N/A ECU Coupe vs. Vert
Old Aug 2, 2004 | 03:36 PM
jpd3253's Avatar
In both S4 and S5, the N/A coupes and convertibles (North America) had different ECUs. Yet, they were both normally aspirated with the same engines. Does anyone know the reasoning and specific differences (other than the numbers)?
JP
Old Aug 2, 2004 | 05:39 PM
DEZERTE's Avatar
777** The Anti-rice
Reasoning, in other countries, the very came in a turbo model. I guess they used the ECU from those, in the US verts... The US is so lame, always having shitty cars, and the good cars nerfed.
Old Aug 2, 2004 | 08:02 PM
jpd3253's Avatar
Thanks, but that's not the point of the question. I don't have information on the comparsion of turbo coupes to turbo convertibles ECUs, so I can't comment on any differences (if any). My questions remains, if the North American Coupe and Convertible were both NA, (S4 &S 5) then why the difference in the ECUs and what are the differences?
JP
Old Aug 2, 2004 | 09:43 PM
RETed's Avatar
US-spec 1988 convertible ECU (N338) runs both NA and turbo code in it.
I think it's the only one that can.
US-spec 1989-1991 convertibles all run NA code only.
-Ted
Old Aug 2, 2004 | 09:56 PM
DEZERTE's Avatar
777** The Anti-rice
-Ted
Thats gay, why the hell did they do it that way.. Mazda pisses me off sometimes.
DEZERTE's Avatar
777** The Anti-rice
all US coupes arent NA..
Old Aug 2, 2004 | 09:59 PM
stacher's Avatar
I think what "jpd3253" is trying to say is what is the difference between
'89 California N350
'89 Federal (non-California) N351
'89 California, Convertible N352
'89 Federal, Convertible N353
We know that the "California" is because of emission, but what about the N351 and the N353. What is the difference?
Old Aug 2, 2004 | 10:28 PM
jpd3253's Avatar
That's the gist of the question...What is the difference and why?
JP
Old Aug 2, 2004 | 10:40 PM
Dltreezan's Avatar
My Bick is Digger
actually to re re re-sum up the question is why the hell does having a cloth top mean you need a different computer
Old Aug 3, 2004 | 12:22 AM
Icemark's Avatar
because gearing and fuel mileage setups are different.
Old Aug 3, 2004 | 12:32 AM
marlaman's Avatar
Need an E6x
-Ted
So if you got a different wiring harness for the 88 and threw in a 13-bt engine you wouldn't have to swap out the ecu?
Old Aug 3, 2004 | 12:39 AM
Icemark's Avatar
Yep... I did that exact thing when I had a 13BT in my 88 vert
Old Aug 3, 2004 | 12:47 AM
RETed's Avatar
That is correct.
In fact, the engine harness difference is just a matter of two pins.
One is for the knock sensor, and the other is for the 2-stage fuel pump voltage system.
Both can be ignored, and you can just de-pin the NA engine harness to make it still work.
Oh, you also need the "2-bar" turbo boost sensor also.
-Ted
Old Aug 3, 2004 | 12:57 AM
marlaman's Avatar
Need an E6x
damn that's pretty damn neato. I couldn't afford to do that, nor do i have an 88 vert. but that's really neat.
you guys rock. i wish i were you sometimes so i had a 7 that ran. but whatever i'll get her going this weekend. (hopefully)
Nite nite,
Matt
Old Aug 3, 2004 | 05:41 AM
vectorminds's Avatar
Where's My Fuel???
mark, do you know what the differences between the 91 vert ecu and a 91 coupe ecu are... because i was under the impression that they have the same gear ratio?
Old Aug 3, 2004 | 04:07 PM
Where's My Fuel???
bumpity
Old Aug 3, 2004 | 06:36 PM
Icemark's Avatar
Yes the gearing in the manual tranny coupes are the same as the verts (I was think on how different the auto trannys are since it seems more S5 verts are auto tranny), however I am guessing that the gas mileage map is not. The verts skated the fine line of gas guzzler tax, because of the weight.
Old Aug 3, 2004 | 09:31 PM
Where's My Fuel???
hrm... if thats the case, would there be performance gains to switching out a vert ecu for the coupe ecu in a 91?
Old Aug 3, 2004 | 09:34 PM
jon88se's Avatar
Eat, sleep, work, mod.
I'm actually sending my N338 ECU to Henrik to open and give us the answer once and for all. I don't think there is ANY turbo "map" in the N338 - there is no fuel cut w/ this ECU on my car, so I stopped boosting until I got an N332 (w/ henrik's 1.5 chip).
He will let us know after some datalogging...
Old Aug 3, 2004 | 10:30 PM
RETed's Avatar
I thought he already confirmed this?
-Ted
Old Aug 4, 2004 | 12:35 AM
George84's Avatar
I am back
bump
Old Aug 4, 2004 | 09:36 AM
Icemark's Avatar
I am guessing that the vert ECU would probably give you slight performance gains in a coupe.
Old Aug 4, 2004 | 05:17 PM
jpd3253's Avatar
The preceding assumptions (gas guzzler tax and gearing) would suggest this as a logical conclusion. However, it raises another question. If the vert ECU could provide better gas mileage and performance in a coupe, then why didn't Mazda just use the vert ECUs in the coupes? Which goes back to my original question, what are the differences? Do the vert ECUs control something specific to the convertible that is not engine related?
JP
Old Aug 4, 2004 | 07:02 PM
Icemark's Avatar
I try and stay away from S5 RX-7s in general, so again without wasting my time diggting through manuals and compairing wiring, it would be hard to say. It could be an cost issue... simular to the N338 on the 88, or the board layouts may be different...
I know I have seen on several early 88 model Cali spec verts, they used the same two stage fuel pump setup as the Turbos, so it could be something as simple as that...
But again I try and stay as far away from S5 models as I can. They were the bastard children of the whole RX-7 Line.
Old Aug 4, 2004 | 08:30 PM
Where's My Fuel???
oh come on mark... thats not fair... and arent you using an s5 intake on your car
