s4 to s6 alternator, newly simplified and demystified
Old Dec 11, 2004 | 06:25 PM
PsYcLo's Avatar
What a waste.
This is a compilation of knowledge gained in the troubleshooting of the wiring of an s6 alternator into a s4 electrical system with the original thread at: http://www.teamfc3s.org/forum/showth...0&pagenumber=1
Through the contributions of many people (KYPREO, Icemark, silverrotor, HiminiRacing, Fedds, fc3s7, RXtasy and myself) we finally resolved the proper way to wire the s6 alternator without causing a drain on the system through improper wiring.
The switch from the FC alternator to the FD alternator has caused many a dead batteries and headaches for the people who have made the switch. I wiring seems simple but a small oversight is easily made which results in a small drain on the battery while the car is off.
Wiring an s5 or s6 alternator up in the s4 fashion (simply trim the old connector off and adapt it) will create an electrical draw. The problem with the way the alternator was wired stock is that the FD alternator expects to see 12V+ with the ignition off, but it actually sees 0V (ign.switched +12v on a s4), Because the output terminal (B) is connected, but the regulator sensed 0V, it will actually try and charge with the battery off, causing a current drain, and potentially fry the regulator. The diagram shows how to wire correctly.
If your regulator is fried (can be checked by most local auto parts stores) they are fairly cheap to replace ($15-20), and a note, there are 4 in the FD alternator.
Why would you want to switch to switch to a FD alternator? The stock FC alternators make just enough power to suffice for the stock electrical system. With many RX-7 owners installing aftermarket stereo systems, security systems and other electrical accessories the alternators soon max out, resulting in dimmed headlights, warmer A/C and all sorts of annoyances. Here are some specs on the output of the different series alternators:
~s4 (86-88) 60amps
~s5 (89-91) 80amps
~s6 (93-99) 100 amps
If you no longer have the stock air pump it is recommended to get a dual belt pulley for the alternator as it may slip at higher rpms with only one belt. Also you will need a different bolt-washer-nut combo to put through the tension bracket and ear of the FD alternator as the FC ear is threaded and the FD is not.
If you are interested in an FD alternator Silverrotor offers everything needed to switch.
https://www.rx7club.com/showthread.p...0&page=1&pp=15
Attached Thumbnails s4 to s6 alternator, newly simplified and demystified-intergeneration-alternator-wiring.gif
Old Dec 11, 2004 | 07:08 PM
Icemark's Avatar
except the stock output of a S4 alt is 70 amps not 60
Old Dec 11, 2004 | 09:11 PM
drft_180sx's Avatar
I thought 70 amps (S4) was overrated...that's what i read somewhere anywayz.
Old Dec 11, 2004 | 11:20 PM
mwpayne's Avatar
Admitted 'rexaholic'
I just did that mod after fooling with a dead battery in my S4 vert with an S5 alt.
I bet that cures it, but it'll sit a few days more to be sure.
Old Dec 12, 2004 | 10:50 AM
usmcjsy's Avatar
I bought my Alt upgrade last year from sliver rotor and hooked it up just like he said. I have never came out to a dead battery. How long would it have taken to drain it...?
Old Dec 12, 2004 | 11:18 AM
mwpayne's Avatar
I noticed mine would crank rather slow (new battery) after a couple of days. Battery completely dead after 2 weeks sitting. You probably won't notice it if you drive everyday.
Old Dec 12, 2004 | 11:54 AM
PsYcLo's Avatar
What a waste.
There will only be a problem if the car is a s4 mind you. But there have been a handfull of people that havn't had a problem with the stock wiring on their cars, I think it has a great deal to do with the battery type, driving habits and what all is done to the electrical system. You may not ever see a problem with your car wired that way, but this IS the correct way to wire it on a s4.
Old Dec 12, 2004 | 01:12 PM
hugues's Avatar
Why am I here ?
ok, this is a quote from a post I made on teamfc3s a while back. Don't worry, this will confirm what psyclo is saying:
Well, let's talk numbers, shall we ...
case 1 (the plug-and-play method):
S4 L wire (W/B) to S5 alt L connector
S4 R wire (B/W) to S5 alt S connector
I get a draw at the negative battery terminal of 130 mA (milli-amps) .. that's quite a lot and that should drain the battery within 2 weeks of inactivity.
case 2 (the method KYPREO introduced):
S4 R wire (B/W) to nothing
battery positive to S5 alt S connector
I get a draw at the negative battery terminal of 20 mA (milli-amps) .. hmm, much better, don't you think ?
I have an S4 with S5 alt (same idea for S6 alt on S4), and it's pretty clear the battery will drain if you don't wire things correctly. Also, the regulator could get damaged.
I had talked about this way back then saying there was a problem but nobody cared at that time.
As previous poster said, if you drive your car regularly, you probably won't notice a thing.
iougs-
Old Dec 12, 2004 | 01:13 PM
hugues's Avatar
Why am I here ?
I had talked about this way back when saying there was a problem but nobody cared at that time.
iougs-
Old Dec 13, 2004 | 11:02 AM
Black13B's Avatar
In Full Autist Cosplay
Icemark, I guess I couldn't convince you? I was right about the LR and LS type differences.
Here is another reference.
http://www.rx7.org/public/altxref.html
I'm glad the misinformation has been disposed of (albeit when I was "wrong" and you so humbly "corrected" me it was available for anyone and everyone to see).
Old Dec 13, 2004 | 12:39 PM
hugues's Avatar
Why am I here ?
That was the thread I created to say that something was fishy, and then I saw the teamfc3s thread which was talking about the same thing, and then KYPREO gave his valuable input, and the problem was solved.
https://www.rx7club.com/forum/showthread.php?t=320618
Then rx7.org changed the instructions on their page after that, I don't know if mikeL changed his though
So at the end, it's all good.
hugues-
Old Dec 13, 2004 | 12:49 PM
PsYcLo's Avatar
What a waste.
No need for pointing fingers and such garbage. Problem solved, use it as a refrence not points scoring.
Old Dec 13, 2004 | 12:59 PM
RotaryRevn's Avatar
How much different is it to wire the s6 alt into a ser3 gslse?
Old Dec 13, 2004 | 01:23 PM
Icemark's Avatar
No I disagree with the solution, as Mazda changed it on later models (fixing the extra draw problem no doubt).
Old Dec 19, 2004 | 11:20 AM
mwpayne's Avatar
UPDATE
My battery would be dead after 2 weeks sitting. Did this mod, waited THREE weeks, car fired right up. Looks like this was indeed the solution to the s5 alt in the s4 problem!
Old Jun 29, 2005 | 04:01 PM
since the S terminal and the B terminal go to the same place. Could you just wire the S terminal wire to the B post? I just installed my alt. this way and dont want to turn it on until I get a responce. THANKS
Old Jun 30, 2005 | 12:50 AM
Well I could wait. So I turned it on and it seemed to do fine. But Im still not going to drive it until I get an oppenion from one of you.
Old Jun 30, 2005 | 01:05 AM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
this thread is fairly old. you might have better luck checking out the sticky from silverrotors threads
ls1swap
Jun 3, 2024 03:25 PM
Robrods64
Oct 2, 2015 07:56 PM
WANKfactor
Sep 29, 2015 01:14 PM
