how to test the engine?
you could remove the leading spark plugs and turn the flywheel or the main pulley by hand. If you hear 3 even "pssssshhh" sounds coming from each rotor, then the engine has some life left in it. If the "psssshhh" sounds are really weak, the engine sux. This is the poor mans compression test. You could also hook up a tranny and starter to the engine. By powering the starter, the engine will rotate and you can get a compression test with an actual gauge. Hope this helps.
so it's all together, starter, tranny, etc.... what should the compression be on each rotor?
