BIG 1600cc Primaries for Power FC????????
OK, here's the deal, I need to know if anyone has tried, or is using 1600cc injectors on the PRIMARIES with a Power FC. If you have tried it, please give let us know of the results and what the fuel pressure is at, injector ms, and how it is performing, especially at idle and regular driveability. As a side note this question is meant for people using a street type of port and idling at 900-1000rpms, anything more than that is not acceptable. Some of you may think that this is not needed, or it can't work, well I know of a some street/strip cars(real street cars, daily drivers, NOT trailer queens) using 1600cc primaries with NO problems of any kind(they all idle at 45psi fuel pressure, and about 900rpms, with the injector ms at about 1.7) BUT not one of them is using a Power FC, all of the guys I know have used either Wolf, Electromotive, or Haltech. I basically wanna know if anyone has done or tried it with a Power FC, and the specifics, thanks.
OK, so I found out the deal with my question above by myself, the PFC's minimum ms speed for the injectors is 2.3 so since 1600's idle somewhere at around 1.7ms, you can't use them in the primaries, the biggest size you could use in the primaries seems that it would be something like a 1000cc injector.
Skeese
65
Mar 28, 2017 03:30 PM
Coolant_Leak
Aug 30, 2015 11:18 AM
