Flame exhaust
Old Dec 26, 2005 | 01:19 PM
ProjectRE's Avatar
Flame exhaust
Originally Posted by ViperDude152
start your motor. then disconnect the spark wires from the rear rotor. Go drive around with someone behind you vide taping. you have have flames ever damn second. big small and HUGE LOUD ones. I wish i had a video. Flames from a blown motor
https://www.rx7club.com/rx-7-audio-visual-lounge-143/my-na-flame-video-493505/
i want to know?
1. disconnect the spark wires 1 or 2 wires from the rear housing
2. by doing that does it kill the engine?
3. can i make a switch in the car on/off spark?how?
Old Dec 26, 2005 | 01:21 PM
J-Rat's Avatar
Alcohol Fueled!
Why? Are flames that important that you would go through these possibly engine damaging steps to get them?
RotaryEvolution's Avatar
Sharp Claws
your engine is just rebuilt and you want to do this ricer bullshit?
come on man...
Old Dec 26, 2005 | 01:23 PM
Nismo Convert86's Avatar
400WHP or bust
This Just In, Don't Listen To That Kid.
Old Dec 26, 2005 | 01:29 PM
ProjectRE's Avatar
That doesn't answer me anything? well?
rice or not rice i just want to know
Old Dec 26, 2005 | 01:34 PM
Sharp Claws
rotary engines are delicate to tuning so even a single detonation under boost can kill the motor, i will not help you destroy an engine and the responses so far speak for themselves.
maybe vipers didn't have an issue but that doesn't mean you might not. i would never try something like this on a new engine.
Old Dec 26, 2005 | 01:37 PM
Jager's Avatar
Tear you apart
Don't do that to your car. Add on a straight pipe and drive around. You'll pop plenty of flames then.
Don't listen to ViperDude, he's a n00b.
Old Dec 26, 2005 | 01:38 PM
J-Rat's Avatar
Alcohol Fueled!
I'm with Karack on this one, I refuse to assist you in what might inevitably cause the death of your motor.
Old Dec 26, 2005 | 01:45 PM
CoRDiTe's Avatar
Dude why dont you just try adding a spark plug to the tip of your exhaust with it hooked up to your battery, I heard that works. Better than trying to ruin your motor. Flamming isnt so special, I had flames comming from my FC because it wasn't perfectly tuned and it isnt a pretty picture because you spend more time and money trying to fix the problem. And I didnt even want flames, The flames came out because my NGK sparks (dont know how) but the tips blew open. so put it this way, a $7.00 part caused over $70 dollars to fix. neways just go by a flame kit.
Old Dec 26, 2005 | 01:47 PM
J-Rat's Avatar
Alcohol Fueled!
Here j00 go man! uber JDM Autolock flamer kit!
http://www.thehoffmangroup.com/Autol...o?refid=GOOGLE
Flame on dog!!!!
Old Dec 26, 2005 | 02:08 PM
ViperDude152's Avatar
Rotary Power Information
Let me just say, I was kidding. I said it because when my rear rotor blew it was shotting flames every second because all that unburnt fuel was getting into the exhaust.
Now because the plugs arnt firing I cant see why it would be horrible for the engine. Carbon build up wont happen. But you could flood it out causing gas to get into the oil if your side seals and oil seals let the fuel pass by. You also will be causing alot more vibration then there should be which could wear your bearings more then you woud like. I would not do this.
its not a ricer thing to do. Ricer is buying a flame kit. Just wanting to see flames coming out of your exhaust for a few seconds is not rice.
you say this on what grounds? my post count? dont let it fool you. I know more then you think. I was kidding about the whole thing. I have worked on rotaries for many many many years.
Old Dec 26, 2005 | 02:09 PM
400WHP or bust
Yeah because KIDDING on the INTERNET works well Why do you think you know so much, it was proven on Teamfc3s that you dont, and you no longer post there.
Old Dec 26, 2005 | 02:12 PM
ForsakenRX7's Avatar
zoom zoom go boom
No ****. DO NOT disconnect the spark plug wires. Its the retarded equivalent to turning off a car with a piston motor running down the road and then turning it back on to make it backfire. Fun for the moment, damaging in the long run.
Old Dec 26, 2005 | 02:13 PM
A **** load of members on teamfc have thanked me for getting their engines running. I saw no help from you in any post. mostly sarcasum. And how was it proven on teamfc that i knew nothing? nothing was proven.
totallimmortal's Avatar
Is that thing Turbo?
hmm sounds like a bad idea, i 'd say if you wanna see some flames just get an safc and run it rich still not a gereat idean but better than the other i'd think, but i dunno my rx7 throws flames on its own i don't need any tricks
Old Dec 26, 2005 | 02:14 PM
Jager's Avatar
Tear you apart
We don't know if you're sarcastic or not. So don't post stupid **** like that Mr. Ubermechanic.
Old Dec 26, 2005 | 02:16 PM
400WHP or bust
Yeah because adjusting timing makes the engine run more rich, or more lean.
It allows the fuel to burn more effeicently, and completely, not adding more fuel or less.
So many many many years would be 3 years? Have you ever rebuilt one? Ported one? Untill you have and made it last with your super dooper smarts, I have no respect for you or anything you say. The only thing you do to help people get their cars running is post common probs and it fixes it, they are too noobish to search. The rest of us get sick and tired of the posts, whiile you seem to thrive.
Old Dec 26, 2005 | 02:19 PM
if someone is stupid enough to do what i was kiddin about? Then they shouldnt have a rotary.
Wow the professional mechanics come out very quickly on this forum.
Old Dec 26, 2005 | 02:21 PM
Jager's Avatar
Tear you apart
I'm not a mechanic .
Posting misinformation is against the rules. I suggest you read them and not wreck someones engine.
Old Dec 26, 2005 | 02:23 PM
You really have no idea what your talkin about. I have rebuilt 2 different engines. One turbo and one n/a. The n/a I ported and is making 194rwhp with a s5 intake and a true CAI with 2.5" exhaust. My next n/a will be b-ported.
Old Dec 26, 2005 | 02:31 PM
400WHP or bust
Thats why I asked, because I didn't know that you did, I have never seen pics, or anything, most people take pics of the motors they port, but I still don't won't listen to you, wheres the dyno of the car?!?! I kinda want to see this.
I guess as long as no one lets you tune their SAFC, or EMS, they should be ok, the motor should hold up.
Old Dec 26, 2005 | 04:11 PM
nopistons13's Avatar
Getting back on topic, all I did was remove emissions, and just blockoff plates and i shoot flames all the time. Actually, it gets old pretty fast. But whatever, it's your car.
Old Dec 26, 2005 | 09:08 PM
You wernt really asking. You were being an ******* and trying to prove somthing that you can't.
Why should I let everyone know about my engines? Non of you want to know anyways. And how do you think im controling the fuel on the n/a engine? By an SAFC2. I used a wideband to tune it. Engine has just over 12K miles on it and still runs strong. The owner is waiting to get it on a dyno since its now parked for the winter.
Old Dec 26, 2005 | 09:40 PM
FC3sinfiniIII's Avatar
JRLT'specs* White Comet
I'm sorry dude but you are doing is wrong, plus is your rx is setup to pop flame when it run rich, that's cool just like mine in every single shift of gear. picture
Attached Thumbnails Flame exhaust-fc-popping-while-driving.jpg   Flame exhaust-fc-popping-while-driving-2.jpg   Flame exhaust-fcshooting.jpg
Ian_D
Sep 6, 2015 10:38 PM
doritoloco
Sep 5, 2015 12:41 PM
FührerTüner
Sep 4, 2015 01:41 PM
