S-AFC/S4 GXL: What's the best way to hook it up?
In March I got myself an S-AFC (4 button blue screen one) for my car - an 86 GXL. Since then I have searched, and read post after post about installing and setting them up - but the main question I had never really got answered, so I've had to start a thread.
The vast majority of SAFC Installations on FC's that I have read about have been on S%'s, and some S4's, but mostly TII's. But my situation involves an S4 N/A. Being an S4, there is the issue that the throttle seems to read 100% after about a quarter throttle. I know that the S5 TPS is full range, and those who have TII's use the pressure sensor - but what can I do?
Is there a way that I can install the S-AFC where the throttle readings will be accurate? While I recognize that it may be difficult, I'm looking for proven methods here. Thanks for your suggestions!
could you not just put it to the pressure sensor and set the change over where you want it... seems the stock fuel system can handle it fine till your really on it... not just mashing tha gas for a second like the tps reading change over would do.
Im not sure but id guess a vaccume gauge in a na would act alot like a turbo car.... until the boost came on of course...
I wondered about the pressure sensor, but how accurate is it? Is it worth hooking it up like that, or will the readings be just as mangled as with the stock S4 TPS?
Is it even worth trying to get around this issue, or does it not have any real effect on the proper tuning of the car? If I am going go to the trouble and expense to take the car to get it tuned on a dyno with a wideband O2, I want to be sure that I can get the best out of it.
Well, when you're on the dyno doing your run getting your air fuel ratios, you're at WOT right? And that's what you tune for, max power at WOT... Well, even if it shows 100% earlier because of the way the s4 is set up, when you're at WOT, it'll still be tuned accordingly. It's just, when you are not at WOT but it is still reading 100%, it will be taking the corrections for that rpm range.
that that could mean adding or taking away fuel where its not needed. if your change over is set to 99/100 and that happends at 33% throttle then your WOT all out run map will be used for lots of times when the low map would be best.
It seems like the pressure sensor would give you more room for adjustment... but then again im a turbo guy.
the pressure sensor and S-AFC works for TII's because the pressure sensor sees a much larger range of voltages due to the boost always rising and falling.
Trending Topics
The only downside to using the AFC on an S4 low range TPS is that you spend most of the time on the high map. If you're adding fuel with the AFC, this will lower your gas mileage. Otherwise it works just fine.
You could always install a full range TPS from either the S5 or other car.
This thread has info on using the pressure sensor:
https://www.rx7club.com/showthread.p...hreadid=202098
The NA boost sensor (according to Mazda, the NA has a boost sensor, the TII has a pressure sensor...go figure) will read accurately enough in an NA application to be used with the S-AFC. However, it is much better to obtain an aftermarket vacuum/boost sensor if you plan on doing this.
Doesn't work for NA cars. The output from the NA pressure sensor is a very narrow reading because the vacuum reading on NA cars is constant while the engine is running.
If I am going to go out and buy an aftermarket piece, would a boost sensor be the best way to do this? If so - where would I pick one up, are they universal, and how much money are we looking at here?
In a TII the pressure sensor sees boost and vacuum, so the output varries. the S-AFC can be set to use the High map when in boost and the low lap when in vacuum. On an NA, you'll only ever get one map.
I don't disagree with you here. The NA Boost sensor output is not the problem. The problem is that the car is always in vacuum, so the output from the sensor is always the same.
I assure you that the NA boost sensor puts out a voltage based on the amount of vacuum it sees.
Um, we're talking about an NA, correct? So obviously the NA boost sensor will always read vacuum. But it will read varying degrees of vacuum based on engine load. Hence, you can now tune the S-AFC to load instead of throttle position.
I'll be happy to go home and prove this. I did quite a bit of work with the NA boost sensor when I did my turbo-NA project. I don't remember the actual values, but the output swung by several volts as I sucked down a vacuum. If I have time tonight, I'll put my scope on it again and repeat the test then post the values tomorrow.
Regardless, it's still a much better idea to use an aftermarket sensor.
