight variations in the balancing process, each rotors weight varies slightly. Mazda designates this variation by stamping a letter, (A-E), on the gear side of the rotor. According to Mazda the rotor weight should not vary more than 2 letters in an engine. Ideally, you should have matching rotors. I did verify this with Henry at Mazdatrix. If this is common knowledge, sorry to take up the bandwidth, just wanted to let everyone know.
Rob
Old Dec 1, 2002 | 12:59 PM
diabolical1's Avatar
hey ... i never knew that, so you've educated at least one person. i noticed the letter before, but never gave them any thought further than the acknowledgement ...
thanks!
Old Dec 2, 2002 | 12:24 AM
Project84's Avatar
Open up! Search Warrant!
Make that 2. I never knew that either. I got rotors laying all over the place. I saw the letters, but I was more worried about the numbers for the side and apex seals. Thanks for the enlightenment.
Old Dec 2, 2002 | 01:15 PM
sunshine's Avatar
I'm #3
Old Dec 3, 2002 | 09:02 PM
LS what?
rotor weight
this does apply to the fb and fd as well.
Old Dec 3, 2002 | 09:57 PM
banzaitoyota's Avatar
What Subscription?
Thanks, my brain is full now!
Old Dec 5, 2002 | 01:21 PM
voodooracing's Avatar
Racing Beat provides a balancing service. If the engine should see very high rpm (over 8.5k) its worth the extra 700+ dollars...
Old Dec 10, 2002 | 08:30 PM
Wow. Now I've got the urge to open up my engine just to check it out.
Sort of ..... Not really ..... Maybe next time.
Thanks for the info.
Kace
Old Dec 13, 2002 | 07:59 PM
gamble302's Avatar
roadkill hats rock
even on 12a's?
thats good info
elfking
Aug 19, 2015 09:48 PM
