Strut Tower Bar clearances
Old Jan 23, 2004 | 11:12 AM
eyecandy's Avatar
I am going to be purchasing a front strut bar shortly, and I would like to know what you folks recomened. Mainly because I hear about clearnce prblems when you swap in the FD alternator, and I would like to know what will fit with no clearamce issues..
Old Jan 23, 2004 | 11:34 AM
SureShot's Avatar
Seduced by the DARK SIDE
I got the $16 e-bay brace.
Any brand will be tight.
I have 3/8" over the stock alternator, and 1/4" below the hood insulation.
With an FD alternator, you might need a shorter belt..
Old Jan 23, 2004 | 11:54 AM
asherwood's Avatar
I just installed one from Ractive on my 1991 N/A.
The plates fit fine, the bar is slightly bent (as they all are) so you have to be carefull to position it so it sits forward of the alternator and as low as possible.
When I first put it on I had it set to go above the alternator, a big NO NO! It was very obvious that this would hit the hood big time. So check the clearance before you drop the hood to close it!
It took a little fiddling but its on now...looks cool
Old Jan 23, 2004 | 12:08 PM
jon88se's Avatar
Eat, sleep, work, mod.
the Trust bar will not fit an NA without a little coaxing, it's made for a TII in japan where the rad. cap is in a different location. We heated mine up a made a few very small bends, you can't tell
Old Jan 23, 2004 | 12:09 PM
Nick86's Avatar
Yup, still here
I put one of these on my 86.
There is no real issues with alternator clearance - as long as you have it positionned correctly as asherwood said.
Any fitment issues you may have would probably be solved with a shorter alternator belt.
Old Jan 23, 2004 | 12:22 PM
T2R7's Avatar
long term project
my ebay strut bar has is like 3/8 -1/2 inch to low so i have to get a shorter belt. I havent gotten my shorter belt yet, does anyone reccomend a size.
Josh
eyecandy's Avatar
Sureshot, what is the quality like of the ebay strut bar?
Thanks all for the help! I didn't think about getting a shoter belt..
Old Jan 23, 2004 | 12:32 PM
SureShot's Avatar
I had to file a chamfer around the bottom edge of the Pillow block clearance hole, to get it to drop down all the way.
After installing I bent the brackets up about 1/4".
The bar is rotated about 20deg forward.
Old Jan 23, 2004 | 12:54 PM
Mr. Gadget's Avatar
Older than Dirt
Other than rezizine the bracket that attaches to the tower, i have no issues installing. As a mater of fact I have plenty of clearance at the alternator. Mine is a cheapo ebay bar. for my limited driving skills I do notice a difference.
Old Jan 23, 2004 | 01:38 PM
neofreak's Avatar
accept no imitations™
Cusco fits perfectly, clears a FD alternator, stock belts, doesn't hit the hood, and doesn't rub anything.
Old Jan 23, 2004 | 01:40 PM
eyecandy's Avatar
Which Cusco? Any idea of Corksports?
Old Jan 23, 2004 | 05:14 PM
silverrotor's Avatar
I have yet to hear of any clearance Issues with that of a FD Alternator and the use of a Strut Bar. There was speculation, as Is this thread I'm assuming, but thats It. I have had a Reactive Strut Bar (at on point), and now a Cusco Bar on - both clearing all peripherals.
Old Jan 23, 2004 | 05:17 PM
Do you have a FD Alternator mounted In your 91?
Old Jan 23, 2004 | 05:30 PM
neofreak's Avatar
D-Cut.
No idea about Corksport, I only buy brand name stuff.
Old Jan 23, 2004 | 06:47 PM
RETed's Avatar
I used to have the GReddy unit, and I've changed over to the Cusco one.  One of the big problems I had was the coolant filler neck fitting to the overflow reservior.  It tended to snap the plastic end real quick due to the tight space.  I've had to flip the coolant filler neck backwards to make sure it stopped breaking.
-Ted
Old Jan 23, 2004 | 07:06 PM
ddub's Avatar
i am legendary
i think my strut tower bar is the same one as yours (not sure though, last owner put it on) and i had to tilt mine a little like you (it appears) it was pretty damn close i can tell you that
Old Jan 23, 2004 | 07:31 PM
RETed's Avatar
Oh, this only really affects Zenki FC's.
-Ted
Old Jan 23, 2004 | 08:43 PM
Mint87RX7's Avatar
I have a CP Racing bar, its awsome reinforcement but to fit it you have to cut the corners off the fan, they ran it there instead of by the alternator belt. I love it and only takes like 5 minutes to cut the fan and i got mine exact so its balanced.