MSD-2311 MAP Sensor, 1-Bar, normally aspirated applications Today $38.99
Is that what I'm looking for?
So, if I were to go out and pay $40-$60 USD for a Crane/MSD MAP sensor - would it be worth it? Would I then be able to accurately tune the SAFC throughout the throttle range? Or would picking up a used S5 TPS and get creative with the mounting/wiring of that be a better option? Does it accomplish the same thing - or would one be superior to the other?
Using a vac-pump will prove your theory. The only way to really test this is to drive around with the car under load and a monitor the output of the NA Boost sensor. I know where your coming from, but it just wouldn't work for us.
I may have to explore the aftermarket sensor.
I just found my data!
Wonderful having a VPN to your server at home...
OK, at atmospheric the sensor read 2.4V. Applying 10" of vacuum resulted in about 1.5V. I was using my tongue and a vacuum gauge, and 10" was all I could manage while holding the sensor, gauge, voltmeter and trying to tongue/suck a good vacuum (according to the guage, normally I am good for about 30"). I can only assume that the sensor voltage would continue to drop off until it hit about 1V. This is remarkably inverse to the TPS. If I am up for an adventure tonight I will try again as I now have a real vacuum pump.
Wonderful having a VPN to your server at home...OK, at atmospheric the sensor read 2.4V. Applying 10" of vacuum resulted in about 1.5V. I was using my tongue and a vacuum gauge, and 10" was all I could manage while holding the sensor, gauge, voltmeter and trying to tongue/suck a good vacuum (according to the guage, normally I am good for about 30"). I can only assume that the sensor voltage would continue to drop off until it hit about 1V. This is remarkably inverse to the TPS. If I am up for an adventure tonight I will try again as I now have a real vacuum pump.
you're right Aaron- with mine connected normally in the car, I can get about a 3v swing out the sensor- it doesn't act too linear, though, but then again I had no actual vac gage readings for comparison, it was kinda just "play with the throttle" type testing...
Just to add more fuel to the fire:
I didn't get to checking a spare boost sensor last night (bar night), but I did find some posts by Bambam7 using the search. He did some testing with the NA boost sensor as well for his turbo-NA project.
This one shows voltage variation during vacuum:
https://www.rx7club.com/showthread.p...hreadid=262629
I think that it should be fine with the S4 narrow TPS.
I mean if you're daily driving then you wont go past 3k much.
The most corrections on the fuel curve are after 4k RPMs so it doesnt really matter if you are using the hi throttle map when you're low thottle.
lol ahahahah
Well I cant believe anyone with an FC would never drive it over 3k as a daily driver. Its not even healthy to drive an FC like an old lady. But that aside I have the same problem on my NA s4 safc setup. My problem with just leaving it is that you dont get any fuel economy out of yor safc. This results because you will be using your WOT map ALL the time. That is not conducive to fuel economy. I believe I am going to use the rpessure sensor, but I need to wait until I am done my midterms. If not I am going to install a boost sensor and try that. I am not going to dyno tune my car (though many people will disagree with me) I think driving tuning is better. Best case scenario the imppossible perfect dyno can only approach an acurate simulation of real world conditions. You will want to tune your safc at different throttle possitions for best power and fuel economy. If you only drive your car to 3000 rpm you should just leave it parked and take the bus. Nobody who doesnt go over 3 grand would bother buying a SAFC, prob not even an FC whats the fun in a rotary you dont rev?
Short answer, try the pressure sensor I am going to, it seems to be the easiest fix. I just want a semi accurate setting so I am using the proper fuel map, last time I looked you can set what the SAFC reads as high and low throttle readings.
im saying that when I drive on the streets, I dont go over 3k
and most people with SAFC lean it out in the lower RPMs, which still gives ya better mileage
and when its time to let it rip, such as on the freeway ramp, or on the track, believe me that SAFC will be worth it to me
The car isnt allways in vacume, at WOT there is no vacume, and between idle and WOT there are varying degrees of vacume, how do you think NA cars run with map sensor based ecu's? vacume is a very good indication of throttle position.
