12A in an FC?
Old Jan 29, 2005 | 10:37 PM
rotarynemesis's Avatar
FD Maniac
12A in an FC?
Has anyone done this? Will it just bolt in or do I need custom mounts? Want to have a carb and not efi and a carb 13b sounds like a pain so why not a 12a. Will it work?
Old Jan 29, 2005 | 11:06 PM
RETed's Avatar
Why are you looking to go backwards?
-Ted
Old Jan 29, 2005 | 11:47 PM
NZConvertible's Avatar
I'm a boost creep...
Why would you want a smaller engine?
Why would you want an older engine?
Why would you want an inferior fuel system?
Why would a carb'd 12A be any less of a pain the a carb'd 13B?
WHY?!
Old Jan 30, 2005 | 08:36 AM
FD Maniac
because its cheaper to do.
could i just take a t2 engine and put a carb on it and run it? probably not I would have to get a custom intake manifold and have the injector ports welded over so theres not just a hole there.
so will it bolt in?
Old Jan 30, 2005 | 08:47 AM
SonicRaT's Avatar
Super Raterhater
cheaper? In what sense? Going stock EFI would be the cheapest route.
Old Jan 30, 2005 | 09:01 AM
lemonade's Avatar
You can choose this?
your car would be so slow with a 100 HP 12a. you dont need custom intake manifolds to do a 13b. say you went my route, you need the upper intake manifold that matches the car, and a gsl-se lower intake to bolt up to the 13b. with a TII block i dont know what you'd do. its simple with a 6 port
Old Jan 30, 2005 | 09:57 AM
Dan H's Avatar
Zoom Zoom Boom!
so will it bolt in?
Its not cheaper at all. How are you going to setup the motor mounts? The 12A has a motor mount bracket on the front cover in my 1st gen. Even if you put a carb on a T2, the compression ratio is pretty low too. Not to mention changing over to a different fuel setup for the carb.
A 12A will also develop much less torque than the 13B and with a carb setup, will be more finicky than the stock EFI.
God, sometimes I wonder about some people...
Old Jan 30, 2005 | 10:08 AM
Aaron Cake's Avatar
Engine, Not Motor
No, it will not bolt directly in. You'll have to fab a motor mount as the 12A mounts at the front cover. Due to the location of the FC subframe, a new oil pan is required.
Also, swapping to carb means swapping the fuel pump, pressure regulator, a significant amount of rewiring, conversion to distributer, etc.
All this for a 105 HP engine?
Old Jan 30, 2005 | 10:19 AM
Turbo II-FB's Avatar
wow this thread just made me dumber
Old Jan 30, 2005 | 04:15 PM
so will it bolt in?
No, no and no.
Old Jan 30, 2005 | 04:20 PM
Gregs's Avatar
101 actually
Old Jan 30, 2005 | 04:21 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
Not easily.
If you just want to makeit go cheaply or something? you can find a used 13B EFI for cheap.
or hell, spend $300 on mounts and find a v6 out of a mid 80's GM and throw that in, it'll be faster than the 12a and probably better on gas.
Old Jan 30, 2005 | 04:28 PM
rxtasy3's Avatar
something that hasn't been asked yet: what's wrong with the 13b that's already in it?
Old Jan 30, 2005 | 05:10 PM
damn, if he wants to do it let him do it, christ
sure are alot of 12a haters here too :P
<edit> signature removed for violation of forum rules
Old Jan 30, 2005 | 05:11 PM
Dan H's Avatar
Zoom Zoom Boom!
Well, ask yourself this, would you put a 10A engine in your FB even though it costs more to put in?
Old Jan 30, 2005 | 05:13 PM
No, but it's not my car we are talking about.... he could put a damn hamster cage in it for all I care.
Instead of bashing him for wanting to try something out, how about some helpful advice.
Old Jan 30, 2005 | 05:16 PM
Dan H's Avatar
Zoom Zoom Boom!
We ARE offering him helpful advice.
He can stick with his original 13B because it will be cheaper, faster, and run better. Giving him bad advice will be telling him to go ahead with the 12A even though it will cost more, will have less torque/horsepower, and will be a more difficult conversion.
Old Jan 30, 2005 | 05:18 PM
nvm, apparently you arent getting my point here :p
Old Jan 30, 2005 | 06:55 PM
RETed's Avatar
Apparently, you're not getting what the majority of us are trying to say.
The 12A install is going to cost MORE money.
This is NOT a matter of swapping out engine mounts - the 12A is SHORTER, so the dimensions are not the same.
This means even though you line everything up with an oil pan and front cover, it does NOT line-up with the stock FC3S engine mounts on the engine subframe in the engine bay.
This means you need to CUSTOM something.
I am not aware of anyone offerings 12A to FC3S engine mounts, so this needs to be CUSTOM made.
CUSTOM MADE usually means EXPENSIVE.
Engine swaps - V8's, SR20, Supra, etc. - are usually about putting something that produces AS MUCH or MORE power than the stock engine that is in there now.
A 12A does NOT make more power over a 13B with similar porting.
So, it is NOT about not being helpful.
It's about trying to prevent the original owner from making a very costly mistake.
If you are really stubborn about doing this, then by all means go for it.
This forum is all about giving opinions and giving advice.
WE ARE GIVING ADVICE.
Don't be telling us NOT to give advice.
At least WE'RE trying to help the guy.
All I see you doing is telling us we're not being helpful.
The ironic thing is you're basically telling us NOT to help.
-Ted
Old Jan 30, 2005 | 07:19 PM
That's a really stupid thing to say. Nobody here "hates" 12A's and nobdy has implied they do. Surely you can see there's no logic in spending more money and more time/effort to have far less power?
I agree with everything Ted said above. All his questions have been answered. All his misconceptions have been corrected. Case closed.
Old Jan 31, 2005 | 03:01 PM
lemonade's Avatar
i would like to put a 10a in an fb, with a big carb and big ports. dont the redline to 8 grand
Old Jan 31, 2005 | 03:41 PM
Icemark's Avatar
Please fix your signature... by forum rules signatures are limited to 6 lines including picture (which any image used should be less than 400x200 pixels).
Your signature is in violation of every rule. Please fix it before it is deleted by a administrator.
Old Jan 31, 2005 | 04:16 PM
hIGGI's Avatar
Here you go, 12A FC (we have nothing to do with it, old guy who owns the car is bit weird but it was done....)
http://rx7cz.net/photos/workshop13/
(the white one)
Old Jan 31, 2005 | 05:30 PM
totallimmortal's Avatar
Is that thing Turbo?
I don't get why you would want a smaller, less powerful engine that will cost much more to install. First of all EFI is better, or maybe i should sayt more accurate not sure how to say it without pissing someone off, than carb thus the reason EFI is used now instead of carbs, But if for some reason you like many other people want to ditch the EFI to go with a carb then it would not be that hard but you would not use the turboii motor you would use either an older 4 port 13b or a 6 port that already came in the second gen, a custom manifold would not be needed since there are companies that make ones that would bolt right up.
Old Jan 31, 2005 | 06:06 PM
-Ted
WTF ever, he obviously WANTS to do it, who gives a flying **** if its more expensive or more difficult to do. All the posts here aren't helping him one bit in trying to achieve what HE wants to do. MAybe he wants something unique. Ever think about that?
I doubt he gives 2 ***** what you think about his concept. Nor do I.
The only irony here is you thinking you are helping him. Get a clue.
Comprende?
