View Poll Results: Vote on what one you are seriously interested in buying:
I am interested in the radiator ducting
9.39%
I am interested in the underpanel/front splitter
34
18.78%
I am interested in both
130
71.82%
Voters: 181. You may not vote on this poll
interest in custom radiator ducting and undertray/front splitter combo?
Old Jul 31, 2004 | 05:49 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
Question interest in custom radiator ducting and undertray/front splitter combo?
THIS IS NOT A THREAD TO BUY THESE, this is just a thread to check interest numbers.
Use the poll options to mark your interest.
Radiator Ducting
It would be made out of CF or Kevlar sheets (or some toher exotic material) and be very similar to the one I made out of fiber glass, but thinner and lighter since it would not have the cardboard inside it. Also, it would be much smoother and refined. I would try to make it 'nose' independent (works with almost any nose) and supply all mounting hardware, etc. It would replace the stock undertray.
Here are pics of my fiberglass test modle to get the idea:
Undertray and Front splitter Combo
This would look very similar to the picture below (taken from jt-imports.com site)
However, it would go all the way past the oil pan AND it would go past the nose in the front about 2 inches, basically like a front splitter and undertay together as one piece. Initially the template is made for my nose (mazdaspeed GTC), however, the curve on teh bottom is basically the same on all noses so it should be fairly compatiable with all noses and you can always cut off the extra front material to match your nose exactly, you just wont have the splitter part coming forward. It would also be made of CF or kevlar or some other exotic material :-)
Only vote on the pole if you would seriously buy.
Old Jul 31, 2004 | 06:04 PM
su_maverick's Avatar
Back in the 7 life again
is it possible to do an undertray that is adjustable if someone goes to a v-mount set up?
Old Jul 31, 2004 | 06:16 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
well, the v mount will not affect the undertray, did you mean radiator ducting?
Old Jul 31, 2004 | 06:38 PM
dont mind me, Im still waking up 9 hours later....yep, ducting.
Old Jul 31, 2004 | 06:45 PM
Kento's Avatar
2/4 wheel cornering fiend
Ballpark figure on estimated cost?
Old Jul 31, 2004 | 06:50 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
my bad, i should have estimated costs, let me look at some materials and I'll post an estimate for each one
Old Jul 31, 2004 | 06:51 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
i dont have a vmount car around here to test fit it, otherwise i could make one for the vmount too....i dunno if the stock ducting shape works with a v mount.
Old Jul 31, 2004 | 06:53 PM
Skeltah's Avatar
Interested in both!!
Old Jul 31, 2004 | 06:55 PM
does anyone know if you can work the same piece with stock and then v-mount? I am going to be going that direction next spring and dont want to have to get another piece.
Old Jul 31, 2004 | 06:57 PM
Fatman0203's Avatar
Damian, isnt that with your bumper wouldnt it be different depending on the bumper different people have? Would you do custom orders I guess?
Old Jul 31, 2004 | 07:10 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
are you talking about the underpanel or radiator ducting?
Old Jul 31, 2004 | 07:13 PM
Fatman0203's Avatar
Radiator ducting.
Old Jul 31, 2004 | 07:17 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
Radiator ducting.
I would try to make it usable for any nose, and we would do some test fits if there is enough interest to make them. The first two test fits would be the ms gtc nose (my track car) and the stock nose (my street car).
Old Aug 1, 2004 | 03:54 PM
Tim Benton's Avatar
FD title holder since 94
Just guessing, but I'd imagine the height of the sides would be smaller on a stock nose than on the GTC. I wonder if doing a mock up of the oil cooler (& brake duct vents) for a 99 and other front noses where the old stock ones don't line up would generate any interest? That's the one thing that keeps me from buying a Pettit front nose is the oil cooler vents that direct air to it. Off the top of my head, does covering the oil pan keep it from getting air flow around it that might help cool it a little, or is the cooling negligible?
Tim
Old Aug 1, 2004 | 04:00 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
good points/questions Tim, ill have to look at those while making prototypes....by the way, did you order that CF rear hatch?
Old Aug 1, 2004 | 05:15 PM
twokrx7's Avatar
Need more sleep
I might be interested if it is setup for a stock mount radiator with the a/c condensor in place ( I see you fabbed up your's with the p/s loop in place ).
For the v-mount crowd, I can see the v-mount working only if you leave the undertray off to vent the backside of the radiator. Please educate me if I'm off here.
Old Aug 1, 2004 | 05:24 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
ahh yes, the ac, forgot about that
Old Aug 1, 2004 | 06:02 PM
Tim Benton's Avatar
working out the details on the shipping, but I plan on getting one.
Tim
Old Aug 2, 2004 | 03:42 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
now im thinking the radiator ducting will some in two 'sizes' one for aftermarket noses and one for stock... looks like i can test fit on a ms gtc nose, there is a 99 spec nose over here and i may have a cwest nose around soon.....anyway, ill keep you guys posted after i make the first prototypes for my car.
Old Aug 3, 2004 | 01:19 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
ok, the rad ducting is a bit more comples, so ill tackle that one later, anyway, we cut and drilled the underpanel/splitter today, it aluminum adn i will test it at BIR wednesday, however, in the end it will just be the template for the much lighter CF (or whatever) material. it looked awsome and covered the entire front bottom, ill have pics tomorrow night (forgot the cam today, doh)
Old Aug 3, 2004 | 02:47 AM
Fatman0203's Avatar
Any results on any high speed testing? Got some temps to feed back?
Old Aug 3, 2004 | 09:51 AM
bros0000's Avatar
...i will test it at BIR wednesday...
OK, either you can't read, or you don't know how to use a calendar...
Old Aug 3, 2004 | 09:56 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
damian's Avatar
DDH Motorsports
Top Answer: 1
hehehe, go easy on em :-)
Old Aug 3, 2004 | 10:28 AM
stop with the flaming, geez.
Damian, I cant wait on the results on this. Any pricing ideas yet?
