dellorto & Holley fuel pres. reg.
Old Sep 3, 2002 | 01:38 PM
metalliman's Avatar
I'm having problems with my '83 rex. I have a street ported 12a, with a Dell carb, Carter pump, and Holley fuel pressure regulator. The regulator is rated for 4.5-9 psi. I have the adjusting screw on the regulator all the way screwed in, and my fuel pressure gauge is reading 6 psi with the key in the start position, 4.5 psi while the engine is cranking. Anyway, the engine keeps flooding out BAD! I've pulled the spark plugs out, and I do have spark on both leading plugs, however I've noticed the engine is flooded so bad that there's a puddle of gas in the spark plug sockets, and this happens after just 30 seconds of cranking. I'm thinking this may be because the idle mixture screws are too far open. Approximately how far should I open up these screws? Any other ideas on what might be causing this problem? One other thing, I've noticed the engine will usually start after it's sat all night long, and run for 5 to 10 seconds. But never again for the rest of the day.
Old Sep 3, 2002 | 03:21 PM
1st7heaven's Avatar
Not 100% sure but I think the preasure is way too high? I used to run a del. and I think I was running around 3.5-4 psi??? anyone else have opinions???
Old Sep 3, 2002 | 03:42 PM
metalliman's Avatar
I know RB recomends 4.5, but for all I know, my gauge may be way off. I here a lot of people talking about there fuel pressure gauge being way off.
Old Sep 3, 2002 | 04:20 PM
David88vert's Avatar
r71's daddy
The Malloy 4309 goes 3-12 psi and is $72. I have one that I am sending back. If you want it instead of me shipping it back, pm me and we'll work something out.
Old Sep 3, 2002 | 04:39 PM
moremazda's Avatar
Gone Race'n
Fuel pressure should be around 2.5 to 3 psi. try it and you will be happy
Old Sep 3, 2002 | 05:02 PM
metalliman's Avatar
Allright, I'll try the lower fuel pressure when my engine isn't flooded, thanks.
Old Sep 3, 2002 | 05:11 PM
JoseReyes's Avatar
RicanRider
According to my Dellorto / Webber Book, all weber / dellorto side draft need a fuel pressure between 1.5 to 2.5 psi....
I have mine at 2.5 and worked fine.....
Old Sep 3, 2002 | 05:17 PM
metalliman's Avatar
It's strange that RB would recommend such a high amount of pressure. Nonetheless the general. consensus seems to be lower the pressure
Old Sep 3, 2002 | 05:47 PM
diabolical1's Avatar
whooooo-weeeee! (said the diabolical one - devilishly rubbing his hands together )
man, i've been there ... with the same dellorto problem. just a thought here, but you may end up having to change the pressure gauge to the 1-4 psi Holley unit (Summit's catalog only lists the 4.5-9 psi) the P/N is HLY-12-804 ... i just got it a few weeks ago, and it's like i'm driving a different car!
anyway, play with what you've got, and exhaust all efforts to make it work before you buy another regulator, though ... what didn't work for mine, may work for you.
anyway ... the whole point of this post was to refer you to a thread i did a few months back ... some very good info, and rxcetera solved my problems, so it might be worth a look. i just tried finding it so that i could include the link, but it's like it just up and disappeared
try searching though, maybe you'll have better luck than me.
Old Sep 3, 2002 | 06:43 PM
metalliman's Avatar
I'll take a look at your thread if I can find it. Fortunately, I have a purolator regulator that I just hooked up that offers me lower pressure. Right now my gauge is reading 3 psi, still no luck.
Old Sep 3, 2002 | 07:14 PM
SilverRocket's Avatar
EliteHardcoreCannuckSquad
Metalliman,
Your fuel pressure is set way too high. The proper setting is the 4.5-9psi Holley reg with the screw almost all of the way *up*.
If you have your screw turned all the way *in*, you are running it at maximum and pouring fuel in. The more you turn the screw "out*, the lower the pressure becomes.
The proper fuel pressure for the RB Dellorto is 4.5 psi.
Don't pay any attention to that guage you have - it is not accurate. The majority of the guages out there are useless for tuning fuel pressure.
The way to set pressure is to turn the screw all the way up. Then turn it in slowly until the carb starts to flood. Then turn it back a bit. Go test drive it. If it starts to stumble if you let it idle for a bit, it's too high. Keep adjusting and test-driving through trial and error until it feels right.
The 4.5-9psi model works great on my car. Get rid of that Purolater; word is it restricts fuel flow.
