Flywheel nut questions...
Old Apr 12, 2004 | 01:13 PM
theflatlander's Avatar
Dual Wielding DieGrinders
this week i will be putting my new motor in along with a bunch of goodies including a 9.5lb flywheel. First question what size is the flywheel nut? and i was reading through the Hayes manual and read that this the nut needs to be torqued to 280-300 ft lbs and was wondering how do all of you torque it to that?
Old Apr 12, 2004 | 01:39 PM
brohr01's Avatar
search!!!
flywheel nut --> 2 1/8th inch
get a peice of flat steel that they sell at lowes or homedepot and drill 2 holes in it that will line up with a couple of the bolt that hold the pressure plate onto the flywheel then you can spin the flywheel until the bar hits something solid and then go at the flywheel nut.
Old Apr 12, 2004 | 01:58 PM
i did search but nothing came up on tightening the nut back to spec. i have a flywheel holder so i don't need to do the bolt method but thanks for the input.
Old Apr 12, 2004 | 03:12 PM
Turbonut's Avatar
Be prepared-That flywheel holder will not do much good when you start getting to that torque range.
Old Apr 12, 2004 | 03:14 PM
Aaron Cake's Avatar
Engine, Not Motor
2 1/8, which is basically the same as 54MM. The exact torque spec is not all that important as long as it is close to 300 ft-LBS. I just use a 6 foot breaker bar.
Old Apr 12, 2004 | 04:13 PM
Wankel7's Avatar
Haven't we ALL heard this
Is there only one way to put on the flywheel nut? Like is it flattened so it should go on way?
James
Old Apr 12, 2004 | 04:27 PM
AcidShock's Avatar
Eet fase
Yeah, there is a transmission side and a flywheel side to the nut. You should put the flattened side towards the flywheel.
Old Apr 12, 2004 | 04:45 PM
bingoboy's Avatar
Lava Surfer
mmm impact wrench would be good...
Old Apr 12, 2004 | 04:53 PM
HAILERS's Avatar
HAILERS
A breaker bar, two foot long, with a 150 lb person hanging/standing on the end, how many ft/lbs? Yes. Bounce once or twice for extra measure.......or just go out and buy a torque wrench!
Old Apr 13, 2004 | 02:35 PM
thanks for all the input. i was heading towards the 6 foot breaker bar direction of doing it.
LongDuck
Oct 7, 2015 08:12 PM
