What is a map sensor?(location)
Old Aug 26, 2002 | 01:39 AM
faisalk's Avatar
I know its stupid but just wondering what is the function of a map sensor/boost sensor? Also what will happen if it goes bad or is disconnected?
Old Aug 26, 2002 | 04:49 AM
jspecracer7's Avatar
1JZ powered
Re: What is a map sensor?(location)
Map(Mass Air Pressure) sensor or commonly referred to as a boost sensor measures boost and sends a signal to the computer so that it can decide which part of the fuel/ignition map to go to. The ECU referrences boost and rpm's and takes the value within that map and applies it to the necessary injectors/ignition.
If you disconnect it, then your ECU will think that you have a steady air pressure(whatever it may be) and feed your engine the wrong amount of fuel and give it the wrong ignition timing.
Old Aug 26, 2002 | 06:40 AM
maxcooper's Avatar
WWFSMD
MAP = Manifold Absolute Pressure. It measures the pressure in the intake manifold relative to absolute vacuum (so the signal can be vacuum relative to the atmosphere).
Mass Air is a different sensor for a different fuel injection system, but the rest of the description was correct -- the ECU chooses a cell in the fuel map based on speed (RPM) and density (pressure and temperature) to decide how long to hold the injectors open.
-Max
Old Aug 26, 2002 | 06:42 AM
Dragon's Avatar
20B N/A Wide Body FC3S
location of the MAP sensor is directly behind the throttle body on the fire wall..
Old Aug 26, 2002 | 07:23 AM
1JZ powered
Thanks for the clarification Max.
1JZ powered
Nice drawing Chris. Looks like you took a crayon to it
Old Aug 26, 2002 | 07:38 AM
Dragon's Avatar
Actually I used the pencil option ...
Old Nov 14, 2002 | 09:51 AM
2manytickets's Avatar
where does the other end of the hose attach to?
Old Nov 14, 2002 | 11:11 AM
rxrotary2_7's Avatar
Old Nov 14, 2002 | 11:23 AM
Mahjik's Avatar
Mr. Links
UIM
Old Jul 12, 2003 | 04:30 PM
mr2loser's Avatar
in most cases when a MAP is left disconnected, the ECU goes into "limp home" mode. It knows that its 5V reference is not making it to the sensor and switches to said mode. It does not "believe" it is seeing any normal situation partly becuase there is no situation in which the ECU gets back 0 volts from the sensor.
It is bad to leave it disconnected though. It makes the car run super rich, as was mentioned, and the effects of that are well known.
greg
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Snook
Aug 15, 2015 08:18 AM
