sunroof restoration (removal/disassembly questions)
Old Jan 9, 2003 | 09:53 PM
93BlackFD's Avatar
built my own engine
i would like to restore my sunroof, mainly the weatherstripping and the brackets which are now rusted...it works fine as it is, and i know if it isn't broke i shouldn't fix it, but when it is open, you can see all of the corroded rails and crappy weather stripping- i want to disassemble it and repaint/regrease/reseal everything
anyone have any help about removing it and getting to these parts? anyone done this?
and yes, i can read the blow up diagrams, i just want some friendly advice
Old Jan 9, 2003 | 11:07 PM
93BlackFD's Avatar
built my own engine
nobody can ever answer my questions, all the newbies get 30posts on a how-to answered question, wtf?
Old Jan 10, 2003 | 09:54 AM
aimedhigh's Avatar
I havent replaced the brackets. I just cleaned mine up and sprayed them with an anti rust paint. (looks like new). As for the weatherstripping, about $80.00 from Russell Mazda Plus S+H #800-638-8401. I hope this makes up for all of the negligence. Good luck.
Kevin
Old Jan 10, 2003 | 10:55 AM
93BlackFD's Avatar
built my own engine
thanks kevin, how did you remove the sunroof assembly? is it as easy as it looks (2 screws??)
Old Jan 10, 2003 | 11:19 AM
rotary-tt's Avatar
2 babies - no back seats
Go to MazdaFormance and pull down the microfilm on the PDF files. It has a blow up of the sunroof and all the part numbers. I don't have a sunroof on mine so I can't help with the removal. If you go to the shop manual (http://www.scuderiaciriani.com/rx7/whats_new.html) it should tell you how to dissassemble.
Old Jan 10, 2003 | 11:54 AM
wonder1and's Avatar
I Sold My Car 2 the Devil
I know to at least get the thing off you need a long screwdriver to get the pop rivets off that hold the interior piece on. once all have been poped you just slide the piece off then start undoing 10mm nuts and such. hope this helps.
Old Jan 10, 2003 | 11:59 AM
93BlackFD's Avatar
built my own engine
yeah, thanks for the help guys, i think this is a project we should all be doing
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
83revival
Sep 3, 2015 10:42 PM
