can you cut the crush washers on a series 4?
I was going to change my plugs tonight and I was wondering if I could cut the crush washers off on a series 4 motor?
I know it can be done on a series 5.
Re: can you cut the crush washers on a series 4?
Trending Topics
Originally posted by supergoat
I cut the washers off the "top" plugs, but not the bottom.
Been that way for over 100 miles so far, no ill effects, but I'll pull the plug and see if it has marks on it later.
Mazdaspeed7 runs his car preaty high up in the rpm range, according to prior posts. So maybe that is why his trailing plugs got nicked. Due to the increased rpms the clearence would be shortened and maybe enough to contact the plug. Reving to a lower peak of maybe 7500 rpms might prevent it from happening.
Originally posted by mazdaspeed7
I can see I am going to have to take a pic of the rotor housing. There is NO WAY the trailing plugs could hit anything inside the chamber. Give me a few minutes and Ill have a few pics up. Ill get a pic of the clearance of the leading too.
I just measured a 1990 n/a rotor housing I had in the garage and a NGK plug(leading) WITH the cruch washer cut off. Heres what I got:
trailing hole, center - .893"
trailing hole, edge - .863"
Leading hole - .924"
Spark plug - .840
So it will fit with NO clearance problems whatsoever.
Spark plug - .840
Spark plug - .840
Spark plug - .840
How did your trailing plugs get nicked then?
Telsa, I havent needed one of those special sockets yet.
Good idea, ka8legend. That might be worth a try.
And this thread is back from the dead, seems to have been happening to a lot of old n/a threads lately
toplessFC3Sman
Mar 20, 2018 01:54 PM
BLK 93
11
Sep 9, 2015 10:56 AM
