Greddy Profec B Spec II survey
Old Aug 1, 2005 | 12:46 AM
overkill's Avatar
If you all do not mind taking the time, please list your mods, PSI, and settings for your Profec B Spec II in this order:
Mods:
PSI:
SET:
GAIN:
START BOOST:
(With so many threads asking how to adjust this controller I thought it would be helpful for others, including myself.)
Old Aug 1, 2005 | 10:19 AM
snagalittle's Avatar
mods: t51r single, 1680 850 injectors, tiwn power, all suporting mods.
Psi: Low setting, 14psi High setting, 20psi
Set: Low setting, 37 High setting, 60
gain Low Setting, 10 High setting, 10
set gain Low setting, 120 High setting, 140
Old Aug 3, 2005 | 10:33 AM
purerx7's Avatar
Registered User
anyone have this on the stock twins, along with their settings?
Old Aug 3, 2005 | 02:20 PM
fastcarfreak's Avatar
3rd motors a charm I hope
Mods: T78 with all supporting mods
PSI:high setting at around 20
SET: 55
GAIN:10
Adam
Old Aug 7, 2005 | 02:56 AM
overkill's Avatar
bump
Old Aug 7, 2005 | 05:28 AM
sdminus's Avatar
Cant be bothered anymore
Stock twins, loads of other mods. Pm if you need more details
Lo
set 0%
Gain 5%
set gain
very low boost i think 8 psi
HI
set 34%
gain 24%
set gain 38
Very stable 13.2 psi
Hope this helps Scott
Old Aug 7, 2005 | 09:11 AM
quid's Avatar
Overkill, glad you asked this. I have the same question, just never got around to asking it. I have a 3" down pipe, 3" mid pipe, 3" catback, grounding kit, greddy profec spec II boost controller, aftermarket intake w/ K&N, HKS turbo timer, 18' Fitipaldi rims all the way around with Falkin skins, Eibach 2" drop, and a few other ammenities.
PSI, I am trying to set it at 10 but all I am pulling now is 8.5 intermittently
I have my wastegate working at 37%. I am having the hardest time putting in the start boost. I have tries pushing the set button twice like it said but the option does not come up. Also, I want to start with 0 gain but when I go to put it below 5, it beeps at me.
Also, what is more acurate, the profec or the boost gauge.
I look forward to everyone else's reply.
Quid
Old Sep 26, 2005 | 10:16 PM
overkill's Avatar
bringing this back from the dead, we need more input guys!
Old Oct 26, 2005 | 07:37 PM
overkill's Avatar
so far , these are the settings for mine. Note my secondary turbos are dying.
Set: 40
Gain:38
Start boost:40
13 psi on stockers , mods in my sig.
Old Oct 26, 2005 | 08:19 PM
overkill's Avatar
Quid
the only time you use the set button is to set the desired value, regardless if you are setting your set, gain or start boost. To set your start boost, press the "mode" button until "setboost" is displayed. Turn the set button to the desired value, and then push it to confirm your setting. I'm not sure whats going on with your gain. Is it conflicting with your limit or warning somehow?
Old Oct 26, 2005 | 08:27 PM
TwinTurbo93's Avatar
0-rotor-0-turbo-0-fd
Set: 40
Gain:38
Start boost:40
BTW, how many secondary turbos you have?
j/k
Great post.
I'm actualy eyeing the Profec B, so I'm educating my self here.
Old Oct 26, 2005 | 08:36 PM
overkill's Avatar
j/k
Great post.
hehe, despite my typo, it's more like a negative secondary turbo
BTW, I've read all the horror stories about how people are having the darndest time setting their controller. Don't let that sway your judgementy.I have not had any of those problems so far. I've spent minimal time , and when I say minimal I have only devoted maybe 5 minutes of tune time and I'm getting consistent boost.
Old Oct 26, 2005 | 08:47 PM
To tell you the truth I halted the buy of one just b/c I read some neg. feedback about it...
Old Oct 26, 2005 | 09:43 PM
NuTbAgSaN's Avatar
triangles
ill post what i HAD i have to retune it for a new ecu and dp and ic, but ill post my past settings
Mods:intake catback
PSI:10
SET:35
GAIN:5
START BOOST:i dont even remember
Old Jan 10, 2006 | 11:57 PM
bring this back from the dead again. I know there has to be more people then this with a profec b spec II.
Old Jan 11, 2006 | 08:22 AM
tdom's Avatar
silver7
Great topic
I'm just about done swapping out the twin turbo with a single. Once it is done I will need to tune it first with the stock ecu. After it is running good I will need to tune it with Apexi Power FC + Commander.
Here are my mods:
Single Turbo
SMIC intercooler
Koyo radiator
Blitz intake
Mid Pipe
Can someone give me the boost setup? Will the boost the same for stock ecu and Apexi Power FC?
Thanks,
Old Jan 11, 2006 | 11:06 AM
Montego's Avatar
Don't worry be happy...
Top Answer: 1
From memory:
Set: 28
gain: 14
For consistent 10 psi
Old Jan 11, 2006 | 11:33 AM
seanfd3s's Avatar
airplane apex seals
Here are my mods:
Single Turbo
SMIC intercooler
Koyo radiator
Blitz intake
Mid Pipe
Thanks,
https://www.rx7club.com/showthread.p...ghlight=profec
click on the bottom doc.
Old Jan 24, 2006 | 03:01 AM
ihavetwins's Avatar
Needs more seat time
bump action for every one
Old Apr 23, 2006 | 05:07 PM
FDarerex7's Avatar
12 psi w/ stock ported turbos
set: 45
gain: 22
set gain: .42
Old Jul 4, 2006 | 12:53 PM
overkill's Avatar
bump
Old Jul 31, 2006 | 12:26 PM
overkill's Avatar
bump
Old Sep 22, 2006 | 10:51 AM
c_akira's Avatar
Here's my setup:
Mods: Greddy CB, Bonez 3" dp, Blitz Intakes, HKS BOV, everything else stock
PSI: 9.5 (although my Defi boost gauge reads closer to 10)
SET: 25
GAIN: 5%
SET GAIN: 20
Old Sep 22, 2006 | 01:15 PM
Robertio's Avatar
For my old car:
Mods: BNRs plus everything
PSI: 20-21
SET: 52
GAIN: 90
START BOOST: can't remember
Old Sep 29, 2006 | 06:04 PM
njstreetrx7's Avatar
i need some nhelp w this what u guys numbvers equivilent to.....i also dont rember seeing psi on.ly set and gain...this boost controller is very confusing try this fore a comapsrison
AKIRA---PSI: 9.5 (although my Defi boost gauge reads closer to 10)
SET: 25
GAIN: 5%
SET GAIN: 20
From memory:
Set: 28
gain: 14