Old Sep 3, 2002 | 07:38 PM
metalliman's Avatar
I'd like nothing more than to go out and test drive it over and over again. I haven't driven it since the day I drove it home from the dealership 6 months ago, and it only had compression in one rotor then. Since then, I've rebuilt it, had it running with the stock fuel pump. I guess I'll just wait until tomorrow morning so the engine isn't flooded.
Old Sep 3, 2002 | 07:40 PM
metalliman's Avatar
By the way, SilverRocket, do you have any idea where your idle mixture screws are set. My cousin (wannabe mechanic) starting messing around with them when I wasn't in the garage. I'm wondering if this has anything to do with my flooding.
Old Sep 3, 2002 | 08:11 PM
It's been a while since I set them; I believe they are around 3-4 turns out (can't check.. put my car away in storage last weekend, due to going back to school.)
Here is RXcetera's advice on adjusting them:
Take your car out for a very hard run… make sure the engine is very hot when adjusting the mixture adjustment screws. I recommend turning them out almost all the way, and then turning them back in until the engine starts to stumble, then back out about 1 1/2 turns. If this is done when the engine is at normal operating temps, the next time you drive hard, your car will idle badly until it cools again.
I don't think this has anything to do with your flooding problem though. I'm thinking that cranking your fuel pressure down will be the ticket.
Old Sep 3, 2002 | 08:16 PM
metalliman's Avatar
Well, like I said, I'm running about 3 psi according to my gauge, and this is using the holley regulator with the screw turned OUT. Thanks for that advice. But, i think the engine is so flooded it will take hours for it to unflood. Any safe way to unflood the engine quicker? I tried unplugging my fuel pump and turning it over for a little while. Didn't help any.
Old Sep 3, 2002 | 08:21 PM
Never done it myself... but it will be all over the forum; try the search button.
I think what you'll probably need to do is pull the spark plugs, wipe them off, disconnect ignition coils, crank the motor and watch gas fly all over the place lol, and re-install plugs.
Search though, again I've never done it.
Old Sep 3, 2002 | 09:05 PM
well, this may soubd really ghetto, but it worked for me more times than i can actually remember.
1 - take your plugs out
2 - disable the fuel pump
3 - crank the engine until mist stops coming out the plug holes - (if no one is there to crank it for you while you watch, then just crank it on and off for a few seconds ... 7-10 maybe)
4 - take the plugs and either burn them with a lighter or if you have a gas stove, then just put them there for a little while (maybe a minute)
MAKE SURE YOU PROTECT YOUR HANDS!!!!
5 - reinstall the plugs
6 - hit the gas a couple times
7 - crank the engine without the fuel pump and see if it tries to start
8 - if it does, then enable the pump and fire it up
hope you get it going ... let us know
Old Sep 3, 2002 | 09:07 PM
actually, wait i just remembered that you're running a Dell'Orto, not a Nikki ... only pump the gas once or twice then, or you might flood it all over again.
sorry
Old Sep 4, 2002 | 01:22 AM
mperformance's Avatar
**** same problem I just posted!
I say we all burn those damn Holley FPR!
I have the HLY-12-804 and run a carter 7psi pump with feeding my weber...I guess I'll just turn that freaking screw all the way out too
How do I know I'm not running out of fuel then?...I can't trust my A/f gauge.
Correct the fuel problem first.
To unflood clean spark plugs but reinstall, crank the engine with enough juice to crank it well but don't overheat the starter...make sure you have enough power to crank it. Do not step on the gas unless you hear the engine firing up slightly, once it pops a bit step once on the gas to squirt some but not too much.... Use a starter or battery booster...that's what I do...
Old Sep 4, 2002 | 10:48 AM
metalliman's Avatar
I'm starting to think there may be something hanging up on the carb. I've set my purolator regulator down to .5 psi, the fuel pressure gauge reads 1.5 psi. After about 30 seconds worth of cranking, I have a badly flooded engine all over again. Is there anything that may be hanging up that would let the fuel directly into the engine?
Old Sep 4, 2002 | 03:10 PM
just a sugestion, have you check the needles? they might be stuck open dude...
check the float bowls if it's only one that is flooding is your carb...
Old Sep 4, 2002 | 11:24 PM
metalliman's Avatar
where exactly are the needles? I'm still learing about carbs. i'm guessing there underneath the float bowl cover.
Old Sep 4, 2002 | 11:39 PM
REVHED's Avatar
Hunting Skylines
Two-barrel Weber carbies only have only one float bowl (and one needle valve obviously). Not sure about Dells though.
Old Sep 4, 2002 | 11:41 PM
No. 13 on the diagram.
Old Sep 5, 2002 | 02:42 AM
true I forgot it was a dell. Buy a Compaq carb
seriously still it could just be the needle or a bad float level adjustment..that diagram more or less shows you everything.
15 is the adjustment for the float level.
