Australian Jamboree Results!
Just thought I'd start a quick thread giving you all an update on the racing in Australia over the weekend.
The Jamboree is the biggest 4 Cylinder and Rotary drag meeting of the year.
Everyone was expecting the big hitters to come out and play, unfortunately this also meant a very large number of breakages and oildowns. I think partly due to everyone pushing pretty hard, and also the surface being relatively sticky. It was a pretty hot day (85 F) and there was a large crowd in attendance from all over Australia enjoying the sunshine (probably 15,000+)
The 20B rail of Corey Armstrong had a few dramas on it's pass but was quickest on the day, running a 7.7.
The Pac Performance RX-3 sedan came out and ran a very strong 7.88 at an amazing 179mph!
Impressive considering the aerodynamics of the car! This RX-3 does not have a "smooth" fibreglass front like a lot of the US cars that I saw, so we can expect big things from their MX-6 which is currently in the build.
Archie from Mazfix ran a strong first pass in his 20B powered 3rd Gen RX-7. It carried the front wheels a long way on the launch, but then the chute failed to deploy and then the brakes locked and the car touched the armco in the deepend after crossing the line with a low 8 second pass
Rotormaster came out for last pass of the night and ran through for a 7.86 @ 171 for a new PB (and quickest "doorslammer" of the night)
Bill Nabham from Mazsport came out and set a PB with an 8.25 @ 160 odd mph in his "Series 8" style RX-7.
Expect a full update with photos (and video) on www.fullboost.com.au soon
PS. (Oh and I ran a PB of 10.2 @ 133 in my little first gen RX-7)
(And didn't even break a stock Turbo II gearbox in the process!)
Impressive considering the aerodynamics of the car! This RX-3 does not have a "smooth" fibreglass front like a lot of the US cars that I saw, so we can expect big things from their MX-6 which is currently in the build.Archie from Mazfix ran a strong first pass in his 20B powered 3rd Gen RX-7. It carried the front wheels a long way on the launch, but then the chute failed to deploy and then the brakes locked and the car touched the armco in the deepend after crossing the line with a low 8 second pass
The Pac RX3 ran a fairly slow 60ft of 1.35. The car has run a 1.21 60ft and run 4.8 to half track at 150mph. On the 7.8 it went 5.0 to half track @ 145mph. This car will go alot quicker! The box is also a manual shift, no airshift.
Its also essential to note that this is a customers car, their own full chassis carbon fibre MX6 is yet to race
Angus ,glad to hear you guy's had a great time. Man congrats on that 10.2 on your sweet first gen. Hmm Steve did you go? that would be a nice Match race 2 street first gen's running similiar times and going for the fastest street Rx7 title.
Re: Australian Jamboree Results!
BTW Congrats Angus. Are you going for 9's on a t2 box?
-pete
Trending Topics
Yeah I raced, but the 2nd hand import box we stuffed in the car wasn't up to the gear shifts I tried to dish out. On my first pass I snapped the shifter and couldn't hit any gears, and the 2nd pass I couldn't hit any gears either.
Shifting normal is fine, but hard shifts its not into, so the box will get redone and we see what happens from there
Ito - Whats the quickest 1st gen on your side of the planet? What are Angus and I up against here??
Steve, you and Angus are right on point. We have a 12A first gen. running 10.10 a 1979 13B turbo on a holley carburador with a powerglide automatic tranny running 9.90, a 1985 Gsl-Se running 10.00 and one more running 10.10..all this cars are street legal. Complete interior, sound system and alot of boost
i was going to get a 2800lb billet press plate with a bonded and riveted clutch plate how does that sound. in the near future im putting a fmic in dont know how much hp that will give me, but the clutch should be alright??
Originally posted by david67
hey A777 you forgot to mention the unforgettable hook up by the Mazfix Cortina with the 13b (i think)
And yes it's a 13B turbo Cortina. Probably the most incredible launch I've ever seen... a must see.
A777 do you have any pics of your car? I would love to see them and a little more information on your car.
AJC13B and I were trying to line up for a match race but it was not to be
Steve didn't have as good a night as me, but I was a very happy guy after the 10.2
Re: Re: Australian Jamboree Results!
Originally posted by rpm_pwr
I saw that car this morning - it wasn't a touch - the shock tower has moved over for starters! They're still deciding what to do with it.
-pete
-pete
I assumed that after a low 8 @ 160mph one could assume that a touch would be a bit more than a touch
Thanks for the kind words though, and yes I may try for a 9 on a t2 box
Although Willowbank is closed for 6 weeks or so while they upgrade the walls and run-off area.
1985 Mazda RX-7 (Series III)
Engine: 13B turbo (Series V - 1990 - built in garage at home)
Gearbox: Turbo II Gearbox (Series V)
Turbo: Garret GTBB turbo
MoTeC ECU
26x8.5" slicks
10.2 @ 133mph
Best 60' of 1.36
