FD3S dyno run with basic mods
Old Jul 28, 2002 | 01:31 PM
Qball's Avatar
Comp Yellow Mica
-Stock Cat is in place
-No boost controller, stock ecu
-typical 70 something degree day in san diego
-10psi on primary turbo
-14psi spike at transition
-8psi all the way to redline after spike
-246hp SAE 252hp uncorrected
Old Jul 28, 2002 | 01:41 PM
Qball's Avatar
Comp Yellow Mica
A/F ratio
wideband lambda
stock ecu is more than rich enough with the mods.
it also compensates for the spike by dumping a huge amount of fuel during the 4500 rpm transition.
Greg's Avatar
not bad at all
Old Jul 28, 2002 | 01:46 PM
Street King's Avatar
*** Bless Texas!
Very Nice!
Old Jul 28, 2002 | 01:51 PM
Qball's Avatar
Comp Yellow Mica
another note. removing the two hks power flow filters and running without them yielded 2 extra hp.
Old Jul 28, 2002 | 09:47 PM
Badog's Avatar
Healthy!
PFC, HKS Twinpower, mid-pip/hi-flo cat, and FMIC away from 300+!
Old Jul 29, 2002 | 12:17 AM
Nathan Kwok's Avatar
Wow that is rich. A lot of evidence has been shown lately that aftermarket ecus aren't needed as soon as once thought as long as boost is controlled. Great run, that spike is crazy but seeing your A/F ratios I'm not as worried about a little spiking anymore.
Old Jul 29, 2002 | 12:24 AM
nitroracer's Avatar
Dub'N
qball: i told u takin them off would help...
Old Jul 29, 2002 | 04:25 PM
Wargasm's Avatar
Weird Cat Man
You have been added to my dyno info page:
http://www.catenet.net/dyno.php
You are the last car currently on the list... if you have any other info you'd like me to add, just PM me.
Thanks,
Brian
Old Sep 4, 2002 | 04:45 PM
Qball's Avatar
Comp Yellow Mica
because my mods list is growing. and some people are asking...
i made this dyno run with ONLY EXHAUST, DP, and INTAKE.
fuel pump, pfc, twinpower.. ETC were not on the car yet and i do not have a new dyno graph to show the addition of these mods.
thanks
Turblown
Aug 14, 2015 04:48 PM
Clacor
Aug 14, 2015 09:17 AM
