paintjob done>supersonic blue met pearl..lots of pics
Old Sep 11, 2002 | 09:44 AM
marlaman's Avatar
Need an E6x
§up ryandogg
I am coming to alaska on a commercial fishing trip to earn money for the sole purpose of making my car a 20b monster. i am going to make it showroom quality (or so i hope) and go the whole 9 years. when i come up to alaska after i'm done with college in duluth you should let me see how your car looks in person .
And yes my old n/a will be a turbo 20b monster. what a little sleeper. well untill i get the bodykit anyway. all is good in the land of matt. so far my budget for my car is roughly 30k and will prolly be higer after i impress tons of people on my fishing trip.
sombody BUMP UP MY POST FOR MY CAR FOR MORE IDEAS!
Old Sep 11, 2002 | 12:06 PM
RotorBalls's Avatar
Damn nice color, looks good!
Old Sep 11, 2002 | 12:17 PM
MaxRX7's Avatar
hambre y sueńo
I can help you fix those headlights !
other than that, your car looks mint
Old Sep 11, 2002 | 02:44 PM
cblake3's Avatar
Where did you get that front lip? How much was it??
Old Sep 11, 2002 | 02:58 PM
SoloIIdrift's Avatar
Can you go into more detail as far as what color the car was before, what you had to use/do to get the car ready to paint. What type of air compressor you had and spray gun did you use?
Old Sep 11, 2002 | 03:50 PM
vaughnc's Avatar
knowledge junkie
Yeah I like the medium blue. A friend just painted his Viper Blue - looks nice.
BTW - did that have clearcoat on it?
Old Sep 11, 2002 | 04:59 PM
rx-7s rock's Avatar
Game of Death
Uh, the car looks good before, when you bought it, but I can't see the after shots. So I'll assume it looks good. I have to get the rust off my car and sand the hell out of it. Should I do anything special when sanding the car down?
Old Sep 11, 2002 | 05:08 PM
ryandogg's Avatar
Originally posted by jetfire76
hey nice work. i too will soon be repainting my FC...an 88 AE and white of course. i am thinking of adding a VERY slight coat of trasparent blue. the car will still be white but if you look at it at the right angle with enough light the finish will give off a VERY slight hint of sky blue.
ryan is right. 95% of the job is sanding, blocking, wet sanding, buffing...repeat about 1000 more times. patience and the willingness to do it RIGHT is key. DONT take any shortcuts.
hey ryan, dont tell me all you wore was that little mask when you shot the car?!?!! when i deal with that toxic paint i put on my "space suit" which has a full head mask with it's own line feed to a separate air compressor source. kinda expensive but much more safe and worth it!!!!
also did you find using a pearl coat hard to work with?
about what i wore when i was painting.. well... put it this way.. i ended up looking like something from an 8-'s spaceman flick.. see i didnt have a suit so i just wore a **** load of clothes.. and as for a breather i just used a resperator.. as u saw me on the pic with a regular 50 cent gas mask compared to a 100 dollar mask.. see my bro was willing to take pics while i was working .. so instead as a nice big brother i handed him the expensive mask for a good 2minutes only.. then kicked him out. ..heheh as for coating pearl. it nothing much more than another type of coat.. so no special tretments. just follow flash procedures and you should be fine..
Old Sep 11, 2002 | 05:10 PM
ryandogg's Avatar
Originally posted by marlaman
§up ryandogg
sure doode.. just give me a holla when you get here.. pm me or something.. ill even take you for a ride or something.. and if youve never been to anchorage.. ill take you to the races.. itll be funn.. trust me..
Old Sep 11, 2002 | 05:22 PM
ryandogg's Avatar
go check out teamfc3s.org or pm mikeL...im not sure how much is it now. but i got mine. like some people before he was mass producing..so i got it for cheaper..
Old Sep 11, 2002 | 05:44 PM
ryandogg's Avatar
well the old paint that was on it was just simply metllic blue.. thats all..it looked nice but it didnt have that wow look. so i did what i did... here are the essentials for the paintjob....
compressor tank. - i used craftsman 150psi/33 gallon.
craftsman airgun..
wet sand papers. 150-for those big scratches
400 for getting rid of the cloar coat.
use only if not gonna take off all paint..
