Help Identify this sound - Movie inside
Old Apr 12, 2009 | 10:15 PM
Radigash's Avatar
Recently a sound started usually only after just starting the car, I would drive up the road about 100m then the sound would start (at first it seemed like a slipping belt, squealing sound).
A few times after that it would happen at random times. Last night it got worse, still on and off but much more metallic sound and seems to be originating from the rear right of the engine, is it a turbo failing? It can occur: in or out of gear, at idle and at load.
http://picasaweb.google.com/misterdo...41741004128450
Any ideas would be great, thanks.
Old Apr 13, 2009 | 12:14 AM
Radigash's Avatar
here are some more movies located in my album
http://picasaweb.google.com/misterdo...xplodingcar02#
Old Apr 13, 2009 | 01:54 AM
FDeez's Avatar
My guess is that your wastegate rod might be loose. If that's the case, your wastegate flapper door will be flapping around. You can jack up your car and take a look. You can see the wastegate rods in the thread below.
https://www.rx7club.com/west-sale-wanted-classifieds-195/fs-knightsports-rf420-twin-turbos-viton-hose-kit-ceramic-manifold-orc-clutch-832546/
Old Apr 13, 2009 | 10:09 AM
catch-22's Avatar
lol you got birdz!!! jk do you have a pfc because it will make your IAC valve sound like its squealing sometimes.
Old Apr 13, 2009 | 11:09 AM
apeiron
Do this as a preliminary test for me. Loosen the tension pulley with a 10 mm socket wrench and remove the belt that goes to the power steering and a/c.
Start the engine up and let it run without that belt and let me know if the symptoms persist.
Old Apr 13, 2009 | 05:46 PM
ChrisSRT4's Avatar
I agree with Spoolage. Sounds like a belt slipping. Or birds... ( c:
lordderak
Sep 19, 2015 12:14 PM
RyanFox
Sep 18, 2015 09:09 PM
