fmic, what kind of gains?
Old Sep 6, 2002 | 01:53 PM
Ryde _Or_Die's Avatar
I know, I know this is a general question that depends on alot. I am planning on buying the greddy 2 row fmic and wanted to know what to expect. I mean its a good amount of money. What kind of HP? Noticeable? Anyone dyno before and after? Thanks.
Old Sep 6, 2002 | 02:32 PM
Triangle Power's Avatar
Big Wankel
From what I've heard a front mount is good for anywhere from 20-30rwhp over the TMIC.
Makes me want one pretty bad!
I've heard nothing but good things about the GReddy.
-Seth
Old Sep 6, 2002 | 02:36 PM
DaleClark's Avatar
RX-7 Bad Ass
The first thing I noticed when going to a front-mount is the *increase* in throttle response - the car seems a lot snappier. Also, you know how fast the car feels in cold weather? Feels like that all the time with a front-mount.
A front mount also gives you some headroom to run more boost - up to 12psi on the stock turbo, if the fuel is there. At that pressure, the stock intercooler is just heating the crap out of the air and can't keep up.
Not to mention you don't have to pull that stupid intercooler off every time you want to do something to the car!
I'm 80% done with installing my Greddy intercooler, and it is quite a bit of work to install - there's a lot of cutting involved. But, it's all worth it when you see that giant, shiny bastard in the nose of your car!
Dale
Old Sep 6, 2002 | 02:37 PM
What all do you have to do to make it fit? I thought it just "bolted" on.
Old Sep 6, 2002 | 02:43 PM
DaleClark's Avatar
RX-7 Bad Ass
Well, it is pretty much a bolt-on, but any front mount requires some degree of cutting. Remember, our cars weren't designed to have an intercooler up front!
You have to cut a hole in the sheet metal under the passenger side headlight, and another just to the side of the battery tray.
You also have to trim the bottom off of the front bumper support and cut the brackets that hold the bumper support as well.
Check out http://www.2751engineering.com and look at the CYM T2. He has lots of high-res pics of the install.
BTW, both the old Greddy and HKS front-mount kits also require cutting to run the pipes.
Dale
Old Sep 6, 2002 | 02:47 PM
What kind of tools do you need(what size bits)? I should be able to get it done it a day right? Does it come with the blue couplers? Thanks.
Old Sep 6, 2002 | 02:58 PM
MtnRacer's Avatar
infini guru
How much lag increase is there with a front mount?
Steve
Old Sep 6, 2002 | 03:02 PM
I'm hoping none.
Old Sep 6, 2002 | 03:11 PM
DaleClark's Avatar
RX-7 Bad Ass
I used an air powered angle grinder to do most of my cutting . You are gonna be cutting sheet steel, so find something appropriate for what level of tools you have.
Yes, it does come with the couplers. It comes with EVERYTHING - all the silicone couplers, hose clamps, brackets, bolts, MASSIVE throttle body inlet, etc. The only thing that has to be done is adding a blow-off valve - there is no provision for one. Which is kinda cool, since you can custom put one on whereever you want.
I'd plan on spending a whole weekend on the install - it's a LOT of work.
Dale
Old Sep 6, 2002 | 03:12 PM
DaleClark's Avatar
RX-7 Bad Ass
Steve
If anything, it reduces lag! You guys have NO IDEA how bad the stock intercooler is - I was amazed when I upgraded mine!
Dale
Old Sep 6, 2002 | 03:13 PM
DomFD3S's Avatar
Mod Powers...gone!
This may sound stupid, but can I get the front mount as my first mod OR will it cause me to blow my motor (due to untuned ecu, etc.)?
Old Sep 6, 2002 | 03:16 PM
DaleClark's Avatar
RX-7 Bad Ass
It's really a pretty safe mod to do - I don't think it would be a bad first mod. It's an expensive first mod, though!
But, it's really hard to say for 100% sure - I don't know of anyone that's had JUST a front-mount.
Dale
Old Sep 6, 2002 | 03:25 PM
Evil Aviator's Avatar
Rotorhead
Re: fmic, what kind of gains?
It doesn't work like that. The intercooler will give different gains depending on your boost level, airflow rate, and ambient conditions. You need to ask the smart guys at GReddy support:
1) What is the approximate intercooler efficiency at 10mph ambient side face velocity with an engine producing (your estimated hp at the flywheel)?
2) What is the approximate intercooler assembly or core pressure drop at (your estimated hp at the flywheel) and (your estimated boost level)?
Of course, an airflow rate (cfm or ppm) would be more accurate than hp, but they should still be able to answer your questions based on hp.
Dale
So do I need to buy a universal BOV or can I buy a kit?
Old Sep 6, 2002 | 03:39 PM
DaleClark's Avatar
RX-7 Bad Ass
You need a universal - a kit will come with a pipe that goes from the turbo to the stock IC that you don't need.
Get a TurboXS BOV - they sound great, flow great, and are very reasonably priced. They also come with the flange. All you'd have to do is test fit the first pipe, figure out where you want the BOV, and take it to a welding shop to have them weld the flange on - should only cost a few bucks.
Dale
Old Sep 6, 2002 | 03:43 PM
Hmm wheres the best place to buy one? And which one? Oh and is there a "best" place to mount it?
Old Sep 6, 2002 | 04:04 PM
I was thinking I would have to cut some of the piping to make room for the bov, but I'd do it like this right?
Old Sep 6, 2002 | 05:24 PM
Rotorhead
Where to buy it and which one to buy are up to you. Note that a lot of the "race" BOV's tend to leak, and are not the best thing for the street.
The best place to mount it is either just after the turbo or just before the throttle body because these are the low-velocity/high-pressure points. If you retain the stock AFM, you should get a CBV (Compressor Bypass Valve), which is a BOV that feeds back to the turbo through an additional pipe to keep the correct air/fuel ratio. With the CBV, you may want to put it close to the turbo to reduce your tubing length. If you use an aftermarket EMS, then venting to the atmosphere is fine.
More info on CBV vs. BOV:
http://www.machvw.com/whatisblowva.html
Old Sep 6, 2002 | 05:34 PM
Well I'll be using an s-afc for a while. See the stuff that you are saying is kind of confusing. I'm not sure what exactly I'd need to do. I am planning on ordering the GReddy i/c and prolly either the turbo xs or blitz univerasal bov. Now installing the bov...I got no idea how.
Old Sep 6, 2002 | 05:52 PM
Would this bov work?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1854754127
Old Sep 7, 2002 | 07:38 AM
bump
Old Sep 7, 2002 | 08:01 AM
87GTR's Avatar
any bov will work you just need to weld the flange to your ic pipe so you can mount it.
Old Sep 7, 2002 | 08:04 AM
ALright, thanks. I have to have an aluminum flange for the greddy ic kit right? Oh and did you get my pm 87gtr?
Old Sep 7, 2002 | 08:49 AM
madaz07's Avatar
Pew Pew Pew
i want o get a fmic too as im running the stock top mount as well anyone got any ideas on hp gain on my car my mods are below
Old Sep 7, 2002 | 08:53 AM
Ya I would say your in desperate need of a fmic. 210hp@14psi? It should help alot.
