19lbs of boost/stock turbos/safe?
Old Oct 5, 2004 | 01:33 PM
evil7's Avatar
I have been informed that 19lbs is the most you can go with out burning the stockers up and also being a consistant boost presure.....ANY DISAGREE????
Old Oct 5, 2004 | 01:35 PM
rx7f4n4tic's Avatar
no way, id say the stockers cant push more than 16 efficiently TOPS. Even then they will taper off high end at that high of boost...
Old Oct 5, 2004 | 01:36 PM
rynberg's Avatar
You've been misinformed. Additionally, you need a 3-bar map sensor to run over 16 psi.
Old Oct 5, 2004 | 01:38 PM
wiblergt's Avatar
yeah, 19lbs for 1 quarter mile run at best!
Old Oct 5, 2004 | 01:40 PM
the_glass_man's Avatar
Will u do me a kindness?
Attempting to do so would just be asking for a blown engine and turbos.
Old Oct 5, 2004 | 02:02 PM
TurboLumpy's Avatar
They took our jobs!
but if u choose to do it could you get it on film?
Old Oct 5, 2004 | 02:06 PM
1QWIK7's Avatar
White chicks > *
LOL ^^^
only one way to find out huh?
Old Oct 5, 2004 | 02:43 PM
95R2-89TII Ground Zero's Avatar
Banned
I'm gonna say 1/2 of the 1/4 before it blows up....(1/8 mile total for the math impared)
Old Oct 5, 2004 | 02:48 PM
Single7's Avatar
Evil7,
Even if you could make your stock turbos boost to 19 lbs. consistently, in that range you are way out of your turbos' efficiency range. You'll essentially be blowing lots of hot air with only marginal performance increases.
Old Oct 5, 2004 | 02:51 PM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
Originally Posted by Single7
Evil7,
I agree with single7..
Old Oct 5, 2004 | 02:58 PM
1QWIK7's Avatar
White chicks > *
Evil7,
but hey
at least he can be the first one to say, "i boosted 19lbs on my stock twins "
lol
Old Oct 5, 2004 | 04:17 PM
Tom93R1's Avatar
gross polluter
So my question is, who has actually tried running that high of a pressure on the stock twins and how do you know it is beyond their efficiency range? This is one of those things I wonder if anybody really knows or if they just keep repeating what they heard from somebody else.
Old Oct 5, 2004 | 04:45 PM
DaleClark's Avatar
RX-7 Bad Ass
There was a fellow on the forum a while back that was running some INSANE quarter mile times on the stock twins - like nearly breaking into the 10's.
I do know of people running high boost on stock twins consistently and having MAJOR reliablility problems - smoking, bearings dying, even the shaft snapping. If it's spinning at that high of an RPM where it has mechanical difficulty, it's definitely beyond the design spec for the amount of air the compressor can properly handle.
Dale
Old Oct 5, 2004 | 04:53 PM
KaiFD3S's Avatar
SINFUL7
Just try it and video it and show it to us...if you blow then we know not to do it and if engine survives then you can prove people wrong..
Old Oct 5, 2004 | 05:22 PM
skunks's Avatar
I'm a CF and poop smith
i have seen 1.2-1.5bar on my stock twins but that was a long time ago. this was only in 2nd though and when i just got my car and yes it was to redline. 3rd gear showed 1.5bar by 5krpm and i would let off . i have since turned down boost to a nice/stock 10psi and was actually able to get 10-8-10psi boost pattern now. in anycase, both my super afc (i know it reads off the stock map sensor and yes i know that the stock 2bar sensor only reads accuratly up to 17psi) and my greddy boost gauge said the same thing. not sure if they can both be off at the same time. in any case, my car is running very nicely right now except for the craptastic tranny (5gear is gone and others sometimes grind if shift fast, note: i bought the car like this previous owners could not drive very well i guess or just dragged the **** out of it) and brakes (god i have to really blead them well and get new brake pads, i can come to a stop from 60mph with in the lenght of a intersection but i think it could be better).
Old Oct 5, 2004 | 05:37 PM
evil7's Avatar
Well,I know my engine is not going to blow, it is STREET-PORTED and has 3mm apex seals,on top of that I have a Power-FC stand alone and all the other goody's to go with it,just read my GARAGE and tell me what type of PASS i should make on the stock twins"I DONT PLAN ON KEEPING THEM LONG ANY-WAY",LOL...If I end up running them like that Iwill be sure to get it on video for all to see...
Old Oct 5, 2004 | 05:41 PM
Mahjik's Avatar
Mr. Links
Unless you have have a different map sensor, ~17 PSI is the max the stocker goes.
People have run the stockers at 17 PSI.
Old Oct 5, 2004 | 06:02 PM
Boostn7's Avatar
PowerFC w/OEM map sensor is good for 17-17.5psi before it maxes.
I personally ran 18-19psi and the twins(non-seq) lasted much longer then everyones opinions !!!! I did break the shaft once trying 20psi !!!!d the limit
I would recommend 17 psi being the limit for them to last....I ran them at 17psi for over a year before cranking it up.
For those non-believers check out the following videos.....
I guess I proved a few of you wrong.
http://forum.vwsport.com/dload.php?a...ory&cat_id=122
Old Oct 5, 2004 | 07:37 PM
cavellm's Avatar
The turbos are out of their efficiency range if after a 3rd/4th gear pull or two you notice your intake temperature rise by a few degrees C on your Power FC.
Old Oct 5, 2004 | 07:39 PM
dexmex88's Avatar
My FD Sucks
Boost that much and video tape it. Then we will start a thread called "How not to treat your 7".
Old Oct 5, 2004 | 11:20 PM
Black97VR4's Avatar
FEARED
I think darkphantom is this guy's tuner.
Old Oct 5, 2004 | 11:25 PM
cloud9's Avatar
The bomb is in the toy!1!
Top Answer: 1
my intake temps used to "skyrocket" even when I got on it just once and that was at 12.5PSI
Old Oct 5, 2004 | 11:32 PM
jimlab's Avatar
Super Snuggles
Let me guess... stock intercooler?
Old Oct 6, 2004 | 12:17 AM
xb2002's Avatar
I AM A THEIF - I also go by EVIL7
3 bar map
a 3bar map sensor is just a plain old GM map sensor correct? What settings will the power fc need for it to work?
Old Oct 6, 2004 | 12:35 AM
radiantRX-7's Avatar
does anyone know how much boost you could max out on the 99 spec. twins is it 17lb's also?
