Suggestions for fixing oil catch can problem
Old Aug 15, 2008 | 03:05 PM
  #276
Hyper4mance2k's Avatar
The Shadetree Project
so will the OMP drain back in the FB front cover be enough? It is really small in compairison to the ones in the pictures.
Old Aug 24, 2008 | 04:51 AM
  #277
Alright I answered my own question. Yes it will work. The gasket has a pin hole for the return, but it's the same size as the FD return. This is the best solution I've seen and it works great in my car. after 3 hard races not gunk in the neck and no oil loss at all...
Old May 9, 2013 | 12:35 PM
  #278
80's old school's Avatar
common sense prevails....
I know this is digging up an old thread!!
I have a Turbo 2 engine in a first gen that easily pulls in excess of 1G on the track.
I am having an oily mess like explained in this thread.
I DO NOT have the passenger side turbo oil return like the 3rd gens have, but would like to do a crankcase vent on the passenger side.
I am doing the oil cap (turkey baster mod) and a Moroso oil catch can/separator, so that will address the drivers side.
Here is my question:
I have removed the OMP and the associated gear drive. I plugged off the oil feed to the OMP shaft and put a block plate on.
Can I modify that OMP block off plate (weld a hose fitting) and use that for an alternate crankcase vent? I saw where people have drilled the front cover and did this... Do you think this would work, or would there be some kind of oil spray there?
I REALLY don't want to remove my front cover and drill and tap!
Ideas?
Th0m4s
Feb 26, 2019 02:04 AM
Microtech
30
Apr 23, 2016 06:37 PM
tsmith94FD
Aug 16, 2015 05:41 PM
