GTU skidpad ?!?
Old Oct 22, 2002 | 12:17 AM
GTU skidpad ?!?
I have seen the Skidpad rating for a S4 T2, but been wondering how does the GTU do ?
Old Oct 22, 2002 | 12:19 AM
koukifc3s's Avatar
Clogged cat
what's the skidpad rating for the TII?
I know that the 86 SE tested at .88.
Old Oct 22, 2002 | 12:24 AM
I bealive i read .84 it was that, or .82
Aww C'mon someone must know.
Old Oct 22, 2002 | 12:48 AM
RarestRX's Avatar
NA Powah, Every Hour!
Yo,
1989 GTUs per Road & Track:
0.81g
KS
1989 GTUs "I ain't gonna tell you what it did the 1/4 in."
Old Oct 22, 2002 | 01:06 AM
MtnRacer's Avatar
infini guru
I can't believe the numbers are that low. Is that the crappy stock tires making the number so bad, or what?
Steve
Old Oct 22, 2002 | 02:44 AM
ajsuper7's Avatar
Nothin But a G Thang
ive heard that the 86-88 s4 n/a's made .86 and the s5 n/a's made .89. i dont think that a a new protegé can outhandle any rx7's
Old Oct 22, 2002 | 03:16 AM
NZConvertible's Avatar
I'm a boost creep...
Don't put too muck stock in skidpad numbers; they're a very unrealistic measure of how well a car handles. The smooth, flat surface of a skidpad bears no resemblance to a real road, which is never smooth, and may have bumps, dips, ripples, camber, etc. It's really only a measure of the outright lateral grip of the tyre, which is irrelevant if the suspension can't keep those grippy tyres of the uneven road surface. A car with good skidpad numbers won't necessarily handle or grip better than one with properly sorted road suspension.
Old Oct 22, 2002 | 04:04 PM
Ohh, i was worried to see that the T2 did better than the GTU, yet the t2 weighs more.
Can someone tell me exactly what all makes the GTU different from a GXL.
I am getting a GTU soon, ,only needs a Apex seal.
Old Oct 22, 2002 | 05:57 PM
ummmm.... do you know what that means?????????
or was that a joke????
You've got 270 posts so you should know, right????
Old Oct 22, 2002 | 06:46 PM
dre_2ooo's Avatar
All i ever heard was .89 for the N/As and .91 for the TII's
Old Oct 22, 2002 | 08:45 PM
Enough with the guessing. Here are the actual test numbers from the magazines:
89 Turbo II: .85g
89 GTUs : .86g
Both on 205/55/VR16 Bridgestone Potenza RE71 on 16*7 wheels
Sports Car Illustrated
(The GTUs and Turbo have the identical suspension and tires, but the GTUS is nearly 250 lbs lighter)
89 Convertible: .83g
205/60/15 RE71 on 15*6.5
Motor Trend
88 Convertible: .82g
Road & Track
88 GTU: .80g
88 Turbo II 10AE: 83g
205/55/16 Goodyear Eagle VR
Road & Track
87 Turbo II: .83g
On Goodyear VR
87 Turbo II: .85g
On RE71
Car & Driver
86 GXL: .86g &.83g on another car
86 Sport: .84g
87 Turbo II: .85g
Road & Track
89 GTUs: .81g
89 Turbo II: .85g
Road & Track
(The GTUs tested must havebeen beat to hell beacuse it put up some lousy numbers in this test. It ran 0-60 in 8.6 secs in the test. Mazda claimed 7.7 secs. Also, how can a car 200+ lbs lighter than a Turbo with the same tires and suspension produce less lateral grip?)
By the way....GXL, GTU, GTUs, Convertible and Turbo RX-7s never came on crappy stock tires. Bridgestone Potenza RE71 was standard equipment on all non-turbo RX-7s and S5 Turbos and at that time it was arguably the best tire in the world. Its equivalent today is the Potenza S-03 Pole Position. the S4 Turbo came on Goodyear Eagle VR55 which was not a bad tire either.
Old Oct 22, 2002 | 11:48 PM
Yes i do know what an Apex seal is, there are 3 per rotor, they rest in a divit at the tip of each rotors point. But when considering the price of the car, this is not a problem, hell i think i could scrap the car for more than i am paying ($400)
And he is not sure if it is a Apex seal, he assumes it is, becuase it is Blowing white smoke, but still runs.
Old Oct 22, 2002 | 11:58 PM
koukifc3s's Avatar
Clogged cat
the 86 n/a did do .88 in the skidpad. I've got those magazines that came out in 86 where they were testing the car.
BUSTN
V-8 Powered RX-7's
Oct 23, 2015 05:59 PM
josef 91 vert
23
Sep 3, 2015 11:20 AM
