What kind of oil you guys use?
Old Jan 16, 2008 | 08:53 PM
Nemesis1705's Avatar
AL What kind of oil you guys use?
I was wanting some info on doing an oil change. Ive worked on for a few years now but never an RX7. Im actually a mechanic on Army Tanks for the military, I didnt want to start off on the wrong foot trying to change my oil. Also wanted to info on what kind of oil to use. I called Pettit Racing today cause their the ones who built my motor and I wanna say they told me to run 20 50 but I cant remember I was on my cell so it wasnt totally clear. Just wanted to see what everyones input is. Thanks.
Old Jan 16, 2008 | 09:16 PM
2FAST7S's Avatar
this is one of those questions that depend on who you ask...
I myself have used Mobil 1 synthetic 20/50 for a few years no problem. Actually when I switch to it, the engine did feel a little smoother and it even picked up a full inch of vaccum.
I just finished putting my engine together and for the first start up I'm using Mobil non synthetic 10/30 but I will be switching to a heavier oil later on after break in.
Old Jan 16, 2008 | 09:22 PM
Carpenter's Avatar
T67, did I say 7?
I would call Pettit again, since they put it together.
Old Jan 16, 2008 | 09:26 PM
How hard is it to change? Is similar to any other car or is it different?
Old Jan 16, 2008 | 09:34 PM
Carpenter's Avatar
T67, did I say 7?
Just like any other car. Drain plug under the car, oil filter, in back, on top right (looking from the front of the car in).
Old Jan 16, 2008 | 09:54 PM
Thanks Bro.
Old Jan 16, 2008 | 10:17 PM
Manny, I wouldnt break the motor on in synth. Use regular oil, then switch to synth after the breakin period.
I use Idemitsu oil, you can get it from rx7.com, it's on their website. It's not cheap, so daily driver guys should probably choose something else.
Old Jan 17, 2008 | 08:14 PM
Carpenter's Avatar
T67, did I say 7?
Did you call Pettit today? If yes, whats the oil?
Old Jan 17, 2008 | 08:33 PM
RX7LINK's Avatar
RX7FD3S
i use valvoline racing 20-50 all year round. oil change every 1500 miles
Old Jan 17, 2008 | 08:45 PM
1QWIK7's Avatar
White chicks > *
I use your basic, off the shelf at any store valvoline 10w-30. The white bottle with the blue label.
I might switch to something really good by summer, prob idemitsu like someone mentioned. See how that goes.
Old Jan 17, 2008 | 08:47 PM
rotarymandan's Avatar
packin' heat
I tried 10-30 but my oil pressure dropped below the FSM recommended 50 psi at 3000, so I went with Mobil 1 15-50 Synthetic. It works great!
Old Jan 17, 2008 | 08:55 PM
Carpenter's Avatar
T67, did I say 7?
I have been using Valvoline 10w-30 for 9 years now. Not sure what I'm going to use, once I get the car back after the single turbo conversion.
Old Jan 17, 2008 | 09:00 PM
MAZDASPEED08's Avatar
royal purpule 10w-30 A+
Old Jan 17, 2008 | 09:08 PM
rearviewmirror's Avatar
I like lighter weight oils. See the link in my sig to see the reasoning behind that.
Old Jan 17, 2008 | 09:51 PM
cewrx7r1's Avatar
Eye In The Sky
Time for the newb to download the manuals from this forum, read them, and get over his FOTU.
Old Jan 18, 2008 | 10:29 AM
JConn2299's Avatar
reliable performance
Finally! some sophisticated scienctific thinking applied to this endless debate. Thanks for your post. I've read substantially the same thing from other sources. The number of backyard engineers who routinely dismiss the recommendations in the owner's manual never ceases to amaze. Everyone with an interest in this topic should read the article to which you've linked.
Old Jan 18, 2008 | 11:46 AM
Pettit recommended 20 50 for their motors unless its real cold where you live.
Old Jan 18, 2008 | 11:25 PM
turbojeff's Avatar
Do it right, do it once
20-50 is the way to go.
10-30 is recommended by the manual but the FD gets fuel dilution which pretty much makes 10-30 look like water. I would avoid it unless I was driving in very cold temps.
Old Jan 18, 2008 | 11:28 PM
turbojeff's Avatar
I just lightly skimmed over the article, it seems like a great read. Please remember the fuel dilution issue that affects turbo rotaries.
I had my oil tested 4 times at Southwest Spectro Chemical in my FD starting in 1998 when the car only had 36k miles or so. I changed the oil every 1500-2000 miles and it always came back with 10% fuel dilution.
Old Jan 18, 2008 | 11:37 PM
KaiFD3S's Avatar
SINFUL7
20-50 here too and I am in Alaska...
Old Jan 18, 2008 | 11:40 PM
Chris and Ari over at rx7.com/RP always maintained that it's best to run 20w50 in warmer climates to help protect the bearings under high rpm use.
Old Jan 19, 2008 | 06:40 PM
JConn2299's Avatar
....and what, the engineers who designed the car didn't know about fuel dilution in rotary engines?! LOL! Read the article linked above by rearviewmirror and learn something.
Old Jan 19, 2008 | 10:44 PM
I skimmed through the oil article linked a while ago. It doesnt seem to be rotary specific......in warmer weather, I most definitely will not run 10w30 oil in my FD. To each their own
Edit: Also, the manual is aimed at stock, 255 hp FDs, and I highly doubt the engineers who designed the car envisioned FDs with double the stock horsepower routinely touching the redline
Old Jan 20, 2008 | 01:47 AM
Kento's Avatar
2/4 wheel cornering fiend
Yep, the same engineers who failed to foresee engine heat causing coolant hoses to burst and cause an engine fire hazard, or heat degradation effect on the rat's nest hoses, etc...no one's perfect.
The long Ferrarichat forum post's basic premise is that it's better to use 0W multigrade oils in cars with manufacturer recommendations of 5W or 10W. I would tend to view that as "dismissing the recommendations in the owner's manual"...
While there is a lot of good info in the ferrarichat forum gentleman's long post, he does gloss over the fact that motor oil and its applications to various engines is an extremely complicated subject, one that can't be covered with in a lengthy posting that tends to impress with tons of viscosity measurement results. (I also take issue with his assertion that the API SM grade oils are automatically superior to previous API grades-- the increased cam lifter wear that many classic hotrod builders were seeing with off-the-shelf API SL oils comes to mind-- but no reason to belabor this subject).
There's no doubt that rotaries' fuel dilution is far greater than that encountered in piston engines', and piston engines don't have internal stationary gears (responsible for transferring power) that shear on the motor oil molecules in a way that cams/lifters can't approach. There's too many variables to draw conclusions based simply on some research made with regards to conventional piston engines.
Old Jan 20, 2008 | 02:30 AM
dhays's Avatar
For a novice such as myself, this question about what oil to use is just plain confusing. The issue of fuel dilution is the one that has me worried. I know that atkinsrotary recommends on their website the use of 5W-30 or 10W-30 in the winter and 20W-50 in the summer. Of course, Atkins is located just a few miles from me. Both our winters and summers are mild. Cold here is typically in the 30's and Hot is only in the 80's, and that is rare.
The very experienced rotary mechanic I had check out my FD used 10W-30 Quaker State. When I changed my oil again after taking out a Greddy Oil Filter relocation kit I used Penzoil 5W-30. Come springtime, I'm considering changing out to a synthetic. The question is what weight to use at that time. 20W-50 seems pretty thick when the typical temperatures are still going to be in the 60-70's even in the warm months.
Thoughts?
