Smoking turbo options
Old Nov 18, 2002 | 01:06 PM
Flying Monkey's Avatar
Can you check out http://www.teamfc3s.org/forum/showth...&threadid=6566
I'm kind of cross posting across forums in hopes that more eyes = more information.
Old Nov 19, 2002 | 12:39 PM
18 views & no opinions? I'll put the post here, then since maybe running to the other fourm was puttintg some poeple out.
Well, the turbo rebuild I thought I salvaged is still goofy. The car smokes like a freight train all the time. It's oil smoke. Damn near positive of it. Anyway, I'm pretty sure it's the turbine seal. The intake side is still nice & oil free. No oil in the intake tract. I think the seal may have wiggled out of it's "slot" in the center section. I was hoping it would seat nicely when I tightened up the nut. That evidently didn't happen. I'm reviewing my options right now.
1) Pull turbo apart, inspect it for obvious problems & reassemble. Maybe I can get the seal to seat properly doing this.
2) Pull turbo apart & try using the old turbine seal. It didn't pass oil prior to the rebuild going bad. I rebuilt due to oil in the intake tract & shaft play. The turbine seal is still in a baggy in the garage.
3) Order new turbine seal & just replace it. This may work, may not.
4) Pull turbo & send it to BNR Supercars for a rebuild. This should be $320. That's $320 that'll be lost if/when I upgrade the turbo instaed of going full T4. I ,of course, don't really feel like spending this as it will push back my painting a bit. Of course, I should probably just suck it up & go this route.
In any case, I'll check the DP for oil when I pull it off. I'm pretty sure I'll find some.
I'm trying very hard to do this as cheaply as possible while still fixing the problem. I'm going to hate it if I have to have it rebuilt as I'll keep it stock. This falls into the spending my money more than once bit that I despise. I'd love to have it upgraded while the rebuild is done, but then I'd have to do some fuel mods (720cc injectors, $240) & get an S-AFC ($315) at minimum. So that'd be $550 plus the upgraded turbo. I'd much rather spend that on a Haltech & some fuel mods instead. The car needs paint/rims/tires first.
Old Nov 19, 2002 | 12:43 PM
GLHS's Avatar
Shelby Tuner & FC badass
bad PCV valves or disconnected or incorrectly connected valves make cars smoke.
Old Nov 19, 2002 | 12:46 PM
DaleClark's Avatar
RX-7 Bad Ass
Yeah, make sure it isn't just a crankcase breather failure.
If it is the turbo, I'd just pick up a used turbo for $100-150, slap it in, and rock and roll.
Dale
Old Nov 19, 2002 | 01:00 PM
PCV was replaced during the splicing. None of the smoking was present until the compressor shaft nut backed off. This is why I'm pretty sure it's the turbine seal.
Old Nov 19, 2002 | 01:03 PM
tIIforever's Avatar
terminally boosted
I got my s-afc for 280 brand new with buy it now on ebay..
Old Nov 19, 2002 | 01:04 PM
tIIforever's Avatar
terminally boosted
heres one for cheap. http://cgi.ebay.com/ebaymotors/ws/eB...tem=1872886282
And once more, I'll ask where to find a usable S5 turbo for $100-150. I'm looking, but can't find one for that price.
ChrisRX8PR
Aug 21, 2015 01:56 PM
pzr2
Aug 15, 2015 08:29 PM
WyomingTII
Aug 13, 2015 10:42 AM
