Will premix make my engine last significantly longer ?
Old Feb 26, 2005 | 06:40 PM
wthdidusay82's Avatar
Rotary Power
Will using a premix on my s4 na make the engine last significantly longer ? I am strongly considering it, only if it has some big advantages over using the stock omp system... ( Longer lasting engine)
Old Feb 26, 2005 | 06:53 PM
Kenteth's Avatar
Like Ghandi with a gun
Define significantly... Adequate engine maintnance will get the engine to live significantly longer,..
The question isn't whether premix will have the engine live longer, but rather if the stock system of lubrication is/not " adequate"
Old Feb 26, 2005 | 07:00 PM
Rotary Power
well yes this is my question....but i also heard that using the premix will help u to get less carbon deposits inside the engine
Old Feb 26, 2005 | 07:05 PM
Parastie's Avatar
Mountain Rotary Mod
It's debatable. Most of the rebuild guys around here say premix is better, but other disagree. I premix because my oil lines were shot and i didn't feel like replacing them. You can search for this topic, it has been discusses several times.
Old Feb 26, 2005 | 07:19 PM
mwpayne's Avatar
Admitted 'rexaholic'
My OMP seems to be working fine, but I add MMO or 2 cycle oil to my gas anyway.
Might make no difference at all, but it makes me FEEL better.
Old Feb 26, 2005 | 07:24 PM
RexRyder's Avatar
i dunno, probably
Old Feb 26, 2005 | 07:57 PM
iceblue's Avatar
Passing life by
my OMP is leaking out the shaft so its not getting enugh oil and runing lean so i premixing it 150 to 1 my air fule guage shows bettor and being a 2cycle engin guy my whol life it makes me feel alot more comfortable. i will switch 128to1 after i block off the OMP
Old Feb 26, 2005 | 08:46 PM
Amur_'s Avatar
Refined Valley Dude
MMO is *not* a lubricant, so be careful you.
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