2000 grit.. inbetween coats sanding
sandable primer- use catalized
a resperator-a must
some household dish washing soap
masking- use masking tape(duh), and a **** load of newspapers..lol.. cheapo
wax and grease remover--.. this will be your last step before actualli painting the car. this removes light finger prints and grease that you might have not noticed taht was there.. please dont skip this step.. wait for at least several hours. better off over night.. , you wouldnt want water on the car.., make sure everything is dry..
now for the funn part.. shoot the car with your choice paint, in a side to side pattern with a 1 sec intervals..whats out for drips.. if this occurs.. finish the rest of the car and wait till its dry. give it about an hour., then dry sand it with 400 until smothened..then proceed. re paint..
and for the clearcoat its almost the same as the base paint.. except for the mist is way more amplified.. ohh trust me guys, youll know when you do it yourself.. almost zero visability.. coating your car 2-3 coats is essential. , due to uv light your paint will get dull. so make sure you do good job on the coats.. for an extensive wet glossy look..
onlly coat twice then sand make sure you dont snd all the way to the base..then wipe excess with gease and wax remover. and then recoat..
Old Sep 11, 2002 | 05:49 PM
ryandogg's Avatar
buy a rust nuetralizer.. i chemically changes rust to primer.. then sand it. with 150.. reprimer.. then maybe if you want - bondo the parts thats been eaten up.. the re prime....
Old Sep 11, 2002 | 06:03 PM
aerodogg's Avatar
Hey heres a pic of my 7. I just got it painted to. Its a 67 Corvette manira blue met.
Old Sep 11, 2002 | 06:06 PM
aerodogg's Avatar
Here my Car 7. just got painted too. Its a 67 corvette mainra blue met.
Old Sep 11, 2002 | 08:08 PM
ryandogg's Avatar
aerodogg. i cant see the pic.. i would like to see it.. can you try to repost the pic please.. thank you.
Old Sep 11, 2002 | 08:25 PM
Rotary-Revolution's Avatar
Does anyone have a more in-depth article on how to do body work and paint?
Or is there a good book on painting?
And for a first time painter, is it worth the time and money, or should I have it done by a "pro"?
Old Sep 11, 2002 | 08:36 PM
banzaitoyota's Avatar
What Subscription?
Looks good.
One step I would add for all those attempting this/ Use a product called POLYCRACKER before you start sanding. This removes all traces of silicones and polyglycoat on your car.
Old Sep 11, 2002 | 10:10 PM
superpimp35's Avatar
oodle the noodle
WILL SOMEONE PAINT MY ******* CAR!!!!!!!!!!!! PLEASE!
Old Sep 11, 2002 | 10:30 PM
ryandogg's Avatar
y whats wrong with your car color. is it dull.. is it shitty.. let see some pics...
Old Sep 12, 2002 | 02:04 AM
Node's Avatar
Your paint looked great before, now it's just plain breathtaking.
I wsa I had the tools and space to paint my own car :-\
Oh well, I'm selling it and going for an S5.
Do you have any pictures of the engine bay?
Did you paint under the rubstrips and then install them and paint them, or just paint overtop?
I think it would be kinda cool to paint the black hatch part body color
Old Sep 12, 2002 | 01:42 PM
Gen2's Avatar
Paint looks great! im debating on whether i should try a DIY paint job or not, on my t2. Looking at your car is giving me more confidence that it can done.. do you have actual experience at a shop, or was it just pretty much from your own trials? any good web sites or books on autopainting?
-AL
Old Sep 12, 2002 | 05:32 PM
  #47
ryandogg's Avatar
here ya go node
this was taken today.. egine bay is kinda dirty. but itll do for now...
Old Sep 12, 2002 | 05:38 PM
  #48
ryandogg's Avatar
another..
Old Sep 12, 2002 | 05:55 PM
  #49
Spraintz's Avatar
Edmond Dantes
WooHoo!! I've been looking for a good blue, and that is IT!!!
Good job BTW
Old Sep 13, 2002 | 05:06 AM
  #50
ryandogg's Avatar
-AL
nah man. i dont have any shop experience. the only experience i had was drawing tagging on was. like you know graffiti art. lol. i had some can control. thats about it.. but automotive shop experience..shopwise.. like body and fender.. none..
but im good with engines.. just not so great with rotaries..i know enough to keep it running good, thats all
