Anyone who has done the water temp gauge mod...
I'm about to do it this weekend. I have the pdf that describes pretty much everything. Just wanted to ask for any last-minute advice that the pdf might leave out. Thanks.
(the pdf I'm talking about is this one: http://www.iluvmyrx7.com/3rdgen/how-...auge%20mod.pdf )
Just for the record...
Temp gauge mod is now done. I followed the pdf word-for-word. Only problems I had was pulling some panels off (this was my first time dissassembling the dash). I used alot of force to pull the dashboard end panel and meter hood off, but nothing cracked. I didn't need to remove the steering wheel.
This is a pretty easy mod for newbies (like me), but a word of caution: if you're not very good at soldering try to find someone to solder the jumper wire for you. I had no problems, but I've soldered quite alot before.
The difference in gauge behavior after the mod is incredible. At first I thought I had screwed something up because the gauge didn't move until the car got quite warm (I burned myself pretty bad making sure all the wires were still connected). As I drove in stop and go traffic, the gauge hung close to the middle, but was obviously very sensitive to exactly what the engine was doing. At speed, the gauge went way down to cold. It read so cold that I thought something had come loose, but when I let the car idle in the garage, the gauge went back up until the fan came on just over the halfway mark. So I think it's working fine (the ambient temperature was very cool which I think explains the low reading on the highway).
All in all I am very happy with the "new" gauge. I have much more confidence in the temperature reading, and the dash still looks stock. Oh, and it cost me less that $40.
Good work, I recently did this also. The weather outside in ALT is getting colder, so driving around the gauge sits on the normal low marker, and when I kick the fan mod on it moves to the cold reading. Your guage seems to be working perfect! I was surprised how long it takes to get the car up to normal temp also.
Questions:
Do you need to keep the Radio Shack(potentio meter assembly) box in the engine compartment? Or do you just use it once to adjust, then take it out of the engine bay?
Thanks,
Reza
Thanks,
Reza
Originally posted by reza
Questions:
Thanks,
Reza
Questions:
Thanks,
Reza
That makes for a cleaner install.
Use 1 watt resistors if you can get them.
I ended up using a lot lower resistor value than the article sugested.
I set my guage so that the top of the normal range corresponded to the cooling fans turning on with no electrical load (AC, blower and parking lights off).
That should correspond to 220 deg F.
Yeah, you could replace the pot with a fixed resistor, but I left it in. It's in a shiny little aluminum box so it doesn't look too bad.
I worry a little about the heat from the engine changing the resitance of a fixed resistor (I guess it could affect the pot too). It's probably a good idea to check the calibration of the temp gauge every now and then (like after an oil change?). Leaving the pot in makes re-calibration much easier.
Has anyone checked to see the affect of heat on the pot or fixed resistor?
Trending Topics
I see no change in calibration with heat.
I used 1 watt resistors for better heat resistance.
(compared to 1/2 or 1/4 watt)
I know it's staying in calibration because the top of the normal range corresponds to the electric fans turning on.
It alwyas seems to be dead on.
good info. How long did it take to do it?
Any difficulties experienced during the mods?
I’d be happy to give anyone pointers, if it’ll get you started …
Originally posted by HeatTreated
Man, that site link on the How To, isnt working... can someone e-mail me the how to... if you saved it? or paste it on here? thanks alot.
You'll need Adobe Acrobat Reader to view the file. Don't ask for it in another format, that's the only format it's in...
Note that it also takes pdf files an AGE to load from this site, whether the gauge linearization or manual pages. Just be patient.
I did this mod also, and swear I've become a temperature **** because of it. TOTALLY **** about temperature, just like I oughta be
Originally posted by FattyCBR
Anyone know if this would work on temp gauges in other cars?
Thanks
Thanks
Maybe in another gen of rx7, maybe even another Mazda, but I doubt that it would work in another make. Well, unless the same gauge circuit is used in other cars ... maybe manufactured / sold by say a company other than Mazda.
Now if you were willing to put in the time to reverse engineer the gauge in the other car I'm sure that a solution exists. You're gona need some electronics experience though. I’d venture that a high end hobbyist could do it.
Mazda, in it's infinite wisdom, decided that customers would be bothered by seeing large fluctuations in engine temperature, given they were paying $36K for the car. So they set the gauge to come up fast so customers would not be bothered by the long warm up (or be bothered by thinking they were driving around on a cold engine. 'Cause why would THAT be a bad thing?), and not move more or less NO MATTER WHAT the hell was really going on. Unless the car was boiling its coolant out the overflow tank 'cause it just overheated. THEN, said customer that would have been SOOOO inconvienenced by a moving needle (that nearly EVERY other car I've EVER driven has!!!) would dutifully pull right over on the freeway or side road he or she was driving on and shut down the engine and call the friendly local tow truck owner, rather than continue for thirty miles to the nearest gas station run by "a guy I know" and COMPLETELY warp the housings.
Right.
My second gen had a nicely linear gauge. So has every other car I've ever driven.
Right.
[For Sale] Scratch & Dent, Used, and Open-Box Sale!
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
mulcryant
Sep 9, 2015 05:24 PM
